Page 3 of 6 1 2 3 4 5 6
Re: BB Street heads for mild 505 [Re: TonyS451] #2509331
06/16/18 01:54 PM
06/16/18 01:54 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I'm not sure how accurate this info is on the stealth head flow numbers out of the box, but I found this Hot Rod article where max flow was only 158.5 @ 0.500"
http://www.hotrod.com/articles/mopp-1205-big-block-cylinder-head-testing-flow-charts/
This is what my stealth heads flowed with just a bit of hand porting (gasket match, bowl blending, and valve job.) Not a huge improvement like CNC porting, but basically just cost me some time and the money for the valve job (and extra to flow the head just to see where it was at.)
Lift Intake Exhaust
0.100" / 82 / 81
0.200" / 157 / 127
0.300" / 221 / 151
0.400" / 260 / 174
0.500" / 278 / 190
0.600" / 283 / 200
0.700" / 289 / 211
0.800" / 289 / 215
I posted this way back in Jan, 2013 when I was putting the engine together.
https://board.moparts.org/ubbthreads/ubbt...tml#Post1024402
Re: BB Street heads for mild 505 [Re: 451Mopar] #2509452
06/16/18 10:33 PM
06/16/18 10:33 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Lift Intake Exhaust
0.100" / 82 / 81
0.200" / 157 / 127
0.300" / 221 / 151
0.400" / 260 / 174
0.500" / 278 / 190
0.600" / 283 / 200
0.700" / 289 / 211
0.800" / 289 / 215
That's good info. Do the stealths really flow that poorly at .500?? That's really bad, even on the exhaust side.
2 kids and a dog
Re: BB Street heads for mild 505 [Re: TonyS451] #2509562
06/17/18 11:42 AM
06/17/18 11:42 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The flow bench that my heads were flowed on is an older SF-110 model. I think the cylinder bore size was only 4.25". Not sure what entry radius, if any was used?
I have had 4 heads flowed on that machine, so I just compare what the different heads flowed, and the last 3 seemed reasonable, if not a bit low. The last head flowed at that shop were the Trick Flow 240's and the results were all messed up, not sure if something was going wrong with the test or machine, but the numbers were way low. Took the heads to another shop with a newer SF-1020 flow bench and the flow results were very close to the advertised ratings from Trick Flow.
Re: BB Street heads for mild 505 [Re: TonyS451] #2510125
06/18/18 08:18 PM
06/18/18 08:18 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I am curious as since I put my eng in my 63 together in 2011 I have not looked hard at bigblock heads. And I was curious if the Trick Flows use raised exh ports or standard height exh ports ? I really have not looked into them as I have no plans to change anything big on my car. I do know in 2011 when I bought aluminum heads I went with the basic Indy SEZ heads I bought from Dwayne Porter and he sold them to me for a good reasonable price. There was no Trick Flow heads in 2011 when I built my 493. Dwayne opened up the intake ports to max wedge size as I figured why not in case I want to step it up some later. But I liked the fact the SEZ heads have standard exh ports and I did not need to buy offset rockers or did not need to use external oiling to the heads and could use standard headers. I wanted to keep my eng build very basic and simple since I drive it a lot on the street. I am curious as to how the Indy SEZ heads compare to the Trick flows in performance and price today ? I don't seem to here as much about the Indy SEZ and EZ heads since the Trick Flows came out. Ron
Re: BB Street heads for mild 505 [Re: TonyS451] #2510152
06/18/18 09:09 PM
06/18/18 09:09 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Ootb stealth from a few months ago vs valve job, back cut, bowl blend.
28”, 4.375 bore, radius inlet plate, no tube on ex
Ootb:
Lift——in/ex
.100—65.7/51.8
.200–134.8/101.2
.300–197.2/135.4
.400–241.2/159.0
.450–248.7/167.1
.500–254.3/174.4
.550–256.1/179.8
.600–256.9/184.2
2 mins(or less) in the intake bowl will get it into the 260’s
Cut seats, back cut valves, blend bowls:
Lift——in/ex
.100—72.1/59.1
.200–147.6/112.2
.300–210.4/144.4
.400–254.3/166.4
.450–267.4/176.1
.500–273.7/185.9
.550–277.5/193.2
.600–280.5/198.1
Re: BB Street heads for mild 505 [Re: fast68plymouth] #2510170
06/18/18 09:47 PM
06/18/18 09:47 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Ootb:
Lift——in/ex
.100—65.7/51.8
.200–134.8/101.2
.300–197.2/135.4
.400–241.2/159.0
.450–248.7/167.1
.500–254.3/174.4
.550–256.1/179.8
.600–256.9/184.2
Lift——in/ex
.100—72.1/59.1
.200–147.6/112.2
.300–210.4/144.4
.400–254.3/166.4
.450–267.4/176.1
.500–273.7/185.9
.550–277.5/193.2
.600–280.5/198.1
So, if the theory of 1cfm per 2hp is correct, that small amount of head work may equal a 40hp improvement ?? That's money well spent
2 kids and a dog
Re: BB Street heads for mild 505 [Re: 383man] #2510172
06/18/18 09:50 PM
06/18/18 09:50 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Ron - I don't think you could have put together a better working combination for the money. Well done!
