Re: oil ring gap
[Re: bonefish]
#2514254
06/28/18 01:28 AM
06/28/18 01:28 AM
RapidRobert
the eng is 40 over & the rings are 60 over? From what I understand you dont want rings more than 10 over the bore dia for file fit cuz they end up slightly out of round (compression rings, not sure about oil rings). I would check on this. file fit rings for a given bore are 5 over
Re: oil ring gap
[Re: RapidRobert]
#2514357
06/28/18 11:43 AM
06/28/18 11:43 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
the eng is 40 over & the rings are 60 over? From what I understand you dont want rings more than 10 over the bore dia for file fit cuz they end up slightly out of round (compression rings, not sure about oil rings). I would check on this. file fit rings for a given bore are 5 over SORRY i ment to say 4.360
