Page 1 of 3 1 2 3
A/C with R12 still serviceable? #2514433
06/28/18 01:46 PM
06/28/18 01:46 PM
The Historic Hudson Valley
MONC Offline OP
MONC  Offline OP
Can older A/C systems using R12 still be serviced, or does it have to be converted to R134a?
Re: A/C with R12 still serviceable? [Re: MONC] #2514450
06/28/18 02:01 PM
06/28/18 02:01 PM
Plymouth, MI
HotRod20 Offline
HotRod20  Offline
Plymouth, MI
There is no law that states an existing system "has to be" converted to R 134 a if a system using R-12 is functioning properly.
If it needs recharging due to a leak,and you have a source for the R -12 then consider getting it fixed.
Many technicians will try to sell you retrofit kits,but if your system is low on charge,it may only need an o ring or tightening of a fitting. Have a reputable garage leak check the system and find out an action plan for a repair.
R -12 systems in good working order will cool down much faster than 134a systems.
Beware though, that the cost of any remaining R-12 refrigerant on earth is going to be very expensive, that's why many car guys retrofit to the newer R-134a systems. Hope that helps smile
HR 20
Re: A/C with R12 still serviceable? [Re: HotRod20] #2514484
06/28/18 03:00 PM
06/28/18 03:00 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
iagree with all of the above.
Another thing is you have to be certified in a/c repair to buy R-12 if you are thinking of doing the repair yourself. Unless you know someone.... wink
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: A/C with R12 still serviceable? [Re: MONC] #2514485
06/28/18 03:05 PM
06/28/18 03:05 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Lots of places wont touch R12 because they dont have the machines for it anymore.I know the last shop I was at had R!2 and we were only like 1 of 30 or so places that had it.Let alone most dont have R12 to recharge it.We were getting 50 bucks a pound for it which was cheap.Changing to 134 isnt very hard.Usually just the conversion kit and a reciever.dryer.Did quite a few at work and almost all lasted and cooled decent.oh yeah 134 only uses IIRC 85 % of 12.You can pick up 1 pound cans at times.Just be careful we had sysyems at work that identifier said had benzyne,butane etv in it.Rocky
Chrysler Firepower
Re: A/C with R12 still serviceable? [Re: MONC] #2514549
06/28/18 05:38 PM
06/28/18 05:38 PM
MONC Offline OP
MONC  Offline OP
Thanks for the insights guys very helpful.
I am going to see if my regular mechanic can at least leak check the system.
I can get some R12, but not sure if my mechanic has a machines for it.
Hard to find restoration places that do it as well...
Mopar
Or
No
Car
Re: A/C with R12 still serviceable? [Re: MONC] #2514555
06/28/18 05:44 PM
06/28/18 05:44 PM
Valencia, España
NachoRT74 Online content
NachoRT74  Online Content
Valencia, España
I don't get why you say about "diff machines" between R12 and R134... the only diff is the niple port and there are adapters for that.
At least locally, any A/C shop is able to work on any refrigerant without diff machines really
Re: A/C with R12 still serviceable? [Re: MONC] #2514557
06/28/18 05:56 PM
06/28/18 05:56 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Its the oil in the R12 compared to the oil in 134A screw up the machines
Re: A/C with R12 still serviceable? [Re: MONC] #2514559
06/28/18 06:07 PM
06/28/18 06:07 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Canada has, I think, R15, they don't sell 134A, read that somewhere. Maybe one can bring down some when coming to Carlisle.
Re: A/C with R12 still serviceable? [Re: therocks] #2514560
06/28/18 06:09 PM
06/28/18 06:09 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You don't need a "machine" to service A/C systems, the machine just makes it easier.
A gauge set and vacuum pump are all that's needed.
https://www.amazon.com/Goetland-Diagnost...YT1H6Z9B1HSS7AS
Re: A/C with R12 still serviceable? [Re: NachoRT74] #2514562
06/28/18 06:17 PM
06/28/18 06:17 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
things work different up here.
It is illegal to vent freon to the atmosphere. It must be recovered and recycled. If you cross contaminate your R12 with R134, or vice versa, then you have an expensive waste product to dispose of.
Don't be the exception.
Re: A/C with R12 still serviceable? [Re: John_Kunkel] #2514563
06/28/18 06:17 PM
06/28/18 06:17 PM
Buford, GA
Buford, GA
Come on, John. You're not releasing freon into the atmosphere, are you? wink biggrin
Tim
'71 Charger 383/727
Re: A/C with R12 still serviceable? [Re: I_bleed_MOPAR] #2514582
06/28/18 07:46 PM
06/28/18 07:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
No, I have both an R-12 and R-134 machine but I'm not the subject, the OP want's to "service" a system with no mention of the system's status. If it's totally flat or just low, service can be performed with minimal equipment and no harm to the ozone layer.
Re: A/C with R12 still serviceable? [Re: John_Kunkel] #2514613
06/28/18 08:41 PM
06/28/18 08:41 PM
Buford, GA
Buford, GA
Easy there, big guy. Only kidding. blush
Tim
'71 Charger 383/727
Re: A/C with R12 still serviceable? [Re: cudaman1969] #2514620
06/28/18 08:47 PM
06/28/18 08:47 PM
5thAve Offline
5thAve  Offline
Canada has R134 but it's harder for the average shmoe to get.
