Converter diameter #2514191
06/27/18 11:30 PM
06/27/18 11:30 PM
TN
RRandP92 Offline OP
RRandP92  Offline OP
TN
I have a unknown converter that measures 10.5" in overall diameter. Could this be a 9 or 9.5" converter? The known 8" is 9.5" overall diameter. Maybe no way to confirm unless cut open?
Re: Converter diameter [Re: RRandP92] #2514194
06/27/18 11:34 PM
06/27/18 11:34 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
10.5 OD should be a 9.5” or 10” unit.
Re: Converter diameter [Re: RRandP92] #2514286
06/28/18 07:47 AM
06/28/18 07:47 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Is there a serial number on it? That might help.
Re: Converter diameter [Re: ProSport] #2514577
06/28/18 07:27 PM
06/28/18 07:27 PM
TN
RRandP92 Offline OP
RRandP92  Offline OP
TN
There are couple numbers stamped on it 10490R, 7174, 1420.
Re: Converter diameter [Re: RRandP92] #2514588
06/28/18 07:58 PM
06/28/18 07:58 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
From my personal experience, some converter maker's diameter claims and any semblance to a tape measure are a total mystery. confused
Re: Converter diameter [Re: John_Kunkel] #2514966
06/29/18 04:19 PM
06/29/18 04:19 PM
TN
RRandP92 Offline OP
RRandP92  Offline OP
TN
Never paid much attention to it until this one that I didn't have labeled. I sent the 8" off to be redone but am now questioning what this other unit that measures 10.5" actually is. Guess ill be getting it cut open!
Re: Converter diameter [Re: John_Kunkel] #2514987
06/29/18 04:52 PM
06/29/18 04:52 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
iagree shruggy
