Two questions in one. Alternators?
#2513706
06/26/18 11:12 PM
06/26/18 11:12 PM
fullmetaljacket
First and foremost, are rebuilt alternators that have sat on a shelf noisy when first fired up? In other words, are they supposed to sound intimately ratty like something is slightly rubbing? Would it/could it be the brushes and stator breaking in or is it something to worry about?
Second: Are civilian cars with options such as AC, light group, radio, heater, rear window defogger, 3 speed wipers, Windshield washer pump, cigarette lighter, ignition key reminder come from the factory with a 60 amp alternator or is it a 35 amp unit?
Thank you in advance.
Re: Two questions in one. Alternators?
[Re: fullmetaljacket]
#2513735
06/27/18 12:29 AM
06/27/18 12:29 AM
Posts: 43,163 Bend,OR USA
Cab_Burge
First question answer is no,I never had a rebuilt alternator make noise I've rebuilt some of my own with new brushes, bearings and diode and never heard any noises any OEM Mopar alternator other than from a worn out one with a bad rear bushing On the second question what year and brand car?
#2513907
06/27/18 02:05 PM
06/27/18 02:05 PM
RapidRobert
Second: Are civilian cars with options such as AC, light group, radio, heater, rear window defogger, 3 speed wipers, Windshield washer pump, cigarette lighter, ignition key reminder come from the factory with a 60 amp alternator or is it a 35 amp unit? Thank you in advance. I would ASSuME that it'd be the highest amper available for that year/app tho if you have to get another one (& it sounds like you will) I would get the highest amper unit available that is just below the 78 amper available for an 85 M body (that one has a thin stator & needs slight fore/aft adjustments, no big deal just sayin & MAY need a swing arm change, the chebby $10 chrome one iirc) & the 70's ones have (2) field terminals & you can easily just ground one of em to the nearby alt case if needed for your app. There was something (iirc) about higher amp alts not charging as well at lower RPM's (no info on that, if true or false, just sayin). Even more important I would clean ALL terminals/connections including ground paths & a braided strap from eng to firewall is a good addition. there are 2 different alt pulley dia's & I'd use the smaller one (I forget the dimentions). 2&3/4" on the smallest iirc.
#2514545
06/28/18 05:35 PM
06/28/18 05:35 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The letters do match the VIN, if you understand where they came from.
V=Valiant, the first Plymouth A body. My 65 Cuda starts out with a V. L=Lancer, the first Dodge A body.
They follow on from there
#2515140
06/30/18 12:08 AM
06/30/18 12:08 AM
Supercuda
About to go away
About to go away
up yours
Your Dart is an L not a V, it's listed in the parts books, image from the 74 parts book, don't have a 73
#2515225
06/30/18 11:03 AM
06/30/18 11:03 AM
Supercuda
About to go away
About to go away
up yours
You said your VIN started with LL? Where is this V coming from?
Below chart is right out of the 73 Dodge FSM
