98 DAKOTA R/T AUTO TRANS. #2501417
05/28/18 07:21 PM
05/28/18 07:21 PM
greenfield, ind.
P
PLMCRZY Offline OP
PLMCRZY  Offline OP
P
greenfield, ind.
trans starting to throw codes related to solenoid circuits. any recommendations on replacement or rebuilds.
Re: 98 DAKOTA R/T AUTO TRANS. [Re: PLMCRZY] #2501419
05/28/18 07:23 PM
05/28/18 07:23 PM
Guitar Jones Offline
What Trans is in it?
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 98 DAKOTA R/T AUTO TRANS. [Re: PLMCRZY] #2501453
05/28/18 08:51 PM
05/28/18 08:51 PM
541 slobovia
A990 Online content
A990  Online Content
541 slobovia
and what is it doing exactly?
Re: 98 DAKOTA R/T AUTO TRANS. [Re: PLMCRZY] #2501460
05/28/18 09:10 PM
05/28/18 09:10 PM
greenfield, ind.
P
PLMCRZY Offline OP
PLMCRZY  Offline OP
P
greenfield, ind.
46RE, i have seen code p0748 and p0752. other than that it feels like it shifts fine
Re: 98 DAKOTA R/T AUTO TRANS. [Re: PLMCRZY] #2501469
05/28/18 09:23 PM
05/28/18 09:23 PM
Just go ahead and replace the solenoid and transducer.
Re: 98 DAKOTA R/T AUTO TRANS. [Re: PLMCRZY] #2501517
05/28/18 11:13 PM
05/28/18 11:13 PM
541 slobovia
A990 Online content
A990  Online Content
541 slobovia
Are you seeing any codes for the rear (aftercat) o2 sensor?
If you are, change it first, clear the codes and see what happens.
Re: 98 DAKOTA R/T AUTO TRANS. [Re: A990] #2501548
05/29/18 12:43 AM
05/29/18 12:43 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
A990 its funny you say that as I had a strange problem on about a 98 Durango where I ended up working with the Chrysler tech adviser because the truck kept setting a code for Gov Press Sensor and Gov Press Sensor Volts to high and to make a long story short I replaced the gov sensor and solenoid and checked everything. But about a week or two later his check eng lite would come on and set the same codes. I finally got a tech adviser on the phone who told me to replace the downstream 02 sensor and it fixed it. He actually told me why it sets the code and how it causes it to set because I told him I have to know. But its to much to write about it but I am guessing you ran into the same sort of problem before ? Ron
Re: 98 DAKOTA R/T AUTO TRANS. [Re: PLMCRZY] #2501597
05/29/18 08:15 AM
05/29/18 08:15 AM
nj
JAMESDART Offline
JAMESDART  Offline
nj
This is interesting. I put a 5.9 and 46re in my Wrangler. And I'm getting these pesky trans codes over the last couple months. Sometimes it's only the gov pressure code and it will not go into 1st. But then other times I get a couple codes and it will drive perfectly fine. I did put new o2 sensors when I put the engine in. But the last time I got these codes an O2 was one of them.
Re: 98 DAKOTA R/T AUTO TRANS. [Re: PLMCRZY] #2501635
05/29/18 10:56 AM
05/29/18 10:56 AM
541 slobovia
A990 Online content
A990  Online Content
541 slobovia
I had this happen like 10 years ago. It seems to be a really obscure problem.
The way I understand it, the downstream also reports a warmed up cat, but if it doesn't, and the coolant sensor says warm, then the computer on my 99 Dakota would hold the trans in first gear. I did like you-
replaced the sensor and solenoid, but still no upshift. I then changed the downstream and everything was fine.
We had another member here with a Ram that did the same thing. Your Durango is the first I've heard that shifted normal.
By chance was it Canada spec? They have a convertor/sensor setup nothing like the 48 state/Cali units. (My Dakota is canada spec)
Re: 98 DAKOTA R/T AUTO TRANS. [Re: A990] #2501896
05/29/18 06:15 PM
05/29/18 06:15 PM
greenfield, ind.
P
PLMCRZY Offline OP
PLMCRZY  Offline OP
P
greenfield, ind.
nope, that is very interesting about the 02 sensor, cheaper than a rebuild. i'll order the parts and cross my fingers.
Re: 98 DAKOTA R/T AUTO TRANS. [Re: A990] #2501907
05/29/18 06:48 PM
05/29/18 06:48 PM
greenfield, ind.
P
PLMCRZY Offline OP
PLMCRZY  Offline OP
P
greenfield, ind.
is the canada converter better? i understand that the t/c is the source of the many problems, as it sends debris through the tranny
Re: 98 DAKOTA R/T AUTO TRANS. [Re: PLMCRZY] #2501961
05/29/18 09:24 PM
05/29/18 09:24 PM
541 slobovia
A990 Online content
A990  Online Content
541 slobovia
I meant Catalytic convertor. There's 3 exhaust configurations.
Good luck on the fix.
Re: 98 DAKOTA R/T AUTO TRANS. [Re: A990] #2502072
05/30/18 01:38 AM
05/30/18 01:38 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Actually this Durango cust said it shifted fine but the check eng lite would come on with the Gov codes. The Chrysler tech adviser told me the PCM looks at the downstream 02 and then looks at the trans gov press sensor next. He told me the sensor had a heater problem and it could spike voltage from a defective heater in the 02 into the Gov press sensor reading as this one kept setting the code for Gov Press Sensor volts High. And the 02 heater of course was fed 12 volts to it. But that's the way the tech adviser told me it set that code. I told him I don't know if I could have figured that one out without his help. I don't remember it being a Canada vehicle either. Ron
Re: 98 DAKOTA R/T AUTO TRANS. [Re: PLMCRZY] #2502104
05/30/18 03:33 AM
05/30/18 03:33 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
I agree with swapping in a new O2 sensor before doing further troubleshooting. All brands have had issues with errant codes, due to the way sampling and key-on tests are performed on OBD2 cars.
As a for instance, a couple years of Ford F150's had a "glitch" in their testing sequence - if the computer was at a certain spot testing the air bag system - testing the front sensor and speed sensor - and you slammed the passenger door, it would see speed and both sensors tripped and blow the air bags.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: 98 DAKOTA R/T AUTO TRANS. [Re: PLMCRZY] #2502122
05/30/18 08:25 AM
05/30/18 08:25 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Seems like the 46RE auto trans give a lot of problems compared to the older 46RH.
I wonder if one could flash the OBD-II PCM to the software for a 5 speed manual, install a button on the dash to trigger Overdrive, and install a 46RH instead of a 46RE?
