Re: A/C with R12 still serviceable?
[Re: MONC]
#2514450
06/28/18 02:01 PM
06/28/18 02:01 PM
Posts: 788 Plymouth, MI
HotRod20
Plymouth, MI
There is no law that states an existing system "has to be" converted to R 134 a if a system using R-12 is functioning properly. If it needs recharging due to a leak,and you have a source for the R -12 then consider getting it fixed. Many technicians will try to sell you retrofit kits,but if your system is low on charge,it may only need an o ring or tightening of a fitting. Have a reputable garage leak check the system and find out an action plan for a repair. R -12 systems in good working order will cool down much faster than 134a systems. Beware though, that the cost of any remaining R-12 refrigerant on earth is going to be very expensive, that's why many car guys retrofit to the newer R-134a systems. Hope that helps ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) HR 20
[Re: HotRod20]
#2514484
06/28/18 03:00 PM
06/28/18 03:00 PM
Posts: 8,681 Buford, GA
I_bleed_MOPAR
Buford, GA
![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) with all of the above. Another thing is you have to be certified in a/c repair to buy R-12 if you are thinking of doing the repair yourself. Unless you know someone.... ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) )
[Re: MONC]
#2514485
06/28/18 03:05 PM
06/28/18 03:05 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Lots of places wont touch R12 because they dont have the machines for it anymore.I know the last shop I was at had R!2 and we were only like 1 of 30 or so places that had it.Let alone most dont have R12 to recharge it.We were getting 50 bucks a pound for it which was cheap.Changing to 134 isnt very hard.Usually just the conversion kit and a reciever.dryer.Did quite a few at work and almost all lasted and cooled decent.oh yeah 134 only uses IIRC 85 % of 12.You can pick up 1 pound cans at times.Just be careful we had sysyems at work that identifier said had benzyne,butane etv in it.Rocky
Chrysler Firepower
[Re: MONC]
#2514549
06/28/18 05:38 PM
06/28/18 05:38 PM
Posts: 3,683 The Historic Hudson Valley
MONC
Thanks for the insights guys very helpful. I am going to see if my regular mechanic can at least leak check the system. I can get some R12, but not sure if my mechanic has a machines for it.
Hard to find restoration places that do it as well...
Mopar Or No Car
[Re: MONC]
#2514555
06/28/18 05:44 PM
06/28/18 05:44 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
I don't get why you say about "diff machines" between R12 and R134... the only diff is the niple port and there are adapters for that.
At least locally, any A/C shop is able to work on any refrigerant without diff machines really
[Re: NachoRT74]
#2514562
06/28/18 06:17 PM
06/28/18 06:17 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
At least locally, any A/C shop is able to work on any refrigerant without diff machines really things work different up here. It is illegal to vent freon to the atmosphere. It must be recovered and recycled. If you cross contaminate your R12 with R134, or vice versa, then you have an expensive waste product to dispose of.
[Re: John_Kunkel]
#2514563
06/28/18 06:17 PM
06/28/18 06:17 PM
I_bleed_MOPAR
Buford, GA
Come on, John. You're not releasing freon into the atmosphere, are you? ![biggrin biggrin](/ubbthreads/images/graemlins/custom/biggrin.gif) Tim
[Re: I_bleed_MOPAR]
#2514582
06/28/18 07:46 PM
06/28/18 07:46 PM
Posts: 25,992 Rio Linda, CA
John_Kunkel
Rio Linda, CA
No, I have both an R-12 and R-134 machine but I'm not the subject, the OP want's to "service" a system with no mention of the system's status. If it's totally flat or just low, service can be performed with minimal equipment and no harm to the ozone layer.
[Re: John_Kunkel]
#2514613
06/28/18 08:41 PM
06/28/18 08:41 PM
I_bleed_MOPAR
Buford, GA
Easy there, big guy. Only kidding. ![blush blush](/ubbthreads/images/graemlins/custom/blush.gif) Tim
[Re: cudaman1969]
#2514620
06/28/18 08:47 PM
06/28/18 08:47 PM
Posts: 4,159 Canada -- Posts: 4034 -Registe...
5thAve
Canada has, I think, R15, they don't sell 134A, read that somewhere. Maybe one can bring down some when coming to Carlisle. Canada has R134 but it's harder for the average shmoe to get.
[Re: John_Kunkel]
#2514654
06/28/18 10:02 PM
06/28/18 10:02 PM
MONC
No, I have both an R-12 and R-134 machine but I'm not the subject, the OP want's to "service" a system with no mention of the system's status. If it's totally flat or just low, service can be performed with minimal equipment and no harm to the ozone layer. The original system was rebuilt, but it is not blowing cold. Cool at best...
Mopar Or No Car
[Re: IMGTX]
#2515344
06/30/18 05:04 PM
06/30/18 05:04 PM
John_Kunkel
Rio Linda, CA
And remember, the R-134 molecule is smaller than the R-12 so, if there are minute holes in a hose or component, the R-134 will leak out when the R-12 won't.