2 kids and a dog
Re: BB Street heads for mild 505 [Re: TonyS451] #2510324
06/19/18 10:57 AM
06/19/18 10:57 AM
So. Burlington, Vt.
So. Burlington, Vt.
Ootb:
Lift——in/ex
.100—65.7/51.8
.200–134.8/101.2
.300–197.2/135.4
.400–241.2/159.0
.450–248.7/167.1
.500–254.3/174.4
.550–256.1/179.8
.600–256.9/184.2
Lift——in/ex
.100—72.1/59.1
.200–147.6/112.2
.300–210.4/144.4
.400–254.3/166.4
.450–267.4/176.1
.500–273.7/185.9
.550–277.5/193.2
.600–280.5/198.1
On a build where the hp/ci is about 1.1, I don’t think you’d see 2hp/cfm gain.
Re: BB Street heads for mild 505 [Re: fast68plymouth] #2510325
06/19/18 11:10 AM
06/19/18 11:10 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
whats the cost of back cut, valve job and bowl blend?
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: BB Street heads for mild 505 [Re: Jerry] #2510332
06/19/18 11:43 AM
06/19/18 11:43 AM
So. Burlington, Vt.
So. Burlington, Vt.
Starting with new** stealth heads........
-disassemble
-measure guides *
-machine and finish grind seats
-back cut valves
-blend bowls
-flow test one cylinder
-jet wash heads
-test springs
-reassemble heads
$450
*if guides need honing it will be an extra charge
**Used heads will need to be jet washed and bead blasted prior to the seats being cut and bowls blended, and the valves will also need to be cleaned, bead blasted, and refaced..... all of which will add $150 to the total.
Re: BB Street heads for mild 505 [Re: TonyS451] #2510663
06/20/18 03:01 AM
06/20/18 03:01 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thank you Tony. wave Ron
Re: BB Street heads for mild 505 [Re: TonyS451] #2513357
06/26/18 05:03 AM
06/26/18 05:03 AM
Pittsburgh,PA
RTSrunner Online content
RTSrunner  Online Content
Pittsburgh,PA
I know they are a performace based stock upgrade,but where would the Edelbrock E-Street heads fall in power production here? What are their power to cubic inch levels and limitations? Would they be better for the anticipated street torque levels and driveability with the high axle gear ratio? ...sorry for all the questions!
Re: BB Street heads for mild 505 [Re: TonyS451] #2513417
06/26/18 11:50 AM
06/26/18 11:50 AM
So. Burlington, Vt.
So. Burlington, Vt.
Power potential wise, the E street is the same as the RPM.
It’s the same casting.
Re: BB Street heads for mild 505 [Re: fast68plymouth] #2513537
06/26/18 04:13 PM
06/26/18 04:13 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Is it just a smaller chamber ?
2 kids and a dog
Re: BB Street heads for mild 505 [Re: TonyS451] #2513601
06/26/18 06:16 PM
06/26/18 06:16 PM
So. Burlington, Vt.
So. Burlington, Vt.
They come in 75 or 84 cc versions.
Re: BB Street heads for mild 505 [Re: TonyS451] #2515873
07/01/18 02:20 PM
07/01/18 02:20 PM
Central NC
gch Offline
gch  Offline
Central NC
May have been said but why not just cnc your heads and maybe some 1.6 rockers(intake anyway) if you are happy with what you have?
Re: BB Street heads for mild 505 [Re: fast68plymouth] #2563427
10/13/18 03:40 PM
10/13/18 03:40 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Pulled the trigger on the TF 240's. Man they look nice! Note to self: remember, stay the course, this is not a race car
2 kids and a dog
Re: BB Street heads for mild 505 [Re: TonyS451] #2563436
10/13/18 03:56 PM
10/13/18 03:56 PM
AndyF Online content
AndyF  Online Content
Even with a mild cam those heads will make the car feel like a race car when you put your foot into it. They really work.
Re: BB Street heads for mild 505 [Re: AndyF] #2563446
10/13/18 04:30 PM
10/13/18 04:30 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Looking forward to getting it going!
2 kids and a dog
Re: BB Street heads for mild 505 [Re: TonyS451] #2563640
10/13/18 11:54 PM
10/13/18 11:54 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
They look good Tony. Very nice choice and good luck with it. Ron
