Page 4 of 4 1 2 3 4
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: ademon] #2406148
11/20/17 12:08 AM
11/20/17 12:08 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Been 9s with 3.55s with a 493 and g3 hemi
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: ProSport] #2406620
11/21/17 01:10 AM
11/21/17 01:10 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Originally Posted By ProSport
This thread made me decide to go with 3.23 gears in my Duster awhile back, I finally got to drive it to the track this year and it went 10.69 at 124.75 with a 1.51 60 foot. I'm extremely happy with it.
500" low deck, 10to1 compression, small 557 lift purpleshaft cam, Eddy cnc ported MW heads, 950 carb, small B-body 1.75" headers, mechanical water pump and fan, never runs hot.
727 with Dynamic 9.5" converter that needs tightened(17.5% slip), 8.75 rearend with factory leaf springs with one new leaf added to each spring, Rancho adjustable rear shocks, 275/60 drag radial.
Launch at 2000, shift at 5800, trap at 5800.
I really like my 9.5 Dynamic converter I run. How tall are the rear tires you run with the 3.23's at the track Bob ? Ron
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: ademon] #2406684
11/21/17 09:04 AM
11/21/17 09:04 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
28" tall, 275/60 drag radial.
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: sixpackgut] #2407309
11/22/17 12:19 PM
11/22/17 12:19 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
That is an impressive combo
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: ademon] #2509070
06/15/18 07:40 PM
06/15/18 07:40 PM
Minnesota
skep419 Offline
skep419  Offline
Minnesota
coffee
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: ademon] #2509082
06/15/18 08:18 PM
06/15/18 08:18 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
1st pass since freshen up, 11.33 @ 121 ,1750 DA, have not done any tuning yet, probably wont be able to car has no roll bar, it is my daily driver.
1968 Dodge Charger,4100lb with me Street car, COLD AC, 512 low deck, 440 source stroker kit
9.7 compression, Hughes hydro roller cam 255,258@.050,
.608/.613 lift with 1.6 T&D rockers with B3 geometry correction, Indy 400-2 intake
that I ported to max wedge,1050AN 4150 pieced together carb,
440 source Super stealth heads max wedge size that I ported flow 330 @ .700, with Farrea valves,
Comp Beehive springs, 1 7/8 headers, full 3" magnaflow exhaust & tail pipes.
A518 overdrive trans,4000stall lock up converter, alum driveshaft,
3.54 Strange Dana 60, Caltrac bars & split mono springs with sliders.
325-50-15 MT drag radials street. drove 80 mph, 80 mile round trip to the track, dropped the air pressure in the rear tires, turned of the AC & made a easy , short shifted pass, next pass went up against the converter 2500 & it blew the tires off, got to hot outside for me, drove home in the ac. smile
I WAS ASLEEP
[video:youtube]https://youtu.be/qusZAXyw9yc[/video]
2nd pass
[video:youtube]https://youtu.be/UCgH0_V0dQY[/video]
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: CSK] #2509150
06/15/18 10:47 PM
06/15/18 10:47 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I posted this elewhere, but we got a new best of 10.69 @ 128 with 150 shot last Saturday. DA was well over 4000 ft. and it was at least 85°! May put the 200 jets in for tomorrow night... panic or drive
'63 Dodge 330
11.19 @ 121 mph
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: ademon] #2509181
06/16/18 12:12 AM
06/16/18 12:12 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Nice runs CSK and GY3!
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: ProSport] #2902070
03/23/21 03:01 PM
03/23/21 03:01 PM
Minnesota
skep419 Offline
skep419  Offline
Minnesota
chargerwork
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: GY3] #2902160
03/23/21 07:15 PM
03/23/21 07:15 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I guess this was a while back! We went 10.01 @ 133 last Fall.
'63 Dodge 330
11.19 @ 121 mph
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: GY3] #2902307
03/24/21 10:31 AM
03/24/21 10:31 AM
an8sec70cuda Offline
I've been 8.97 at 152.5 mph w/ 3.54 gears at 3900 lbs.
I've been a good bit quicker since then, but I've only been going to 1/8 mile tracks. Hopefully get a new 1/4 mile timeslip real soon.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: an8sec70cuda] #2902388
03/24/21 02:03 PM
03/24/21 02:03 PM
MD.
V
vttm Offline
vttm  Offline
V
MD.
What size tire you running Chip?
Re: Your low ET's 11's 10's with 3.23/3.55 gear [Re: vttm] #2902393
03/24/21 02:15 PM
03/24/21 02:15 PM
295-65 drag radial...about 30" tall.
CHIP
Page 4 of 4 1 2 3 4
