Re: Indy Aluminum Timing Chain Cover
[Re: Dduster]
#2508015
06/13/18 05:16 PM
06/13/18 05:16 PM
Posts: 20,175 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I love mine and it’s been on several different engines that ran mid 8 - to high 8 second passes but I can’t help you out about vacuum pump use because I never ran one. They are made pretty heavy duty or at least they used to be
[Re: AndyF]
#2508103
06/13/18 07:52 PM
06/13/18 07:52 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
I use a billet timing cover when I want something that seals tight, fits a standard damper, accepts a cam button, and fits under a water pump. AR Engineering makes a really great one- Mancini Racing sells them. The one I've got looks too good to hide behind the water pump and pulleys.
