Re: Battery in the trunk. Car doesnt shut off when switched off
[Re: '72CudaRacer]
#2504626
06/05/18 12:18 AM
06/05/18 12:18 AM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
The alternator wire needs to go all the way back to the battery and then a wire on the down side of the switch needs to run back to the harness. It's running off the alternator once it starts.
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
[Re: Charger446]
#2504731
06/05/18 10:24 AM
06/05/18 10:24 AM
Posts: 13,273 aZLiViN
J_BODY
aZLiViN
Only 1 of the field wires needs to go back to the switch. Example: cut blue wire at alt. Wire end from harness back to switch small pole A. Wire from small pole B back to the front and connects to ALT.
[Re: Charger446]
#2504737
06/05/18 10:30 AM
06/05/18 10:30 AM
Posts: 282 Northeast MA
Charger446
Northeast MA
Thanks for the replies guys, Yes, I did see the MAD electrical stuff but I was really hoping to disturb as little as the wiring as possible to make this work. I was wondering about the field wires if I had them backwards on the switch or if I only needed to shut down one of the fields. If I only shut off one of the field wires, what do I do with the master cutoff switch, just interrupt one of them using the switch and discard the other? Thank you, just saw your edited response
[Re: Charger446]
#2504937
06/05/18 06:13 PM
06/05/18 06:13 PM
Posts: 4,836 Moved to N.E. Tennessee
GomangoCuda
added the pic of my altimeter since I am running the bypass upgrade outlined by Nacho in past posts. I don't know if this makes a difference in my issues. You have an altimeter in your car? Bigdad needs one of those.
[Re: Charger446]
#2505535
06/07/18 10:47 AM
06/07/18 10:47 AM
Posts: 304 Portland, Oregon
Digger73
Portland, Oregon
If you have the 4 post battery switch as in your picture. Just run the charging system as it is wired originally and use the small posts on the battery switch to shut off the ignition system. Just run the ignition activation wire through the small posts. When the switch is shut off the ignition also shuts off. Engine stops running.
Hope this helps, Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
[Re: Digger73]
#2505650
06/07/18 04:14 PM
06/07/18 04:14 PM
Posts: 289 Lowes
steve660
Lowes
Hope this helps, Digger73 (Mike) This is how i did mine but ran MSD ground wire to battery switch. Not NHRA legal, but it turned the engine off.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
[Re: Charger446]
#2505676
06/07/18 05:32 PM
06/07/18 05:32 PM
Posts: 2,094 central texas
krautrock
central texas
just run your MSD 12v reference wire (turn on lead) to the battery switch. then the switch will kill yr ign and therefore your motor...
i would run the ign1 and ign2 to the battery switch and then to the msd.
[Re: Charger446]
#2505684
06/07/18 05:55 PM
06/07/18 05:55 PM
Digger73
Portland, Oregon
All you have to do is take the small red wire for the MSD 6AL and cut it. I would cut it near the MSD box so that nothing else will be effected. Then run one end of the cut wire to one of the small posts on the battery switch. Then run the other cut end to the other small post. This will stop the engine from running when the switch is turned off. Of coarse you will have to wire the alternator so that it charges the battery.
Digger73 (Mike)