[Re: cudaman1969]
#2515350
06/30/18 05:26 PM
06/30/18 05:26 PM
DaytonaTurbo
Manitoba, Canada
Here we have to watch out for some of the top-ups guys have done using that junk from the store. Because the retail sale of refrigerant in canisters under 22lbs is prohibited the stuff you buy at walmart is hydrocarbon based, usually propane/butane or something similar, which does work as a refridgerant in systems designed for it (not automotive). Canada has, I think, R15, they don't sell 134A, read that somewhere. Maybe one can bring down some when coming to Carlisle. We use R134A here. R12 is extinct. Legislation in place to phase down production limits of R134A to something like .5% of current levels by 2020 and replace it with R1234YF which is apparently what new vehicles are coming with. Right now R134A is a few bucks a pound but the R1234YF is in short supply and going for 50-75 a pound. Soon the R134A will start jumping up in price. We're not allowed to import the small cans of R134A either, yet nothing stops me from diving across the border and doing it on US soil.
[Re: IMGTX]
#2515401
06/30/18 06:00 PM
06/30/18 06:00 PM
Posts: 637 SoMd, USA
135sohc
SoMd, USA
I've done lot of R134a conversions. They really aren't that good. Here are a few facts to ponder.
1. R12 is a better refrigerant and operates at lower pressures. You will never get an R12 system to be as cold as it should be by using R134a. Partly because of the poorer refrigerant properties and partly because the expansion valves/orifice tubes for R12 systems are not design for the proper pressures to operate R134a. You may be able to get a different orifice tube but the expansion valves used in Mopars would have to be tuned to the R134a. I don't know of anyone who sells a replacement that is properly tuned for R134a.
2. Converting an R12 system to R134a is a temporary fix since the R12 systems are lower pressure designs. The higher operating pressures of R134a will eventually cause leaks. Even with new hoses the systems will not last as long before a leak will occur. Part of this is because R134a systems typically have 2 pressure sensors (1 low and 1 high) and a relief valve. Most R12 systems have 1 low pressure sensor only. At normal charging you are turning 800 to 2000 rpms which is not indicative to a normal driving experience. Imagine stomping on the throttle to pass somebody with the A/C on. Modern cars will either electronically detect a full throttle and temporarily cut off the compressor or when the pressure spikes the High pressure switch cuts off the compressor for you. An R12 system will simply spike to over 300PSI on the high side without much trouble. Easily over 100psi more than R12 will do and was deigned for. It can only take that so long before it leaks.
3. R134a requires approx 80% of the volume of R12. Keep this in mind while charging. Overcharging will result in very high pressures. In modern R134a systems there is usually a high pressure vent to release excess pressure. Those are not usually on R12 systems.
4. R12 uses mineral oil R134 uses ester or PAG oil. Two factors to consider about the oil. Compatibility with the refrigerant and compatibility with the other oils in a conversion. The oil is carried by the refrigerant through the system to lubricate it. R134a will not carry mineral oil so you can't use it or compressor failure will occur. However Mineral oil is not compatible with PAG oil. In a conversion you must either flush everything out and replace the compressor to remove the mineral oil or use simply use ester oil. The mineral oil will just find a low spot and settle there but as long as you do not add PAG oil it won't hurt anything. This is important because an inexperienced person/shop may add PAG since most of the OEM's use it and then you have problems.
In my opinion the two best choices are buy some overpriced R12 on craigslist or do a legitimate conversion. A legitimate conversion would be something like a Vintage air system with a newer style (high pressure compatible) compressor and proper pressure sensors.
I still do R134a conversions even on my cars because it is easily available but I expect to service the system at least once every summer.
However
I have not tried the R12 replacements like duracool, F12 and such. I tried the Freeze 12 when it was available and was unimpressed.
Anybody have experience with those I would love to hear about it. I used 414B "hotshot" in my former B van and still use it in my Shadow. The van came with R12, the shadow being a 94 was a ba$tard configuration from Chrysler even when new. The system was designed for R12 but for the final year they switched to 134A and I remember even when new it went back to the dealership several times under warranty claims because the A/C never worked right. My dad had an A/C savvy friend put R12 in it just after the warranty was over when R12 was still mostly readily available at the time. In 2004 we switched to 414B and it ran just the same as an R12 system. 414B was phased out a couple years ago since its still more damaging to the atmosphere. I have not tried the successor to hotshot yet since I still have several pounds of 414B in stock.
[Re: DaytonaTurbo]
#2515418
06/30/18 06:16 PM
06/30/18 06:16 PM
Posts: 8,350 fredericksburg,va
cudaman1969
fredericksburg,va
Here we have to watch out for some of the top-ups guys have done using that junk from the store. Because the retail sale of refrigerant in canisters under 22lbs is prohibited the stuff you buy at walmart is hydrocarbon based, usually propane/butane or something similar, which does work as a refridgerant in systems designed for it (not automotive). Canada has, I think, R15, they don't sell 134A, read that somewhere. Maybe one can bring down some when coming to Carlisle. We use R134A here. R12 is extinct. Legislation in place to phase down production limits of R134A to something like .5% of current levels by 2020 and replace it with R1234YF which is apparently what new vehicles are coming with. Right now R134A is a few bucks a pound but the R1234YF is in short supply and going for 50-75 a pound. Soon the R134A will start jumping up in price. We're not allowed to import the small cans of R134A either, yet nothing stops me from diving across the border and doing it on US soil. Well from what you said above about WallMart stuff thats probably why my van doesn't get very cool. How do you tell if it's the good stuff? The cans said 134A but... Should I find someone with a big cylinder?
