COMP TEST RESULTS ON 360
#2510108
06/18/18 07:29 PM
06/18/18 07:29 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I recently bought a Duster with a 73 360 motor,edelbrock intake, edelbrock csrb, headers, it was running really poor when i fired it up, turns out it had 30 degrees initial timing, so i backed it off to 16, stripped the edelbrock carb, cleaned, checked and replaced a few gaskets and it ran a lot better. When i put my vac gauge on it, it read around 8 inches vac ? Driving it, it feels soft down low untill it gets rolling, it's got a 7-1/4 axle that feels pretty high geared and it feels like a stock converter but i thought it would be more punchy so i did a comp test today. Engine was cold, accelerator fully open, dry then wet. Opinions please. 2 4 6 8 1 3 5 7 Dry 120 115 145 120 120 125 120 100 Wet 135 125 150 130 135 130 135 110
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
Re: COMP TEST RESULTS ON 360
[Re: deaks]
#2510120
06/18/18 08:10 PM
06/18/18 08:10 PM
deaks
robin hood country
If the lobe is flat then why cant i here it and it idles fairly steady,needle on vac gauge was jumping around 1 inch. Mick
[Re: deaks]
#2510126
06/18/18 08:20 PM
06/18/18 08:20 PM
RapidRobert
#7 rings/seal may be a bit more worn than the others. How wild is the cam? what springs are in the dist? what is the total now & what RPM does it max at? Lets figure out the low vac #
[Re: deaks]
#2510139
06/18/18 08:53 PM
06/18/18 08:53 PM
deaks
robin hood country
Motor info is unknown to me, i bought the car from west VA and got very few specifics, 16 initial, 36 max mechanical now.Not sure what RPM no tach, seems better once it gets going.
[Re: deaks]
#2510148
06/18/18 08:59 PM
06/18/18 08:59 PM
RapidRobert
36 is a good ballpark total (initial+slots) & I'm assuming this is with the can plugged. 16 is OK for a stock cam.
[Re: deaks]
#2510150
06/18/18 09:07 PM
06/18/18 09:07 PM
deaks
robin hood country
Yes can plugged. I've been doing other stuff to the car and ideally should be finishing my 470 for my Dart but [censored] like this keeps getting in the way.
[Re: deaks]
#2510225
06/18/18 11:48 PM
06/18/18 11:48 PM
RapidRobert
Me too, holler with any new developments.
[Re: deaks]
#2510284
06/19/18 05:59 AM
06/19/18 05:59 AM
deaks
robin hood country
I was toying with the idea of advancing the cam because of the low comp and tall gears.
[Re: deaks]
#2510340
06/19/18 12:04 PM
06/19/18 12:04 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Cam is probably bigger than optimum.
[Re: deaks]
#2510387
06/19/18 02:15 PM
06/19/18 02:15 PM
deaks
robin hood country
Do you think advancing the cam might help Dwayne ? also what's your thoughts on the seven cylinder, i dont think it's cam wear but could it be a valve sticking ?
[Re: deaks]
#2510769
06/20/18 12:42 PM
06/20/18 12:42 PM
deaks
robin hood country
I'm going to flush the engine, put fresh oil and a filter on it first. Mick
[Re: deaks]
#2511358
06/21/18 03:28 PM
06/21/18 03:28 PM
deaks
robin hood country
No 7 was right under the header, so fairly hard to get the fitting on, anyway i thought i'll do that cylinder again today and got 110 dry, 120 wet ? I picked a fresh set of plugs up today.
[Re: deaks]
#2511511
06/21/18 10:24 PM
06/21/18 10:24 PM
RapidRobert
Motor info is unknown to me, how wild/mild is the cam? what does it idle at?
