Small block hydraulic lifter question #2499555
05/23/18 04:53 PM
05/23/18 04:53 PM
O
OLD318 Offline OP
OLD318  Offline OP
O
Hey team, does anyone know firsthand...
Can you replace a hydraulic valve lifter on a mopar small block without removing the head or the intake?
i.e. Is the pushrod port large enough to take the lifter in/out?
if you've done this before please chime in
thanks for the ad!
Re: Small block hydraulic lifter question [Re: OLD318] #2499559
05/23/18 05:01 PM
05/23/18 05:01 PM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
Yes indeed, just get an extendable pick-up magnet or mini-grabber tool, and they will all come out super-easy once you have the pushrods out.
If you have some scuzz built up in the engine, you might need to break a little ridge at the top of the bores, but nothing some cleaner can't take care of. One of the first jobs I did with my car.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Small block hydraulic lifter question [Re: OLD318] #2499579
05/23/18 05:47 PM
05/23/18 05:47 PM
scratchnfotraction Offline
in the old days? yes.
now days? no. I have dropped 1 too many and had to pull the intake anyways.
I have also opened up a couple engines that had lifters in the valley or in the oil pan. I ASSume from someone doing this very thing.
so now I get a gasket set and pull all of it for a good cleaning/paint/gaskets.
plus you can clean any carbon deposit build up or gunk out of the valley area while looking over the wear pattern of the lifters/cam lobes.
now days all I have are pre-magnum LA roller cam engines. and the ones I do find that have a flat tappet cam I swap over to roller cam/valve gear.
Re: Small block hydraulic lifter question [Re: OLD318] #2499693
05/23/18 10:00 PM
05/23/18 10:00 PM
md
mopars4ever Offline
mopars4ever  Offline
md
There is a tool made for grabbing the lifter. I have done them more then once. Some are harder to get to then others.
Re: Small block hydraulic lifter question [Re: OLD318] #2499754
05/23/18 11:47 PM
05/23/18 11:47 PM
there was enough room on my 308's (not real tight but tight). You have pinpointed a bad one?
