Power steering pump questions #2508903
06/15/18 02:11 PM
06/15/18 02:11 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
I'd like to know if a power steering pump is mechanically the same whether it came on a slant six, small block or big block. I know the brackets are different. Just wondering about the internals and whether or not a specific pulley is required for each size engine. I have a Federal pump form a slant six 69 Dart and was wondering if I could use it on a 440 if I got the right brackets and if necessary, a different pulley.
Re: Power steering pump questions [Re: 1970RT] #2508921
06/15/18 02:41 PM
06/15/18 02:41 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I read that the \ 6 had the pressure restricted more than V8s, which can be a good thing.
Re: Power steering pump questions [Re: 1970RT] #2508961
06/15/18 03:30 PM
06/15/18 03:30 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The FSM has the specs, pressure, flow are all different.
Don't be the exception.
Re: Power steering pump questions [Re: Supercuda] #2509125
06/15/18 10:04 PM
06/15/18 10:04 PM
IN
ahy Offline
ahy  Offline
IN
There were 3 manufacturers for pumps in general. Federal is one, Saginaw another and I forget the 3'rd. In general the Saginaw is considered the best and re-popped today new.
No harm in trying the Federal... but personally I would not spend any money on brackets for it. I would look for a Saginaw. May be available reman with minimal core charge (or used or new repop).
