Page 1 of 10 1 2 3 9 10
Super Sniper install #2501485
05/28/18 09:49 PM
05/28/18 09:49 PM
AndyF Online content OP
AndyF  Online Content OP
Got the new Super Sniper throttle body setup for my Coronet and have starting to install it. In theory they just bolt on with a few connections but this one isn't going on so easily. One wiring harness was missing out of the package and the secondary linkage is missing off of the throttle body. Holley must be making these things so fast that they are forgetting to put all the parts in the box.
Re: Super Sniper install [Re: AndyF] #2501486
05/28/18 09:54 PM
05/28/18 09:54 PM
The Sniper is wider than a carb so the throttle cable doesn't line up. That could be a problem with a lot of existing throttle brackets. I'm just going to make a new set of brackets that are offset an inch and see how that works.
Re: Super Sniper install [Re: AndyF] #2501494
05/28/18 10:23 PM
05/28/18 10:23 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
It looks like your bracket is 2 pieces, maybe unbolt and turn it to the out side?
Re: Super Sniper install [Re: AndyF] #2501557
05/29/18 01:13 AM
05/29/18 01:13 AM
Granbury TX
Prochargedmopar Offline
Granbury TX
My standard sniper that I put on my 73 F100 still doesn't have the trans kickdown/servo lever hooked up.
I need to make a bracket for it.
The install was definitely MORE than a 4 wire hookup. LOL
Fuel system was the biggest pita but also had to do an air cleaner mod.
"Old" member Registered: Sep 2001
Lost my credentials, I'm Back!! LOL
71 Ply Satellite Procharged
73 Dodge Dart Swinger
73 Ford F-100 390/Sniper efi/back to carb
01 Town and Country Limited
08 Dodge 2500 6.7 5" Deleted
02 Mercedes C230K
19 Camry
Re: Super Sniper install [Re: rowin4] #2501559
05/29/18 01:17 AM
05/29/18 01:17 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Looks like that would work! scope
Re: Super Sniper install [Re: AndyF] #2501582
05/29/18 03:00 AM
05/29/18 03:00 AM
The front fuel inlets on the Sniper body are mounted really high so the fittings will run into the air cleaner base. The instructions don't mention it, but Holley sells a special Sniper air filter base. Not sure why the instructions don't point it out, seems like it could help guys out with a problem.
I bought one of the Sniper air cleaner bases but I don't think I'll use it. I decided to use the fuel fittings on the back of the throttle body rather than the front ones. The Sniper base if kind of flat while my old K&N base seemed to have a better shape to it for air flow. I haven't tested either one but the K&N just looks better so I'm going to use it.
Re: Super Sniper install [Re: AndyF] #2502001
05/29/18 10:55 PM
05/29/18 10:55 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
Watching with extreme enthusiasm Andy. I'm about to install the same setup on my Charger along with the Holley Dual Sync I purchased from you. I knew about the air cleaner for the throttle body. Lot's more info on the Holley forums and sites. I do read about quite a few IAC issues on the Holley Sniper forums on FB as well. I've installed a FiTech, an Edelbrock on customers cars, however never a Holley so my car will be the ginny pig.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: Super Sniper install [Re: AndyF] #2502024
05/29/18 11:38 PM
05/29/18 11:38 PM
The dual sync distributor should work well with the Sniper. I'm waiting for the new Hyperspark ignition stuff from Holley to start showing up. The Hyperspark is all designed to plug and play with the Sniper so it will be a clean install. The dual sync is a pretty clean install though and it is Hall effect so that is better than trying to use a MSD distributor.
Re: Super Sniper install [Re: AndyF] #2502080
05/30/18 02:08 AM
05/30/18 02:08 AM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
Sounds great Andy. Looking forward to seeing how you address the throttle linkage.
Re: Super Sniper install [Re: ChrgrCuda] #2502177
05/30/18 11:38 AM
05/30/18 11:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I had to cut off my throttle arm and reverse
it and weld it back on to get my cable to line
up correctly.. was about 1 1/4" off.. ths was
on my HP throttle body.. minor issue when you
build the whole car
wave
Re: Super Sniper install [Re: MR_P_BODY] #2502294
05/30/18 03:51 PM
05/30/18 03:51 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Hey Andy, who makes the black water neck/sensor piece?
Re: Super Sniper install [Re: AndyF] #2502312
05/30/18 04:34 PM
05/30/18 04:34 PM
I made that. I made a few extras, haven't decided to put them on the website or not.
Re: Super Sniper install [Re: AndyF] #2502343
05/30/18 05:47 PM
05/30/18 05:47 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Damn that's sweet. PM me about a price Andy. wave
Re: Super Sniper install [Re: AndyF] #2502372
05/30/18 07:09 PM
05/30/18 07:09 PM
Thanks. You can get water neck spacers from Summit but sometimes the quality isn't super high. I've tried a few different brands in the past and sometimes they don't work with a thermostat or else there isn't enough wall thickness for the sensor threads.
Re: Super Sniper install [Re: AndyF] #2502375
05/30/18 07:12 PM
05/30/18 07:12 PM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
I will take one. I like it. Very clean. I can run my EFI temp off it like you did. Then run my Mercedes fan controller off the other. Very trick Andy.
Re: Super Sniper install [Re: HDNMOPERS] #2502398
05/30/18 08:53 PM
05/30/18 08:53 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
I kinda figured that, and it looked like something you'd do. Pm me a price if they're not all spoken for already. laugh2
Re: Super Sniper install [Re: thehemikid] #2502431
05/30/18 10:09 PM
05/30/18 10:09 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
For what it's worth I've got the same throttle bracket and the 4 injector model lines up just a hair off center.
Re: Super Sniper install [Re: AndyF] #2502437
05/30/18 10:45 PM
05/30/18 10:45 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
I'm a buyer Andy if you decide to make any.
Re: Super Sniper install [Re: ChrgrCuda] #2502440
05/30/18 10:47 PM
05/30/18 10:47 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
Referencing of course the thermostat adapter.
Re: Super Sniper install [Re: MarkZ] #2502495
05/31/18 12:20 AM
05/31/18 12:20 AM
MR_P_BODY Offline
MR_P_BODY  Offline
For that little bit I would just bend the linkage bracket
a bit to line it up... just up from the intake
wave
