What type of anodizing is on '69 Charger rocker moldings? #2500974
05/27/18 12:25 PM
05/27/18 12:25 PM
Ball Ground, Georgia
Dixie Offline OP
Dixie  Offline OP
Hey Guys,
I need to get my rocker moldings anodized for my '69 Charger. Does anyone know what type of anodizing was used and percentage of brightness?
I think I read somewhere they were clear anodizing with 20% brightness. I would appreciate any info on the subject.
I recently had mine polished and straightened and found two shops in Atlanta that can anodize.
Thanks!!
Randy
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: What type of anodizing is on '69 Charger rocker moldings? [Re: Dixie] #2500979
05/27/18 12:33 PM
05/27/18 12:33 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I thought the process on exterior bright aluminum was called “Brite-Dip”
Different than anodizing
Re: What type of anodizing is on '69 Charger rocker moldings? [Re: Dixie] #2500987
05/27/18 01:03 PM
05/27/18 01:03 PM
Dixie Offline OP
Dixie  Offline OP
I think Brite-dip is a form of anodizing, but I'm not sure. Would appreciate any clarification.
Re: What type of anodizing is on '69 Charger rocker moldings? [Re: Dixie] #2501083
05/27/18 07:29 PM
05/27/18 07:29 PM
home of the Buckeyes
Butterscotch71 Offline
Lost Title
Lost Title
If I understand it correctly the brite dip is a process to create the smooth surface and shine then the part would be dipped in the anodizing solution
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
Re: What type of anodizing is on '69 Charger rocker moldings? [Re: Dixie] #2501231
05/28/18 06:05 AM
05/28/18 06:05 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
All the rocker moldings on cars I've ever owned (not any Chargers) were much harder polished stainless steel, not aluminum, because of potential rock damage. Aggressive polishing or compounding of anodized aluminum trim will remove the anodizing, and the finish will turn dull after a short while.
Are you sure yours is aluminum?
"Bright Dip Anodized Aluminum Trim" is a term used by an expert restorer, now retired, at http://www.alltrim.com/index.html.
This is a finish on only stamped aluminum sheet products. AFAIK bright is bright, and there is no choice of brightness. But you can discuss this with a competent restorer.
Every month's issue of Hemmings Motor News has several classified ads for small batch restoration of bright dip anodized aluminum trim.
Photo is an example of restored bright dip anodized aluminum trim. Not stainless steel.
Re: What type of anodizing is on '69 Charger rocker moldings? [Re: kentj340] #2501249
05/28/18 10:06 AM
05/28/18 10:06 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Anodizing was used on all exterior aluminum trim to protect the finish.If you polish exterior aluminum trim you can make it shine like stainless but eventually the finish will start to cloud and turn dull.
Re: What type of anodizing is on '69 Charger rocker moldings? [Re: kentj340] #2501273
05/28/18 11:26 AM
05/28/18 11:26 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Most 68-74 era A/B/E body rocker moldings were aluminum. Can’t think of one that was stainless, but there might be. stainless might be more prevalent on 67 an earlier cars or more expensive C-bodies.
