Technical Q about 1965 carbs and linkage brackets...
#2505769
06/07/18 11:34 PM
06/07/18 11:34 PM
Posts: 7,545 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
I'm switching carbs on my '65 Satellite 361 from 2bbl to 4bbl.
The bracket that holds the throttle cable and kick-down linkage needs to be a different "wider" geometry. The two carbs are different widths, so the "new" bracket has to be offset.
I'll surf around and research what's for sale off a 4bbl '65 Big Block.. go to a salvage yard, or I can even shop-fabricate some kind of extension plate... but I figured I'd ask you experts here...
Is there some easy solution to changing these brackets for different carbs? Cheers, - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Technical Q about 1965 carbs and linkage brackets...
[Re: 67SATisfaction]
#2505774
06/07/18 11:58 PM
06/07/18 11:58 PM
67SATisfaction
Albany, NY
Thank you, That's the type of solution I was hoping for.. - Art
#2505880
06/08/18 11:24 AM
06/08/18 11:24 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
When I bought my 65 it had the 361 2 bbl.Changed to Eddy and AFB.I just bent the bracket some and it worked for years.Now its 440 M1 and Dominator.I run the bracket that Mancini sells.A member Andy here makes them if I remember.Rocky
Chrysler Firepower
[Re: therocks]
#2509468
06/17/18 12:17 AM
06/17/18 12:17 AM
67SATisfaction
Albany, NY
When I bought my 65 it had the 361 2 bbl.Changed to Eddy and AFB.I just bent the bracket some and it worked for years. Thanks Rocky - that's basically what I ended up doing - looked at the aftermarket stuff and realized it's not a bolt-on deal with the throttle cable and kick down.. So I modified what I had on hand: Grabbed a little 1/8" steel plate a fabbed a short extension for the factory bracket... made a little extension to get the throttle cable to reach properly.. Got it done in time to test drive around the block, then take my boys out for burgers & ice cream.. made the final throttle adjustment in the parking lot.. Cheers, - Art
