Re: Trouble with oil leaks in a 440 [Re: Kern Dog] #2500934
05/27/18 10:38 AM
05/27/18 10:38 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Plug the breather. Apply low air pressure through the PCV fitting. If you can put your finger over the air source and stop air flow that will be enough air pressure to work. The leak will show itself quickly. Oil will drip, ooze, stream from the leak area. Easiest way I've ever found oil leaks.
Doug
Re: Trouble with oil leaks in a 440 [Re: dvw] #2500965
05/27/18 11:50 AM
05/27/18 11:50 AM
moparx Offline
moparx  Offline
Doug
iagree and you only need about 10# of pressure, if that. start at 5 and see what happens. this is super easy if done on the stand before installation, but perfect for in the car diagnosis as well.
beer
Re: Trouble with oil leaks in a 440 [Re: dvw] #2501016
05/27/18 03:23 PM
05/27/18 03:23 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Doug
Great idea will try it next time we get a difficult leaker in beer
Re: Trouble with oil leaks in a 440 [Re: Kern Dog] #2501261
05/28/18 10:52 AM
05/28/18 10:52 AM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
Superformance gaskets worked for me; my engine was bone dry last year for the first time ever. Since then, I've developed a few small drips on the floor that I need to check out. In years past, no matter what I did, I always had some slight leak from the get go.
I truly believe that in the future, I'll use nothing but Superformance gaskets for everything. Any time that I've used them, they've just been so much better than anything else. This year, my carb gaskets were switched from standard Holley blues. I've had the carb on and off the car and apart a lot and the things don't stick at all and still look brand new.
Re: Trouble with oil leaks in a 440 [Re: Kern Dog] #2502759
05/31/18 04:58 PM
05/31/18 04:58 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
FWIW I don't use anything on my oil pan, windage tray, block, etc. Just the spots I mentioned where the timing cover and rear main seal retainer meet the block
Re: Trouble with oil leaks in a 440 [Re: dvw] #2502933
05/31/18 10:48 PM
05/31/18 10:48 PM
Plug the breather. Apply low air pressure through the PCV fitting. If you can put your finger over the air source and stop air flow that will be enough air pressure to work. The leak will show itself quickly. Oil will drip, ooze, stream from the leak area. Easiest way I've ever found oil leaks. Doug
Noted!
