Page 3 of 6 1 2 3 4 5 6
Re: picked up a 80688 holley 1050 to try [Re: Thumperdart] #2499487
05/23/18 01:56 PM
05/23/18 01:56 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Originally Posted By Thumperdart
Originally Posted By Clanton
I put a 70 in and got 11/0.The main jet is 84 from factory.What is this telling us?
ps:I put 80 jets in and got 11.4 a/f
Yes on the t-slot restrictors so here's my tune.......
.040 IFR'S lowered
.068-.070 idle bleeds
.026-.028 hi bleeds
.055 t-slots and .082-.088 jetting
You need a vacuum gauge to check for the best power valve and one that comes in as you crowd the throttle while cruising at a steady state speed........too high, rich too soon, too low delayed enrichment..........
Thank you!!
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2499488
05/23/18 01:57 PM
05/23/18 01:57 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Call me if u need help............ callme
Re: picked up a 80688 holley 1050 to try [Re: mopar dave] #2499489
05/23/18 01:58 PM
05/23/18 01:58 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
You want smaller on the t slot. If you dont have pin gauges, get some off ebay. You need to pin gauge the pvcrs as well.
Re: picked up a 80688 holley 1050 to try [Re: Thumperdart] #2499490
05/23/18 02:02 PM
05/23/18 02:02 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I put you in my contacts,see how this goes.
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2499518
05/23/18 03:07 PM
05/23/18 03:07 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
my .075 slops around a little in the hole and the jets are press in it looks like
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2499520
05/23/18 03:20 PM
05/23/18 03:20 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Drill and remove those then the holes are USUALLY sized for an 8-32 tap.......... beer
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2499537
05/23/18 04:10 PM
05/23/18 04:10 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
TY!I had a holley tech on line and it was like pulling teeth.I did not get it solved on a press in part # I wanted to see if I could get.
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2499543
05/23/18 04:18 PM
05/23/18 04:18 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
looks like a nice carb for the coin...almost makes me want to pull the EFI off...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: picked up a 80688 holley 1050 to try [Re: OUTLAWD] #2499552
05/23/18 04:35 PM
05/23/18 04:35 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Say it ain't so............. work
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2499562
05/23/18 05:14 PM
05/23/18 05:14 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Has anyone pressed in a lead plug and drilled it?
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2499563
05/23/18 05:16 PM
05/23/18 05:16 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I may have the tap 8-32 and I will get a drill bit just bigger than the hole in the brass jet.I figure I need the carb off for this.
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2499566
05/23/18 05:26 PM
05/23/18 05:26 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I heard some have but best to drill n tap that way you can make changes easier and it's cleaner........... thumbs
Re: picked up a 80688 holley 1050 to try [Re: Thumperdart] #2499581
05/23/18 05:51 PM
05/23/18 05:51 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I just got the drill and tap plus the drill to remove the press in jet.Thanks for the help and I will get back to you in a few days.
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2499683
05/23/18 09:31 PM
05/23/18 09:31 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You got this............... beer thumbs
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2500221
05/25/18 10:02 AM
05/25/18 10:02 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I took my time measuring depth and threads[8] on the set screw,drill bit,tap and the 5/16 8-32 screw[0152806] sits flush with the edge.I ordered 100 brass set screws from fasten all[2.65$] that will be in Tuesday and I can drill a few and give it a try.
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2500241
05/25/18 11:18 AM
05/25/18 11:18 AM
moparx Online content
moparx  Online Content
when drilling brass, be very careful on the bit "break through", as this is the point that will be most prone to drill breakage. a lot depends on the feedrate, and the alloy content of the screw.
beer
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2500256
05/25/18 11:37 AM
05/25/18 11:37 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thank you,I drilled and tapped a little holder for the set screws and is what I tested for drilling the carb and this should be stable for doing the set screws.
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2500259
05/25/18 11:45 AM
05/25/18 11:45 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i chuck the set screws in my handheld drill.
last time i drilled some, i actually just put the drill bit in a regular vise, set screw in the drill, drill in one hand and the other hand spanned the drill and the vise to keep steady...
also, most common i think are 1/8" long screws for IFR's and 1/8" or 3/16" long screws for the t-slot
Re: picked up a 80688 holley 1050 to try [Re: krautrock] #2500263
05/25/18 11:52 AM
05/25/18 11:52 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I may have gone 3/16 but the shoulder[on press in jet] would have made it very deep so 3 threads are shallow and 5 are full contact on the set screw.
Re: picked up a 80688 holley 1050 to try [Re: Clanton] #2500287
05/25/18 01:10 PM
05/25/18 01:10 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I personally use 6-32 in brass and 1/8 in length and 8-32 in the same length then the 10-32's are longer of course.......... thumbs
