intake for 360 with magnum heads factory a/c on 70 charger #2506704
06/10/18 05:39 PM
06/10/18 05:39 PM
texas
magnum440 Offline OP
texas
hello looking for an intake that will work on a 360 with magnum heads,,the eledebrock air gap the thermostat housing is to the right of engine...looks like compressor will hit it...theres a procomp copy that looks like the thermostat is more like stock,but not sure it will work,trying to put all factory brackets back on it...also not sure the throttle cable and kickdown will have to be modified or changed to aftermarket cables....any input would be appreciated...maybe someone has gone through this already,,but couldnt find anything in archives
Re: intake for 360 with magnum heads factory a/c on 70 charger [Re: magnum440] #2506707
06/10/18 05:40 PM
06/10/18 05:40 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
If you redrill thee intake bolt holes in the heads to the LA pattern than any LA intake will fit as well.
Don't be the exception.
Re: intake for 360 with magnum heads factory a/c on 70 charger [Re: magnum440] #2506743
06/10/18 07:19 PM
06/10/18 07:19 PM
birds eye pic of the procomp
Re: intake for 360 with magnum heads factory a/c on 70 charger [Re: magnum440] #2506977
06/11/18 11:06 AM
06/11/18 11:06 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
There are threads on this issue here. As mentioned, there are have been drilling guides fabbed up to redrill and tap the heads for the LA angle intake bolts. Also the Engine Quest magnum heads are obtainable predrilled for the LA intake (CH318LA) (Hughes sells them under their own brand).
There are a lot of Magnums out there running LA intakes.
I have the EQ heads and have run the LD4 as well as the Performer intakes on it.
Craig
