1009 gasket #2516408
07/02/18 02:48 PM
07/02/18 02:48 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
40 over RB.they dont hang over into the bore but they do slightly hang past the bevel in a few spots. is that going to be a problem?
Re: 1009 gasket [Re: bonefish] #2516421
07/02/18 03:07 PM
07/02/18 03:07 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
From what I've seen, YES.
I've used them on 4.375" bores, but there were no remaining factory chamfers on the tops of the cylinders (just a small break on the edge by the machinist) and no overhang in the cylinder heads' chambers.
IIRC, the pics I've seen of 1009 failures could all be traced to the fire ring being exposed by one or both of those conditions.
No idea why they're listed for anything larger than a 4.375" bore, since that's the max I've seen where they can fit w/o some type of overhang issue.
Re: 1009 gasket [Re: bonefish] #2516441
07/02/18 03:28 PM
07/02/18 03:28 PM
AndyF Offline
AndyF  Offline
Don't try to save money on the head gaskets unless you're dead broke and fixing an engine on the side of the road so you can get the family to town before the banjos start playing......
Re: 1009 gasket [Re: bonefish] #2516454
07/02/18 03:49 PM
07/02/18 03:49 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
I won't use a 1009 on a 4.32" bore or larger. had them burn thru and torch alum heads.
Re: 1009 gasket [Re: lewtot184] #2516470
07/02/18 04:39 PM
07/02/18 04:39 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
whats the alternative? does FelPro make a oversize gasket?
Re: 1009 gasket [Re: lewtot184] #2516490
07/02/18 05:24 PM
07/02/18 05:24 PM
iagree Check the bore size on all of the Fel Pro head gaskets. up
Cometecs will make any bore size you may need on their head gaskets scope
Re: 1009 gasket [Re: bonefish] #2516502
07/02/18 05:53 PM
07/02/18 05:53 PM
BradH Offline
BradH  Offline
More than one, but you don't mention CR or deck height or anything else that would help narrow down the choice.
1. The "standard" Permatorque replacementis supposed to have a compressed thickness of approx. .040" and is pretty close to a 4.50" ID. It's not a high-CR type of gasket, though, and most recommendations I hear say not to use much over 10:1 w/ it.
2. The "marine" gasket is the same dimensions as the standard Permatorque, only the construction is supposed to be like the 1009, with the exception of not having the wire reinforcement in the fire ring.
3. There are some dedicated performance gaskets similar to the 1009, only with 4.50" bores. However, those also have compressed thickness of approx. .050", which can jack-up your quench if your pistons are at zero deck height and you're trying to keep it tight.
If you look for something other than Fel-Pro, IMO avoid the Mr. Gasket MLS stuff.
Re: 1009 gasket [Re: bonefish] #2516508
07/02/18 06:03 PM
07/02/18 06:03 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
They hung over the chamfer on my 4.350 493. It's only a 9:1 engine so we rolled the dice on their replacement gaskets that come in the gasket set. They were 4.410 IIRC.
At the time none of their other "good" large bore gaskets had .039 compressed thickness. Made a bunch of dyno pulls and it pulled my New Yorker around without complaint.
Kevin
Re: 1009 gasket [Re: bonefish] #2516634
07/02/18 10:55 PM
07/02/18 10:55 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Fel Pro 17059
RIP Monte Smith
Re: 1009 gasket [Re: bonefish] #2516641
07/02/18 11:05 PM
07/02/18 11:05 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Have a read of the label on the 1009, it says something along the lines of Chrysler big block "exc" 440 and hemi. I just put some on the shelf and purchased Cometic$
1963 Plymouth Max Wedge
1971 Barracuda
Re: 1009 gasket [Re: lewtot184] #2516692
07/03/18 12:05 AM
07/03/18 12:05 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
They will burn and torch a slot between cylinders on steel heads also. 4.35 bore, small chamfer, lots of spray, not overhanging.
Re: 1009 gasket [Re: ozymaxwedge] #2516695
07/03/18 12:10 AM
07/03/18 12:10 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Never saw that on a package, I read 361-440 exc hemi.
Re: 1009 gasket [Re: bonefish] #2516717
07/03/18 12:52 AM
07/03/18 12:52 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Cometic are the best.I think they also offer several choices on compressed thickness.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 1009 gasket [Re: CompWedgeEngines] #2516793
07/03/18 10:14 AM
07/03/18 10:14 AM
BradH Offline
BradH  Offline
Originally Posted By CompWedgeEngines
Fel Pro 17059
Yeah, that's the # of the marine gasket I mentioned above... couldn't remember the part #.
Re: 1009 gasket [Re: bonefish] #2516819
07/03/18 11:39 AM
07/03/18 11:39 AM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
As long as the block and heads have been finished for an MLS gasket. Otherwise you should use a standard style gasket.
Re: 1009 gasket [Re: BradH] #2517159
07/03/18 08:03 PM
07/03/18 08:03 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
its 9.5-1 comp. 0 deck, 4.150 stroker. the marine gasket is pretty big but would prob. work.i will lose some quench with the marine gasket.
Re: 1009 gasket [Re: bonefish] #2517359
07/04/18 11:09 AM
07/04/18 11:09 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Al, I thought that motor was getting 906 heads.
If so, and it doesn’t have quench dome pistons...... there won’t be any quench anyway.
Re: 1009 gasket [Re: fast68plymouth] #2517445
07/04/18 01:32 PM
07/04/18 01:32 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
these are the pistons,the pad is a 0 deck.
Re: 1009 gasket [Re: bonefish] #2517657
07/04/18 08:09 PM
07/04/18 08:09 PM
So. Burlington, Vt.
So. Burlington, Vt.
If you’ll be using open chamber heads, it won’t have effective quench.
Unless the heads have been milled .080 and you’re going to run .020 thick gaskets.
Re: 1009 gasket [Re: fast68plymouth] #2517832
07/05/18 08:53 AM
07/05/18 08:53 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
thanks ,i guess ill go with the marine gaskets.
