Re: Inexpensive AN fittings
[Re: rowin4]
#2504086
06/03/18 10:09 PM
06/03/18 10:09 PM
Posts: 2,299 NE Ohio
DoubleD
NE Ohio
Having the same flair out problem after the cut? I finally took a small hose clamp after the normal taping , slipped the clamp to the cut line, snug it up and cut right next to the clamp. After the cut loosen the clamp just enough to move it back to start the fitting , pushing the clamp back as the fitting goes on. I do leave the tape on also. I found as stated above it's the cheap hose , not the fitting. That's a good idea! - I have used the zip ties and cur between two of them - but i like the clamp idea better - lately I have been using the black braided line - much easier to put together!
[Re: dthemi]
#2504135
06/04/18 12:00 AM
06/04/18 12:00 AM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
There are some differences between AN,SAE,and JIC hose fittings. I used to do a lot of work on boom trucks and heavy equipment so I've used just about every type of hose and hose end there is. SAE and JIC 37* flare are identical, there is no such thing as a JIC 45* flare, however, there is such a thing as a SAE 45* flare. The SAE 45* is used in low pressure applications such as plumbing and LGP or NPG installation. Both JIC and -AN fittings are 37* flare seat angles. -AN is often incorrectly assumed to be the aluminum version of a JIC fitting, but in all actuality, -AN can be made from as many or more alloys than the garden variety JIC. Technically the fittings should not be interchanged, however, the only difference between -AN and JIC is the thread class. -AN is a military/aerospace spec fitting, with a tighter thread class (but still the same size and pitch as JIC) and is mostly intended for space shuttles and air planes. JIC was standardized to be a less costly High Pressure fitting that has no requirements of keeping a space shuttle in the atmosphere. The fact of the matter is, that you would be extremely unlikely to find a actual -AN fitting for sale in any motorsport's catalog, or online web store. Most of the stuff marketed as AN whatever thingamajigger is actually just an anodized aluminum JIC fitting. Any true -AN fitting will be listed in it's catalog as conforming to mil spec MIL-F-5509. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2504138
06/04/18 12:11 AM
06/04/18 12:11 AM
Posts: 6,149 Melbourne , Australia
LA360
I think most of us would be surprised as to which fittings are made in China nowadays. As Darren alluded to, some that may be packaged as being made in the USA etc, may only be anodised and packaged in that country. If the cost of those operations exceed the cost they're sourced for, they can have made in USA on the packaging. Despite being machined in China. Happens quite a lot with things like carbon bicycle frames etc
Alan Jones
[Re: mopar dave]
#2504340
06/04/18 01:56 PM
06/04/18 01:56 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
It's interesting that everyone is blasting Chinese made products. If you do the research you probably would find that most major brands are made in China. I did a quick search on Aeroquip. Major brand highly thought of as a great product. Aeroquip is a sub company of Eton a big conglomerate of different companies. Aeroquip states in their bio that all their [ hose ] is made in the USA and all of their [ fitting ] are shipped from their distribution center in OHIO . Now why would they say that???? I don't have the time right now , you guy's do some digging and see what brands are MADE IN THE USA
[Re: mopar dave]
#2504378
06/04/18 03:07 PM
06/04/18 03:07 PM
Posts: 370 Suffolk County, New York
1mean340
I used all summit brand fittings and hose on my Challenger. Not proud of it, but was on a tight budget and figured I'd probably be changing the setup a lot in the not so distant future so I didn't want to break the bank. 2 years later, no leaks (on 50psi EFI setup) no sign of deterioration of hoses even using their cheapest nylon braided while running e85 for a year. I hate to cheap out on something as critical as the fuel system but it does work and no indication that anything will fail prematurely.
I did have one of the smaller 6an swivels lose its swiveling ability after taking it off/putting it back on a few times. It made it a PITA to tighten and had to lube it up with a lot of motor oil to get the nut to spin freely. Didn't leak, and may have just been user error from me over tightening it.
[Re: mopar dave]
#2504383
06/04/18 03:17 PM
06/04/18 03:17 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
I've had some cheap ebay fittings on cars for several years w/ no trouble from any of them.
[Re: mopar dave]
#2504396
06/04/18 03:31 PM
06/04/18 03:31 PM
Posts: 11,668 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Some people don't care, but I get tired of playing "hide the bologna" with these companies. The "assembled in" and "made in" game. Or they make it impossible to find that information (if made in China is OK with you, man up and say it's made there, bucko). A lot of the small, hard parts sold by most of these companies, like AN/NPT adapters, AN unions, etc. are made overseas and you just have to watch. The hose ends and hose are my main concern. "Where is this stuff made?" is one of the main questions I ask people at PRI every year. Most will be honest about it.
That said, I think that a company like Aeroquip will have stringent oversight and specifications for their stuff and/or their own facility for stuff made overseas. Not so much for the guy buying no-name, private label stuff from Phakin Junq Industries that he sources on Madeinchina.com.
My advice is pick one well known company - Aeroquip, Earls, XRP are about all I will let in the door - for your hose and hose ends to avoid compatibility issues. Stay away from the private label stuff for any of the rest of it unless you know where it comes from. Big Bubba's Race Car Parts on eBay is not making his own parts or selling decent -10 hose ends for $4. It's just not worth wrecking or burn a car up to use junk. There's different levels of "trouble", from pee poor threads galling when you put it together, up to losing the car because a hose end fractured. I have seen and heard enough to know it's happened more than once or twice.
[Re: mopar dave]
#2504402
06/04/18 03:47 PM
06/04/18 03:47 PM
rowin4
Now I didn't say that Aeroquip AN fittings were made in china or overseas, I just referenced their "Quote" that their [ Hoses ] were made in the USA and their [ fittings ] were shipped from their warehouse in Ohio. That just struck me funny that they put that in the same sentence leading me to believe the fittings were not USA made.
[Re: mopar dave]
#2504403
06/04/18 03:48 PM
06/04/18 03:48 PM
Posts: 4,580 Motor City
6PKRTSE
Motor City
All black Fragola fittings & hose with a few Earl's, XRP & Aeroquip mixed in on my Challenger. To me, the Earl's seem to be the cheaper made of the brand names with Fragola & XRP being the better made.
Good thing is I have hundreds of mixed fittings in black, blue, red, clear, brass & stainless at home & in the trailer so I never have to run to the performance shop to buy any. In fact, most everyone stops by my house for fittings before going to the performance stores. LOL.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: rowin4]
#2504412
06/04/18 04:04 PM
06/04/18 04:04 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Now I didn't say that Aeroquip AN fittings were made in china or overseas, I just referenced their "Quote" that their [ Hoses ] were made in the USA and their [ fittings ] were shipped from their warehouse in Ohio. That just struck me funny that they put that in the same sentence leading me to believe the fittings were not USA made. That is what I refer to as playing hide the bologna. It may be USA, China, Taiwan, Mexico, Canada, the Moon. The CoO is usually listed on the packaging. Their company information allows them to have stuff made wherever they desire without being committed to any of them.
[Re: mopar dave]
#2504420
06/04/18 04:37 PM
06/04/18 04:37 PM
rowin4
Made in the USA doesn't always mean what you think. You do know that there is a city in China that they renamed USA just for that reason.
