Need help ID-ing trans
#2503934
06/03/18 03:33 PM
06/03/18 03:33 PM
Posts: 206 Elk River, Mn.
ks66
Elk River, Mn.
I have what I assume is a small block 727. Driver side pan rail is stamped PK4028406 5771 6657, the only other numbers I can find are on pass. side 7025 064 any help would be appreciated.
Re: Need help ID-ing trans
[Re: ks66]
#2503951
06/03/18 04:56 PM
06/03/18 04:56 PM
RapidRobert
measure the C to C between the (2) top mounting holes & post that dimention. I dont have the BB/SB numbers memorized but someone will. I'm assuming the pan shape is a 727, not a 904.
[Re: ks66]
#2503954
06/03/18 05:06 PM
06/03/18 05:06 PM
Posts: 25,949 Rio Linda, CA
John_Kunkel
Rio Linda, CA
PK4028406 5771 6657
PK= Kokomo assembly plant
4028406= A 727 from a 1977 318/360
5771= Build date May 16, 1977
6657= Sequence number, the 6657th built that day
