Measure once cut twice
#251004
03/11/09 07:24 PM
03/11/09 07:24 PM
Posts: 199 SE Wisconsin
49wayfarer
SE Wisconsin
Had the bare engine block set on blocks to figure out where I wanted it, didn't have the heads on, and I don't have headers yet either. Started on my firewall, and as you can see in the pics, I effed up. I had to recess the wall, got it deep enough, but not wide enough. Luckily before I welded in the firewall, I placed the heads on, and realinzed the covers won't fit. Then, I put the dash in and as you can see, the steering coulmn comes thru the wall right on the seam. Now I'm wondering if I'm going to have enough room on the drivers side for the steering linkage and the exhaust. Its a Dakota clip, and planned on centering the 383. Think I might have to move it to the left 1-2". ![](/ubbthreads/images/graemlins/bawling.gif)
Re: Measure once cut twice
[Re: 49wayfarer]
#251006
03/11/09 09:10 PM
03/11/09 09:10 PM
moparpollack
Lil Herman
Lil Herman
85086
Live and learn. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: 49wayfarer]
#251007
03/11/09 09:11 PM
03/11/09 09:11 PM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
I almost always off set the engine, the factory did, so why not, when you have exhaust,starter and steering all fighting for that same area, it makes sense to move it over. and moving the fire wall back to have room to get the valve covers or the exhaust off make sense too. if you have to move the seat back an inch or two to be comfortable then thats not to bad either. ![](/ubbthreads/images/graemlins/thumbs.gif) Ron...
[Re: Mopar Ron]
#251008
03/11/09 09:18 PM
03/11/09 09:18 PM
Posts: 34,963 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Little late but, a nice trick for making a nice looking recess is to ..
Buy a radio flyer wagon and cut it half or so Nice round rolled edges, Making mistakes kind of bites but, it is how you learn to not make them
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: 49wayfarer]
#251012
03/12/09 10:53 PM
03/12/09 10:53 PM
Posts: 10,653 Freeport IL USA
poorboy
Freeport IL USA
One of the street rods I've seen recently had spacers made to set the manifolds out away from the motor, then they ran the exhaust outside of the frame. Wasn't a big block, but it was Mopar and on a Dakota frame. Think the spacers set the manifolds about 2" - 2 1/2" out, simple machined tubes that had bolts go through the manifold, the spacers, and into the heads, two sets of gaskets.
Also wondering if you use a short tilt steering column, can you run the bottom closer to the floor pan and run the column under the exhaust? Stands the column more up right, but the with the tilt and a longer column mount at the dash can make a lot more room under the hood, you just need the steering wheel to end up in the correct position to drive it comfortably. Gene
[Re: poorboy]
#251013
03/13/09 11:25 AM
03/13/09 11:25 AM
Posts: 3,533 Indiana
Fury Fan
Indiana
Offsetting the engine/trans also compensates for weight of the driver.
If you do the 'remote-mount' manifold thing, keep in mind you'll have more movement in your pipes as the engine twists - plan accordingly.
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: 49wayfarer]
#251018
03/14/09 05:07 PM
03/14/09 05:07 PM
Mopar Ron
I think I would move the column over a little more to the drivers side if it were mine, are you planing on running the stock column and wheel? or go with a tilt column? if you go with a tilt column you could angle the column to come through the firewall a little lower instead of next to the valve cover or exhaust manifold and still be comforable by tilting it down ![](/ubbthreads/images/graemlins/shruggy.gif) Ron...
[Re: 49wayfarer]
#251020
03/14/09 10:38 PM
03/14/09 10:38 PM
Posts: 8,089 Sorrento, BC, Canada
4speeds4me
Man, it's too bad you're having such a hassle with it. I got lucky with my 56...used the stock mounts and bolted them to the LA block. I feel for you guys with the older ones, and I'm paying CLOSE attention, as the 37 gets closer and closer as the weather warms up! ![](/ubbthreads/images/graemlins/biggrin.gif)
2 Demons...no, not my kids!
