Bench testing a converter............... #2503776
06/03/18 02:46 AM
06/03/18 02:46 AM
State of confusion
Thumperdart Offline OP
State of confusion
Checking for a friend who's trans area was making noise when in gear and when shut off like a fin or something came loose.............On the bench it spins easier one way more than the other and is a bit noisier than the known good one we compared it to............... beer Thankxxx..........
Re: Bench testing a converter............... [Re: Thumperdart] #2503791
06/03/18 03:51 AM
06/03/18 03:51 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
They clunck a little when you have them out and shake them when they are not pressurized with fluid. They only spin one way. Only noise I've ever heard from them in the car is if the bolts back out and hit the block. There's no service without cutting it open so if it's suspect send it out.
Re: Bench testing a converter............... [Re: Thumperdart] #2503802
06/03/18 08:24 AM
06/03/18 08:24 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Sounds like it needs to be opened up for inspection. I think the diode is what makes it spin one way only if it has one.
Re: Bench testing a converter............... [Re: mopar dave] #2503808
06/03/18 09:08 AM
06/03/18 09:08 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
the vert in one of my cars spin both ways and works fine.
Re: Bench testing a converter............... [Re: Thumperdart] #2503880
06/03/18 01:02 PM
06/03/18 01:02 PM
A727Tflite Offline
A727Tflite  Offline
Take your reaction shaft and input shaft and insert in to the converter. That pilots all the internals. Hold the reaction shaft and turn the input shaft both directions which turns the turbine. Then turn the input and support together. If no noise then the blades are likely ok.
The blade/s could still be bad because without the converter running you are not loading the blades with fluid flow.
The only way to test the stator overrunning clutch is to hold it while turning the input shaft both directions. One way will be easy and the other hard. EDIT - turn the reaction shaft - not input. Sorry.
The old converters had large slots you could insert a tool in to hold the stator - most all late models do not have those slots.
I believe the old service manuals showed how to make a tool using a dipstick that was bend.
Re: Bench testing a converter............... [Re: A727Tflite] #2503916
06/03/18 02:24 PM
06/03/18 02:24 PM
State of confusion
State of confusion
Thankxxx guys will inspect more today............ thumbs
