spray adhesive for intake gaskets #2501317
05/28/18 01:44 PM
05/28/18 01:44 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
I'm looking for a spray adhesive for the felpro metal pan that comes with paper gaskets.
thanks
Re: spray adhesive for intake gaskets [Re: varunner] #2501372
05/28/18 05:20 PM
05/28/18 05:20 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I use 3M spray adhesive #77 or #90 it's just to hold the gaskets in place, not a sealant
Re: spray adhesive for intake gaskets [Re: varunner] #2501442
05/28/18 08:31 PM
05/28/18 08:31 PM
Chicago
PurpleBeeper Offline
Chicago
Those gaskets used to come with a small tube of blue or green sealant and a little metal handled paint brush. It sure "looked" like Indian Head gasket sealer that comes in the little brown bottles (most part stores)
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: spray adhesive for intake gaskets [Re: varunner] #2501467
05/28/18 09:23 PM
05/28/18 09:23 PM
I use the liquid Gasketcinch brand of gasket adhesive, sealer up
I'm sure Jegs and Summit sells them in different size of cans, I buy the littlest cans and use it as needed scope The bigger containers last forever and will usually start to get thicker the longer it sits on the shelfs once you open them shruggy
Follow the instructions to success, no more having to scrape gaskets off after using that really good stuff instead of using the "Right Stuff" scope thumbs twocents
Re: spray adhesive for intake gaskets [Re: DAYCLONA] #2501468
05/28/18 09:23 PM
05/28/18 09:23 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
I have some of the 3M #77 which I used as contact cement for the vinyl top. Not sure how you could spray it on a gasket and not function as a sealer. Anyway a google search showed a 3M doc. that said it can be used on water pump gaskets. I think it should work ok. I want to bond both gaskets to the metal pan first, then install it at final assembly.
I just bought the gasket set, no sealer was in the box.
Re: spray adhesive for intake gaskets [Re: varunner] #2501500
05/28/18 10:31 PM
05/28/18 10:31 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Hi Tack red spray by permatex
Re: spray adhesive for intake gaskets [Re: varunner] #2501529
05/28/18 11:55 PM
05/28/18 11:55 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Thanks all, I'll look into them
Re: spray adhesive for intake gaskets [Re: varunner] #2501553
05/29/18 01:06 AM
05/29/18 01:06 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I use this on the valley pan paper gaskets..No leaks ever...Be prepared to do some scraping if you ever need to remove the intake... Permatex copper spray
Re: spray adhesive for intake gaskets [Re: R/T1968R/T] #2501565
05/29/18 01:37 AM
05/29/18 01:37 AM
that was my old standby (thin/tacky/spray) but the last 2 spray cans of it, red globules came out in the spray. It does have a different can format that the old version of it. I did have some 3M spray (not sure if the # is the same as mentioned) but that stuff was wicked stout.
Re: spray adhesive for intake gaskets [Re: varunner] #2501598
05/29/18 08:32 AM
05/29/18 08:32 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Good suggestions. I plan on taking this engine apart a few times to tinker on it. I was thinking about using some spray rubber-like product on the oil pan/windage tray rails, with the thought of not needing any sealer for the most part with the superformance gaskets, maybe I'll do the same on the intake.
I'll need some copper coating on the shim head gaskets, so thanks for that link.
Hi Tack red spray looks good as well.
Re: spray adhesive for intake gaskets [Re: varunner] #2501623
05/29/18 10:28 AM
05/29/18 10:28 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Gasketcinch on head side, red axle grease on the intake side, super stuck racers do it, they can pull an take and reuse the gaskets over and over....their engines get torn down all the time for rules verification.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: spray adhesive for intake gaskets [Re: varunner] #2501633
05/29/18 10:51 AM
05/29/18 10:51 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I use 3m copper gasket spray for most gaskets. Helps seal and makes it easier to take them apart after. That being said, if this is for a big block valley pan, I install it without paper gaskets. The factory never used paper gaskets there.
Re: spray adhesive for intake gaskets [Re: DaytonaTurbo] #2501647
05/29/18 11:18 AM
05/29/18 11:18 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The OP might be doing a six pack manifold and needs the paper gaskets?
Re: spray adhesive for intake gaskets [Re: Adobedude] #2501698
05/29/18 12:39 PM
05/29/18 12:39 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I like this idea, and am going to try it soon. Thanks!
Re: spray adhesive for intake gaskets [Re: varunner] #2501803
05/29/18 04:10 PM
05/29/18 04:10 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
My combo is a 383, cast iron intake. I need some height to line up the ports, so just the metal won't cut it.
I remember way back in the day in a car craft or similar mag. they had an article about either a pro stock or super stock chevy, they used "duck butter" on the intake gaskets for frequent removal, I think it was just white grease.
Re: spray adhesive for intake gaskets [Re: varunner] #2502211
05/30/18 01:20 PM
05/30/18 01:20 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Not an aerosol but the best intake manifold gasket sealing material I've ever used.
http://hylomar.com/hylomar-product-range/gasket-jointing-compounds/#universalblue
Re: spray adhesive for intake gaskets [Re: Cab_Burge] #2502884
05/31/18 08:27 PM
05/31/18 08:27 PM
Montreal Quebec
STROKIE Offline
STROKIE  Offline
Montreal Quebec
iagree
