E body ? #251530
03/12/09 10:47 AM
03/12/09 10:47 AM
Home of the Bluegrass
MoparJunkie Offline OP
I can't find info on rear sway bar links for my 73 Cuda.... Are the links the same as the front part numbers?????
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: E body ? [Re: MoparJunkie] #251531
03/12/09 11:56 AM
03/12/09 11:56 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
That's a good question. I also have a rear swaybar on my 73 Challenger. I have some extra poly endlink bushings that I am going to use. I may just use a long bolt, some washers and metal sleeves.
I havn't found anyone who makes the rubber bushing that goes from the bar to the frame either. I may have to re-use the origonals.
Re: E body ? [Re: burdar] #251532
03/12/09 12:07 PM
03/12/09 12:07 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
Someone on this board has repoped them, I'll post when I remeber or perhaps they will show.
Re: E body ? [Re: MoparJunkie] #251533
03/12/09 12:15 PM
03/12/09 12:15 PM
BC
70RT27N Offline
70RT27N  Offline
BC
Not the same as the front. Here are the correct 70-74 E body rear links...
http://billrolikenterprises.com/proddetail.asp?prod=2535188-P
Re: E body ? [Re: 70RT27N] #251534
03/12/09 12:19 PM
03/12/09 12:19 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Is anyone making the bar to frame rail bushings?
Re: E body ? [Re: burdar] #251535
03/12/09 01:02 PM
03/12/09 01:02 PM
BC
70RT27N Offline
70RT27N  Offline
BC
I don't think anyone is reproducing the factory frame rail bushings. One option is to go with the
OEM 'style' set up that Firm Feel makes:
http://www.firmfeel.com/swaybars_e.htm
Re: E body ? [Re: 70RT27N] #251536
03/12/09 08:57 PM
03/12/09 08:57 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
I made mine up like the firm feel ones long ago..
use a gm front brackets and bushings, weld in studs and you are good to go...as for the links?..I thought they are still available from mopar...they are different...i'm sure u can make something out of regular links and cut the bolt down to size...
