Page 8 of 8 1 2 3 4 5 6 7 8
Re: 440 Rear Main Seal Leak--Almost Suicidal!! UPDATE! [Re: ozymaxwedge] #2516768
07/03/18 05:42 AM
07/03/18 05:42 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Originally Posted By ozymaxwedge
Well it got me frown ,,, been working real hard on this car and finally drove it yesterday, after about 5 miles the smoke off the exhaust started.
Seriously not felling like pulling this engine back out but dont think I can get the pan off while its in there.
For the life of me I cant remember putting sealant on the retainer mating surface, it's probably it. F#*^ it.
Want a giggle ?? After pulling the box and finding a dry rear main I put it back in, for the next 5 days I replaced the -12 line, purchased and fitted new AN fittings only to wake up and think, "the f*ckin dip stick hole" . I have an aluminum pan that has the tube welded to the other side, I had forgotten that we last ran this engine with a different pan. Sooooo all my oil was coming up through the open dip stick hole in the block.
IDIOT
1963 Plymouth Max Wedge
1971 Barracuda
Re: 440 Rear Main Seal Leak--Almost Suicidal!! UPDATE! [Re: RAMM] #2516807
07/03/18 11:09 AM
07/03/18 11:09 AM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
I offset the crank seal. Put the retainer assembly in the freezer. Makes it easier to slide into the block. Put side seals on with sealant and slide it in easily
Works quite well
Re: 440 Rear Main Seal Leak--Almost Suicidal!! UPDATE! [Re: ozymaxwedge] #2516877
07/03/18 02:06 PM
07/03/18 02:06 PM
IDIOT
Welcome to the club that Murphy messes with whistling grin
If you don't error now and then how you going to learn whistling grin
Congrats on the find and sharing it with us up
Re: 440 Rear Main Seal Leak--Almost Suicidal!! UPDATE! [Re: RAMM] #2566977
10/20/18 04:44 PM
10/20/18 04:44 PM
georgia
moparpro Offline
moparpro  Offline
georgia
nicks garage in canada has neat way of doing rear seals he has a videdo of him building a mopar bb shows how he puts seal in,he offset the rubber by 1/4 of inch on one side,meaning he leaves a 1/4 inch of seal sticking up before install and he swears he have not had any leaks,the guy from pete garage build a 440 with same method and explains how it works.seems to work for them.
Re: 440 Rear Main Seal Leak--Almost Suicidal!! UPDATE! [Re: RAMM] #2567038
10/20/18 08:17 PM
10/20/18 08:17 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Offsetting the seal does little to nothing to prevent the seal from leaking. I’ve built at least 8 bb Mopars over the past 5 years with no offset on the seal. Zero leaks. It’s all about the alignment of the upper and lower half’s of the seal.
Re: 440 Rear Main Seal Leak--Almost Suicidal!! UPDATE! [Re: ccdave] #2567133
10/21/18 12:37 AM
10/21/18 12:37 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
And offsetting the upper and lower half s helps with the alignment of the aluminum retainer itself
I got to play with this when I built my motor last winter
Aligning the seals flush with the block , crankshaft out , and then marking the retainer surface and block with a sharpie when snugging up the retainer and seeing the alignment of the seals with the crankshaft installed and out
Then tried offsetting the seal halves at 12 and 6 , installing the retainer again , and the retainer was in perfect alignment with those sharpie marks
Personally I think a lot of these leaks has to do with the side seals or retainer
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: 440 Rear Main Seal Leak--Almost Suicidal!! UPDATE! [Re: bee1971] #2567265
10/21/18 01:00 PM
10/21/18 01:00 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I just went through this. This is what fixed it:
1.Found interference with windage tray and top of stud , drilled windage tray to allow stud to "pass trough"
2. found interference with the little 12-point nut and seal retainer, 1/2 moon-ed the retainer in the nut area for clearance.
3. clocked-seal 90 degrees.
This was a fresh engine that was run 3-4 times pulled out, sealed up, pressurized and leak checked with soapy water and held 25 psi of crankcase pressure out of the car with no visible leaks at the gasket or seal, however leaked like a sive while running. Being able to examine the pan gasket under pressure I am confident that this was not a gasket issue. My summary would be that to make sure that the retainer can float without interference , then clock seal 90 degrees so that it alignment is guaranteed, fill sides with a good sealer sealer (I have always just used sealer on the sides). I have built many bb mopars, stock rebuilds, stud applications in stock blocks, and aftermarket block builds, this was my first leaker.
