INDY SR Heads
#250201
03/10/09 10:24 PM
03/10/09 10:24 PM
Posts: 77 British Columbia Canada
Challenger340
Just curious What kind of Power has anybody seen these heads make ? As in "whats the most anybody's made with them" ?
I've worked on & off over a few years with a set for a Customer, actually far beyond whatever someone ever SHOULD do, because far better Heads out there, but, nonetheless, I'm a sick puppy, and as long as I could just go over them again, while refreshening the Engine over the years, a little here, a little there, it was OK and kept burnout away.
Anyways, just Dyno'd the 540 using the "magic" SR's and got 849.2 hp @ 6700 rpm and 753 Ft/Lbs @ 5100 rpm. Unfortunately, I DIDN'T Flow them before I put them back on this time !
Now you're really gonna laugh ! Using Crane Gold Rockers and a 230# seat Pressure grind Roller(easy on parts) We just cycle the Gold's out about every 250 pulls or so, but they work fine.
So, how far have you guys seen SR's go ?
I'm now officially DONE with them !
Better to be a "has been" than a "never was".
Re: INDY SR Heads
[Re: 506RR]
#250203
03/10/09 10:35 PM
03/10/09 10:35 PM
Posts: 5,620 long island NY
Ari440
long island NY
what car, weigth and what did it do 1/4 mile
what is the whole combo
1.39 9.85 - 137 mph
Re: INDY SR Heads
[Re: Ari440]
#250204
03/10/09 10:45 PM
03/10/09 10:45 PM
Challenger340
The Car is a 74 Dart Sport, a White one. He's on his way home now to Install, and slam to make Vegas next week.
He used to run real low 9's @ 150-151 ? in the 2800 lb Car, but at 2300 ft elevation(Edmonton) I think he's gonna get an 8 now in Vegas next week with the SR's Too Funny !
540 Combo Mega Block 4.500 Source 4.250 Crank Source 7.100's W/2000 upgrade J.E. 13.7 Slugs INDY SR (highly modified, but NO welding & still 2.19 INDY Intake, downthroat adaptor Dominator Comp .690 Roller(easy on parts, 230 # Seat) CRANE GOLD's
Real "K.I.S.S." Deal. I've made lots more Power, but always with 440-1 or 572's. But thats my BEST with an "SR".
Re: INDY SR Heads
[Re: Challenger340]
#250206
03/10/09 10:57 PM
03/10/09 10:57 PM
Posts: 1,260 Las Vegas NV
moparmanjames
Las Vegas NV
Vegas is 2100ft but the air should be ok next week, especially if we get passes in the morning.
Re: INDY SR Heads
[Re: moparmanjames]
#250207
03/10/09 11:04 PM
03/10/09 11:04 PM
Challenger340
An 8 might be tough then, figure he's only "up" about 30 from before ? Shoulda Dyno'd last time I re-freshened last year, woulda had better reference from 2 years before that(up 60 from there).
Re: INDY SR Heads
[Re: Challenger340]
#250208
03/10/09 11:13 PM
03/10/09 11:13 PM
fast68plymouth
So. Burlington, Vt.
340cfm MW sized SR's, 13:1 493 RB motor, bracket roller cam, dynoed 736hp. has gone 8.73 @ 156 in a 2600-ish lb A body, in like 1400ft air.
its a bit of an over achiever.
Re: INDY SR Heads
[Re: 451Guy]
#250212
03/11/09 04:43 PM
03/11/09 04:43 PM
Posts: 1,056 Mt.Vernon IL
Twin Turbo Mower
Mt.Vernon IL
A guy that lives north of me Jerry timberman I believe ran a rail a few years back 470 low deck with sr heads made around 910-930 hp. His had epoxy in them mainly on the pushrod walls. I think he went to bigger heads and a aluminum block. He had a website and might have even had been in a magazine.
Re: INDY SR Heads
[Re: Challenger340]
#250213
03/11/09 04:46 PM
03/11/09 04:46 PM
Posts: 1,855 Staten Island N.Y.
Dap
Staten Island N.Y.
The little 446 that Dwayne put together for me made 688 on his Dyno with SR`s. So far the best ET has been 10.09 with a DA of 1700 ft through Flowmaster 2 chamber mufflers last July N/A.
PRH446 10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
