Re: Inexpensive AN fittings
[Re: mopar dave]
#2615105
01/31/19 03:17 PM
01/31/19 03:17 PM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
I've had excellent luck with Earls UltraPro line. I think it's their top shelf stuff, also most expensive. PTFE lined.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: mopar dave]
#2615106
01/31/19 03:17 PM
01/31/19 03:17 PM
Posts: 11,822 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Fragola started as a private label maker and probably make stuff for Summit and others.
[Re: mopar dave]
#2615316
01/31/19 10:46 PM
01/31/19 10:46 PM
Posts: 1,472 Martinsville, IN
cdwmotorsports
Martinsville, IN
I use Earl's and Aeroquip and a Russel here and there if I cant find what I need in the other two.
I have quite a few old blue fittings from my swap to black on ebay....
eBay-cdwmotorsports
[Re: mopar dave]
#2616735
02/04/19 04:02 AM
02/04/19 04:02 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I use Parker fittings for my braided teflon hoses, otherwise it is Aeroquip only. But I am using this on airplanes... here is the best AN hardware book in the INDUSTRY.. https://www.askbob.aero/sites/default/files/Genuine_Aircraft_Hardware_Catalog.pdfmost people dont know that AN does not mean Air Force/Navy, it actually stood for Air Corps/Navy because the specs came out before there was an Air Force. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: RV2]
#2616785
02/04/19 11:33 AM
02/04/19 11:33 AM
Posts: 10,050 MN
JERICOGTX
MN
For the past 4 years I have been buying all my hose and fittings from a place called "Getfast1" Excellent pricing and no issues, the last batch of fitting were Fragola. I bought 80% of my fitting for my Road Runner though them. It all looks nice... Haven't installed any yet.
69 GTX
68 Road Runner
[Re: astjp2]
#2616871
02/04/19 02:23 PM
02/04/19 02:23 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I use Parker fittings for my braided teflon hoses, otherwise it is Aeroquip only. But I am using this on airplanes... here is the best AN hardware book in the INDUSTRY.. https://www.askbob.aero/sites/default/files/Genuine_Aircraft_Hardware_Catalog.pdfmost people dont know that AN does not mean Air Force/Navy, it actually stood for Air Corps/Navy because the specs came out before there was an Air Force. Tim Well thanks for that. I had one when I was in an aircraft facility and it got misplaced. Never remembered where it came from or how to get another. Just ordered a new one.
[Re: astjp2]
#2616893
02/04/19 03:07 PM
02/04/19 03:07 PM
Posts: 43,368 Bend,OR USA
Cab_Burge
I use Parker fittings for my braided teflon hoses, otherwise it is Aeroquip only. But I am using this on airplanes... here is the best AN hardware book in the INDUSTRY.. https://www.askbob.aero/sites/default/files/Genuine_Aircraft_Hardware_Catalog.pdfmost people dont know that AN does not mean Air Force/Navy, it actually stood for Air Corps/Navy because the specs came out before there was an Air Force. Tim Does the FAA still require every part used on aircraft be certified with them?
