gauges rise when I turn on the lights #2502932
05/31/18 10:47 PM
05/31/18 10:47 PM
NH
N
NHCharger Offline OP
N
NH
Finally got the latest money pit on the road. now shaking out the problems.
Tonight's problem. When I turned the parking lights on the temp and oil gauges started slowly rising. At idle the oil was at 80 and the water which is usually 175 was around 200. went down as soon as I turned the lights off.
It's a 69 Charger, using the same gauges and headlight switch that came with it. All new wiring harnesses.
Is this some type of resistance or grounding problem??
My Dad always told me, when setting goals " avoid disappointment, aim low".
Re: gauges rise when I turn on the lights [Re: NHCharger] #2502944
05/31/18 11:26 PM
05/31/18 11:26 PM
Andrewh Offline
Andrewh  Offline
probably grounding problem.
I would add a wire to the dash frame and maybe from the circuit board to the dash frame. see if that cures it.
or chase the holes the stuff bolts to.
Re: gauges rise when I turn on the lights [Re: NHCharger] #2502996
06/01/18 01:37 AM
06/01/18 01:37 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Last time I had a problem like that the body ground was loose. I would check the body ground to the battery and or to the eng. Good luck , Ron
Re: gauges rise when I turn on the lights [Re: NHCharger] #2502999
06/01/18 01:52 AM
06/01/18 01:52 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
I think the instrument cluster grounds through the screws that hold it to the dash so if you have any paint behind them it won't ground.
Re: gauges rise when I turn on the lights [Re: NHCharger] #2503207
06/01/18 03:16 PM
06/01/18 03:16 PM
Chicago
PurpleBeeper Offline
Chicago
I agree with these guys...likely a ground issue.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
