E body motor mount help. #2503197
06/01/18 02:55 PM
06/01/18 02:55 PM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
Putting a 360 into my 70. Challenger. Poor thing has been sitting and waiting for 20 years. I have new rubber motor mounts, but Somehow, I can’t find the motor mount brackets that attach to the engine. Can somoeone point me in the right direction to find a set?
Laine.
NRCA Member
Re: E body motor mount help. [Re: Lmopar69] #2503362
06/01/18 10:15 PM
06/01/18 10:15 PM
IN
ahy Offline
ahy  Offline
IN
I have used Schumacher stuff with good results. Have a look. One comment... rubber used in motor mounts these days does not seem the best. I run poly mounts and have been happy.
http://www.engine-swaps.com/
Re: E body motor mount help. [Re: ahy] #2503888
06/03/18 01:29 PM
06/03/18 01:29 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
340-360 b&e BODY ENGINE MOUNTING BRACKETS can be found on Ebay the correct ones are pricey.drivers side is narrow at the top to match the narrow spread pattern on the engine block.
abody are different
you can get by with 318 b&e the drivers side is a little wider, you can use spacers or washers to fill the gap on 1 bolt
Re: E body motor mount help. [Re: Joesixpack] #2503889
06/03/18 01:31 PM
06/03/18 01:31 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
318-273 b&e are pictured here ,they are the same width
Re: E body motor mount help. [Re: Joesixpack] #2503890
06/03/18 01:31 PM
06/03/18 01:31 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
340-360 are pictured here
Re: E body motor mount help. [Re: Joesixpack] #2503891
06/03/18 01:32 PM
06/03/18 01:32 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
340-360 b&e
Re: E body motor mount help. [Re: Joesixpack] #2503892
06/03/18 01:34 PM
06/03/18 01:34 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
applications used to locate these are
1970-1971-1972 340 Ebody
1971-1972-1973 c-body 360
1971-1972 B-body 340
Re: E body motor mount help. [Re: Joesixpack] #2503893
06/03/18 01:36 PM
06/03/18 01:36 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
360 with 340 B&E mount on drivers side
Re: E body motor mount help. [Re: Joesixpack] #2503894
06/03/18 01:37 PM
06/03/18 01:37 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
360 with 340 b&e mount on passenger side
Re: E body motor mount help. [Re: Lmopar69] #2503930
06/03/18 03:11 PM
06/03/18 03:11 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I know you have new rubber mounts, but you might want to look at Eboogers ebay store, he has some US made mounts.
Re: E body motor mount help. [Re: Lmopar69] #2504342
06/04/18 02:04 PM
06/04/18 02:04 PM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
Thanks for the help fellas. I had forgotten about Shumacher. Just ordered a set of the correct brackets.
Laine.
NRCA Member
