Re: '06 2.7 V6 Stratus Violent Bucking
[Re: Powerflow]
#2515001
06/29/18 06:00 PM
06/29/18 06:00 PM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
On a Stratus with a 2.4 litre. I had the cam sensors go bad. They bucked like crazy, and you could barely give it any gas. Less than a 1/4" . I did drive both of them home , about 10 miles. It just took awhile.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
UPDATE Re: '06 2.7 V6 Stratus Violent Bucking
[Re: Powerflow]
#2515948
07/01/18 05:25 PM
07/01/18 05:25 PM
Posts: 1,295 New Jersey
Powerflow
New Jersey
UPDATE: I bought a new cam sensor and cleared the codes (P0344 and a secondary code of P0304). I then wanted to move it to the shade to swap it out(it's about 100 degrees here now). Even though the car idled fine after the hellish ride home a few days ago, now it won't start. Does the computer need to see a signal from the cam sensor for the engine to run? I also notice that the engine had a little 'cough' while cranking, that I'm thinking is caused by the bad cam sensor. My big concern is that it somehow jumped timing due to all the bucking it went through. Any ideas appreciated. Thanks for your help.
Harold
Re: UPDATE Re: '06 2.7 V6 Stratus Violent Bucking
[Re: Powerflow]
#2516224
07/02/18 02:05 AM
07/02/18 02:05 AM
Posts: 8,395 Highland, MI.
Sunroofcuda
Highland, MI.
I was on the edge of my seat - I WAS!!!
Glad it worked out - I hate late model stuff like this that I can't even work on. Give me a distributor, coil, & carb car ANY DAY!
[Re: sportfury70]
#2516495
07/02/18 05:32 PM
07/02/18 05:32 PM
Posts: 4,996 North Pole,New York
formula_s
North Pole,New York
05 neon I had had similar symptoms & it was a bad cam sensor I have replaced 3 of them on my '05. The Borg Warner and Autozone brand last about 15k miles each.
