Radiator support black-out #2502746
05/31/18 04:06 PM
05/31/18 04:06 PM
Mass
charge70 Offline OP
charge70  Offline OP
Mass
Does anyone know when on the assembly line the radiator support received the black-out paint? Was it applied right out of the paint shop or was the car partially assembled and then got painted.
I'm mostly concerned with what might/would have been on the radiator support when the black-out was applied. Thanks,John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Radiator support black-out [Re: charge70] #2502766
05/31/18 05:08 PM
05/31/18 05:08 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Common consensus is it was painted right out of the paint shop by a guy standing in a pit; pattern was inconsistent with lots of overspray. Dark colored cars didn't get the blackout.
Re: Radiator support black-out [Re: charge70] #2502790
05/31/18 06:04 PM
05/31/18 06:04 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The pit part is a myth.
Lots of the cars have the lower top surface of the radiator support flange with black paint on them.
If there was a pit, the dude was either on a ladder or had VERY long arms.
Re: Radiator support black-out [Re: charge70] #2502791
05/31/18 06:06 PM
05/31/18 06:06 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The darker paint cars did not have to have the blackout, but I have seen factory black out on factory TX9, EF8 & EB7 cars.
Re: Radiator support black-out [Re: Alaskan_TA] #2502793
05/31/18 06:07 PM
05/31/18 06:07 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Did it matter what kind of car it was?
Re: Radiator support black-out [Re: Alaskan_TA] #2502857
05/31/18 07:44 PM
05/31/18 07:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Ah. So you worked the line? Tell us how it was done.
Re: Radiator support black-out [Re: charge70] #2502869
05/31/18 07:58 PM
05/31/18 07:58 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
If from a pit, would you have used a ladder or super long arms to do this?
Maybe a pogo stick? (That would be fun) boogie
From the low mile T/A;
Re: Radiator support black-out [Re: charge70] #2502872
05/31/18 08:02 PM
05/31/18 08:02 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
In the previous web version of Moparts, there was a long thread & it was beat to death.
Several members had photos of original paint cars with blackout on the top of that lower radiator support flange.
The conclusion - no pit involved with this process.
With undercoating - yes.
But not for this.
Re: Radiator support black-out [Re: Alaskan_TA] #2502898
05/31/18 09:10 PM
05/31/18 09:10 PM
New York
rarefish Online content
rarefish  Online Content
New York
Here are a couple of pics of the black out on my survivor 69 Dart. The car is B7 Blue. You would have to had to have been the "top man" to spray the black out in this area.
Re: Radiator support black-out [Re: charge70] #2502902
05/31/18 09:16 PM
05/31/18 09:16 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The pit side of the argument sure seems to agree with the half-dozen unrestored, unmolested, original '68-'69 B-bodies I've owned, insofar as the blackout was on undersides of the rad supports but not the upwards-facing areas.
If it wasn't a pit, perhaps the sprayer just reached in from the front and happened to angle the gun upwards, like if the hood was closed. But I don't recall ever seeing black overspray on the underside of the hoods.
It seems logical that the sprayer wouldn't be far away, for the sake of coating efficiency.
Either way, I'm not losing sleep over it; but I'd sure like to see an assembly-line photo so the question/debate can be settled.
Re: Radiator support black-out [Re: charge70] #2502909
05/31/18 09:25 PM
05/31/18 09:25 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Here is a photo of another original paint T/A.
Notice body color on the underside of this area & the back of the bolt head & washer.
The blackout was sprayed from in front & a little above on it too.
Re: Radiator support black-out [Re: Alaskan_TA] #2502947
05/31/18 11:29 PM
05/31/18 11:29 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Since nobody answered my question, I have a yellow 69 B body that doesn't have any blackout.
Re: Radiator support black-out [Re: charge70] #2502978
06/01/18 12:43 AM
06/01/18 12:43 AM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
There was a B/W photo in Mopar Action about 10 years ago of a guy in a PIT spraying a 68 or 69 body. Anyone remember that??
Re: Radiator support black-out [Re: 71birdJ68] #2503022
06/01/18 04:43 AM
06/01/18 04:43 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
It should have blackout
Re: Radiator support black-out [Re: charge70] #2503047
06/01/18 08:41 AM
06/01/18 08:41 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
Friend has a 97 A12 Runner that didn't have black out either.
Re: Radiator support black-out [Re: charge70] #2503159
06/01/18 01:22 PM
06/01/18 01:22 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I just looked at a '68 st louis automatic equipped. The spray appears to been applied by shooting upwards as the various bends in metal facing upward lack black-out paint. There is paint on the engine side of the radiator flange and there is no paint on wiring grommets, bolt threads, wiring or cooler/lines that are mounted to the grille side. I did not look to see if the front valence was fitted can check if needed.
Perhaps the treatment was applied from the grille opening with an open hood?
Re: Radiator support black-out [Re: formula_s] #2503166
06/01/18 01:36 PM
06/01/18 01:36 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yep, and the text supporting it was from E-booger hisself.
Re: Radiator support black-out [Re: charge70] #2503188
06/01/18 02:33 PM
06/01/18 02:33 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Something going on here. Could this blackout procedure differ at different plants? So far we have E-bodys sprayed from above and B-bodies sprayed from below.
I have an original paint 70 B-body from St Louis sprayed from below.
Re: Radiator support black-out [Re: charge70] #2503200
06/01/18 03:02 PM
06/01/18 03:02 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The Dart Rarefish posted is intriguing; I've owned 3 Darts ('69-'73) & 4 Barracudas from '67-'70, (1 of each year) and none had the upper panel blacked out like that. Blacked out from front or below, pretty consistent with my B bodies.
Were some missed? Some incorrectly applied by new-hires or in the factory offline repair areas or at dealerships? Modified due to collision repair or past owners? I'd say all are likely.
FWIW, my cars were from St Louis, Hamtramck, 1 from L.A. and 1 Lynch Rd.
For the record, I'm not in this discussion as a "swordfight" or a contest of any kind; but the various exceptions to the "rule" interest me. I'd REALLY like to see a photo of the blackout process on the line, or at least one of E-berg's Engineering diagrams.
Re: Radiator support black-out [Re: MI_Custumz] #2503259
06/01/18 05:08 PM
06/01/18 05:08 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
This is why I asked does it matter what body style, or trim level the body gets? Mine is a 440 trim level 4 door, yellow and no black out.