Re: A/C with R12 still serviceable? [Re: John_Kunkel] #2514654
06/28/18 10:02 PM
06/28/18 10:02 PM
MONC Offline OP
MONC  Offline OP
The original system was rebuilt, but it is not blowing cold. Cool at best...
Mopar
Or
No
Car
Re: A/C with R12 still serviceable? [Re: MONC] #2515291
06/30/18 02:30 PM
06/30/18 02:30 PM
IMGTX Offline
IMGTX  Offline
I've done lot of R134a conversions. They really aren't that good. Here are a few facts to ponder.
1. R12 is a better refrigerant and operates at lower pressures. You will never get an R12 system to be as cold as it should be by using R134a. Partly because of the poorer refrigerant properties and partly because the expansion valves/orifice tubes for R12 systems are not design for the proper pressures to operate R134a. You may be able to get a different orifice tube but the expansion valves used in Mopars would have to be tuned to the R134a. I don't know of anyone who sells a replacement that is properly tuned for R134a.
2. Converting an R12 system to R134a is a temporary fix since the R12 systems are lower pressure designs. The higher operating pressures of R134a will eventually cause leaks. Even with new hoses the systems will not last as long before a leak will occur. Part of this is because R134a systems typically have 2 pressure sensors (1 low and 1 high) and a relief valve. Most R12 systems have 1 low pressure sensor only. At normal charging you are turning 800 to 2000 rpms which is not indicative to a normal driving experience. Imagine stomping on the throttle to pass somebody with the A/C on. Modern cars will either electronically detect a full throttle and temporarily cut off the compressor or when the pressure spikes the High pressure switch cuts off the compressor for you. An R12 system will simply spike to over 300PSI on the high side without much trouble. Easily over 100psi more than R12 will do and was deigned for. It can only take that so long before it leaks.
3. R134a requires approx 80% of the volume of R12. Keep this in mind while charging. Overcharging will result in very high pressures. In modern R134a systems there is usually a high pressure vent to release excess pressure. Those are not usually on R12 systems.
4. R12 uses mineral oil R134 uses ester or PAG oil. Two factors to consider about the oil. Compatibility with the refrigerant and compatibility with the other oils in a conversion. The oil is carried by the refrigerant through the system to lubricate it. R134a will not carry mineral oil so you can't use it or compressor failure will occur. However Mineral oil is not compatible with PAG oil. In a conversion you must either flush everything out and replace the compressor to remove the mineral oil or use simply use ester oil. The mineral oil will just find a low spot and settle there but as long as you do not add PAG oil it won't hurt anything. This is important because an inexperienced person/shop may add PAG since most of the OEM's use it and then you have problems.
In my opinion the two best choices are buy some overpriced R12 on craigslist or do a legitimate conversion. A legitimate conversion would be something like a Vintage air system with a newer style (high pressure compatible) compressor and proper pressure sensors.
I still do R134a conversions even on my cars because it is easily available but I expect to service the system at least once every summer.
However
I have not tried the R12 replacements like duracool, F12 and such. I tried the Freeze 12 when it was available and was unimpressed.
Anybody have experience with those I would love to hear about it.
Re: A/C with R12 still serviceable? [Re: IMGTX] #2515344
06/30/18 05:04 PM
06/30/18 05:04 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
And remember, the R-134 molecule is smaller than the R-12 so, if there are minute holes in a hose or component, the R-134 will leak out when the R-12 won't.
Re: A/C with R12 still serviceable? [Re: cudaman1969] #2515350
06/30/18 05:26 PM
06/30/18 05:26 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Here we have to watch out for some of the top-ups guys have done using that junk from the store. Because the retail sale of refrigerant in canisters under 22lbs is prohibited the stuff you buy at walmart is hydrocarbon based, usually propane/butane or something similar, which does work as a refridgerant in systems designed for it (not automotive).
We use R134A here. R12 is extinct. Legislation in place to phase down production limits of R134A to something like .5% of current levels by 2020 and replace it with R1234YF which is apparently what new vehicles are coming with. Right now R134A is a few bucks a pound but the R1234YF is in short supply and going for 50-75 a pound. Soon the R134A will start jumping up in price. We're not allowed to import the small cans of R134A either, yet nothing stops me from diving across the border and doing it on US soil.
Re: A/C with R12 still serviceable? [Re: IMGTX] #2515401
06/30/18 06:00 PM
06/30/18 06:00 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
However
I used 414B "hotshot" in my former B van and still use it in my Shadow. The van came with R12, the shadow being a 94 was a ba$tard configuration from Chrysler even when new. The system was designed for R12 but for the final year they switched to 134A and I remember even when new it went back to the dealership several times under warranty claims because the A/C never worked right. My dad had an A/C savvy friend put R12 in it just after the warranty was over when R12 was still mostly readily available at the time.
In 2004 we switched to 414B and it ran just the same as an R12 system. 414B was phased out a couple years ago since its still more damaging to the atmosphere. I have not tried the successor to hotshot yet since I still have several pounds of 414B in stock.
Re: A/C with R12 still serviceable? [Re: DaytonaTurbo] #2515418
06/30/18 06:16 PM
06/30/18 06:16 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Well from what you said above about WallMart stuff thats probably why my van doesn't get very cool. How do you tell if it's the good stuff? The cans said 134A but... Should I find someone with a big cylinder?
Page 1 of 3 1 2 3
