Where to get street hemi orange engine paint #2506543
06/10/18 12:11 PM
06/10/18 12:11 PM
Motown, Mi
P
PAULS_340 Offline OP
P
Motown, Mi
Engine's due back any day now [read, two months ago], and it's getting primed and painted Street Hemi Orange. PPG doesn't have that color, so who might mix a pint of the correct color? Or do I use spray-cans? Thx
Still looking for LM29H1B415501, '71 Demon 340
Re: Where to get street hemi orange engine paint [Re: PAULS_340] #2506548
06/10/18 12:17 PM
06/10/18 12:17 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
There are two Hemi orange colors, early, and late. Wedge engines are a different orange also, as did the air filter lid. If you want the correct paint, Frank Baldason has it in PPG, but it's $$$$.
Re: Where to get street hemi orange engine paint [Re: 71birdJ68] #2506553
06/10/18 12:33 PM
06/10/18 12:33 PM
Motown, Mi
P
P
Motown, Mi
Roseville Chrysler has spray cans for $14.
Re: Where to get street hemi orange engine paint [Re: PAULS_340] #2506559
06/10/18 12:52 PM
06/10/18 12:52 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
sixpackfrank@aol.com
Re: Where to get street hemi orange engine paint [Re: PAULS_340] #2506571
06/10/18 01:20 PM
06/10/18 01:20 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
That's nice.
If you want to rattle can it that's fine but that is not the right way and in the long run you will be pissed you wasted $52 on crappy paint.
Call Frank as the others have told you and you will be happier in the long run
Re: Where to get street hemi orange engine paint [Re: Morty426] #2506627
06/10/18 03:13 PM
06/10/18 03:13 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Bullsquirt...
Got over 20 years and counting on 'crappy' rattle-can spray...
Properly prepped, primed, and sprayed...
On a car that gets driven...
There ARE options...
Re: Where to get street hemi orange engine paint [Re: RSNOMO] #2506701
06/10/18 05:35 PM
06/10/18 05:35 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
But rattle can is not the right shade.
Re: Where to get street hemi orange engine paint [Re: 71birdJ68] #2506706
06/10/18 05:40 PM
06/10/18 05:40 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Right shade for what???
A world-class, OEM no-expense spared resto???
I used MP 'street hemi' orange when I sprayed my engine in 1993...
Dam sure adequate for my needs...
Which was longevity, first and foremost...
Holding-up real well...
Re: Where to get street hemi orange engine paint [Re: PAULS_340] #2506724
06/10/18 06:07 PM
06/10/18 06:07 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Painting an engine on a highly detailed build is the foundation for everything else, spend a few extra dollars and do it right and the other details are simple bolt ons. Go the cheap/fast route and have an issue or change your mind later to up the accuracy level you are shooting for and it's a MAJOR PIA to strip it all down and start over. I'm doing this exact thing for one of my customers right now, he decided to bring his car to a higher standard part way through his build and his current engine paint color/gloss level is way off.
So,
short cutting with a fresh engine build just doesn't make any sense IMO
.02
Re: Where to get street hemi orange engine paint [Re: RSNOMO] #2506733
06/10/18 06:42 PM
06/10/18 06:42 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
The man asked where to get it, and told him his options. If he wants to go the cheap route, then that's his choice, but if he wants it right, then now he knows about that also. I drive my car also, and my correct shade engine looks better than the rattle can engines.
Re: Where to get street hemi orange engine paint [Re: PAULS_340] #2506744
06/10/18 07:20 PM
06/10/18 07:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Body color EV2 without the metallic. Unless you have an original parked next to it, nobody will be able to tell the difference.
Re: Where to get street hemi orange engine paint [Re: PAULS_340] #2506759
06/10/18 07:51 PM
06/10/18 07:51 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Talk to Holgar. He has mixed engine colors to match unrestored cars/powertrains for various years
http://www.supercarrestorations.com/
Re: Where to get street hemi orange engine paint [Re: PAULS_340] #2506767
06/10/18 08:14 PM
06/10/18 08:14 PM
PA
Cudaful Offline
Cudaful  Offline
PA
Re: Where to get street hemi orange engine paint [Re: 71birdJ68] #2506801
06/10/18 10:15 PM
06/10/18 10:15 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
How many average folks out there do you think are gonna be able to tell the difference between your pricey 'correct' orange, and some orange out of a spray can???
And what is the definition of 'right'???
Or 'better'???
Haphazard OEM spray over an un-prepped surface???
How long do you think that will hold-up on a car that's driven???
Hint, not very long...
MY objective was simple, go one better than 'factory'...
Mission accomplished...
Re: Where to get street hemi orange engine paint [Re: ScottSmith_Harms] #2506813
06/10/18 10:51 PM
06/10/18 10:51 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Where do you get that?
If this was the resto forum I could see making that ASSumption.
While I haven't painted an engine in some time now, I used rattle can stuff on all my builds, none were resto types though. All of them held up fine.
The OP made zero statements as to the level of the build and your method is not resto type either, which was spray it on quick and dirty and probably wouldn't outlast a decent rattle can job.
Don't be the exception.
Re: Where to get street hemi orange engine paint [Re: PAULS_340] #2506840
06/10/18 11:38 PM
06/10/18 11:38 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Simple, he asked for a source that would mix a pint of the "correct" color code and I gave him one, "correct" doesn't add up to zero, it adds up to one.
Re: Where to get street hemi orange engine paint [Re: ScottSmith_Harms] #2506870
06/11/18 12:47 AM
06/11/18 12:47 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Scott is right, he said correct. That ain't gonna happen with cheap rattle can. I don't understand why you all are upset about this, the OP said correct.
Re: Where to get street hemi orange engine paint [Re: PAULS_340] #2506900
06/11/18 02:00 AM
06/11/18 02:00 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I don't know, looks like the original 47 year old factory paint held up pretty well on my original engine, I duplicated many details from it when building the one for my Duster. BTW, the difference in color is only due to lighting, they are a VERY close match using Frank Badelson's paint
Re: Where to get street hemi orange engine paint [Re: PAULS_340] #2506904
06/11/18 02:09 AM
06/11/18 02:09 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
How I prepped it was simple, SUPER clean metal using acetone and phosphoric acid wash to clean the iron. No primer, painted with a gun following Frank's instructions. Laid down nice and hasn't chipped or peeled in the least in 3 years.
Re: Where to get street hemi orange engine paint [Re: PAULS_340] #2507055
06/11/18 02:01 PM
06/11/18 02:01 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Totally Auto
2011 Drag Pak Challenger
