How much lift can stock hemi heads take? #2499398
05/23/18 11:13 AM
05/23/18 11:13 AM
Northeast Indiana
73DAD Offline OP
73DAD  Offline OP
Northeast Indiana
In short, my cam is too small, want to upgrade. Willing to buy new springs and retainers as well.
I have '70 heads with stock guides and stock-length valves. Can't easily measure retainer to guide clearance unless I take stuff apart. I realize the best you guys can do for me with this question is a quick estimate, and that's fine.
Going to be racing against my brothers, so its a must-win situation...
Re: How much lift can stock hemi heads take? [Re: 73DAD] #2499434
05/23/18 12:25 PM
05/23/18 12:25 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Disregard the current clearance and get what your advisers say is the best cam for your application because if you are willing to change springs that means you are going to take the heads off anyway. When you do that if you find there isn't enough retainer to guide clearance it will be a tiny charge to have a machine shop cut down the guides for clearance.
2011 Drag Pak Challenger
Re: How much lift can stock hemi heads take? [Re: 73DAD] #2499451
05/23/18 01:00 PM
05/23/18 01:00 PM
Northeast Indiana
73DAD Offline OP
73DAD  Offline OP
Northeast Indiana
No adviser to speak of, I built the dumb thing in the first place, but I don't have any notes on what my clearance was with the current cam.
I don't want to disable the car for multiple weeks during the summer, just looking for a rough estimate to pick a cam in a safe range. If it ends up not being compatible with my current retainers and guides, fine, I'll have some machine work done then.
Looking to do the swap over a weekend's time if possible. Not enough space to leave the car all blown apart.
Re: How much lift can stock hemi heads take? [Re: 73DAD] #2499498
05/23/18 02:23 PM
05/23/18 02:23 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
what are the current cam specs?
JAKES AUTOMOTIVE
Re: How much lift can stock hemi heads take? [Re: 73DAD] #2499815
05/24/18 01:57 AM
05/24/18 01:57 AM
New York
polyspheric Offline
polyspheric  Offline
New York
If I don't say anything, am I still wrong?
Boffin Emeritus
Re: How much lift can stock hemi heads take? [Re: polyspheric] #2499818
05/24/18 02:07 AM
05/24/18 02:07 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Originally Posted By polyspheric
More lift is less important in a hemi than a wedge.
A boat ton of duration then? Doesn't NHRA Stock Elim. have to retain stock lift but modified duration? I would get a cam like that! Not only do they run, REALLY GOOD but they sound evil, wicked, mean and nasty!
Re: How much lift can stock hemi heads take? [Re: 73DAD] #2499876
05/24/18 10:06 AM
05/24/18 10:06 AM
an8sec70cuda Offline
I've been told the opposite by people that actually race them. Hemis like a lot of lift.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: How much lift can stock hemi heads take? [Re: 73DAD] #2499882
05/24/18 10:20 AM
05/24/18 10:20 AM
Northeast Indiana
73DAD Offline OP
73DAD  Offline OP
Northeast Indiana
Anybody got a stock head and a loose valve on hand they'd be willing to grab a quick measurement off of?
Re: How much lift can stock hemi heads take? [Re: 73DAD] #2499883
05/24/18 10:24 AM
05/24/18 10:24 AM
73DAD...sorry, the only heads I have on the shelf are MP aluminum.
CHIP
Re: How much lift can stock hemi heads take? [Re: 73DAD] #2499926
05/24/18 12:10 PM
05/24/18 12:10 PM
New York
polyspheric Offline
polyspheric  Offline
New York
There is always some amusing remark about what some individual engine type wants, likes, needs, does. Like which engine "needs a lot of air"?
A great deal of it is "I was told".
Boffin Emeritus
Re: How much lift can stock hemi heads take? [Re: polyspheric] #2499927
05/24/18 12:14 PM
05/24/18 12:14 PM
Amusing remarks...ok. A lot of things should work a certain way in theory, but in reality things are much different.
CHIP
Re: How much lift can stock hemi heads take? [Re: 73DAD] #2500053
05/24/18 04:55 PM
05/24/18 04:55 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Identifying your opponents remarks as "theory" isn't as useful as you suppose.
"People who actually race them": only someone who bought it can fully understand exactly how it works? What a ridiculous thing to say. The owners, and even builders of most cars have only the most elementary comprehension of what's happening inside the engine.
Is "Jupiter is larger than Earth" a theory?
I'd explain, but then I'd be talking to myself.
Boffin Emeritus
Re: How much lift can stock hemi heads take? [Re: polyspheric] #2500073
05/24/18 05:46 PM
05/24/18 05:46 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
Not quite sure I understand the question. We've been racing Hemis for almost 50 years...still running Nostalgia SS with old school stuff, iron heads, cross ram, etc. 426 inches.
Not quite sure what you mean by how much they can 'take'? To give you an idea, we run iron heads, old TRW 12 to one pistons, and the cams we have used over the years have been a variety of rollers, Crane and Racer Brown, usually around .700 lift and 280-285 degrees duration. That was pretty much SOP during the day, and it hasn't changed much in a combo like ours. The SS/AH cars run over .800 lift, but there is a lot of other differences.
Don't know if this helps you or not, but I thought I'd chip in.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: How much lift can stock hemi heads take? [Re: Steve1118] #2500079
05/24/18 05:59 PM
05/24/18 05:59 PM
Northeast Indiana
73DAD Offline OP
73DAD  Offline OP
Northeast Indiana
Thanks for the reply Steve, do you recall if the guides were cut down on heads when you were running cams around .700 lift? For my particular combo I'm looking at SFT cams a shade under .650
Re: How much lift can stock hemi heads take? [Re: 73DAD] #2500104
05/24/18 07:45 PM
05/24/18 07:45 PM
Steve1118 Offline
Steve1118  Offline
We're still running cams about that size, and no, we've never cut down the valve guides. You figure, .750 is about 3/4 of an inch, and the installed height of a Hemi spring is roughly 2 inches, and you'll be fine. Now, we have never used valve seals, most don't for racing applications, so have never run into that. If you are concerned, take the spring off, hold the valve and retainer together, and lower into the guide about 3/4 of an inch. You will be fine, I'd almost bet the ranch on it.
Just be sure to check piston to valve clearance, but if the pistons have reliefs in them you'll probably be OK there. In the old days, with stock pistons, .650 was getting pretty close. Check your spring when compressed and make sure you have no coil bind, but, I don't imagine you will have any issues there, either. But, check it anyway.
But, my thought is that everything will clear just fine.
Re: How much lift can stock hemi heads take? [Re: 73DAD] #2500246
05/25/18 11:22 AM
05/25/18 11:22 AM
Northeast Indiana
73DAD Offline OP
73DAD  Offline OP
Northeast Indiana
I really appreciate the help, Steve. Resources seem pretty scant for these engines despite their notoriety, or maybe I haven't looked in the right places. Every change is a learning experience.
-Thanks, Dan
Re: How much lift can stock hemi heads take? [Re: 73DAD] #2500273
05/25/18 12:20 PM
05/25/18 12:20 PM
Steve1118 Offline
Steve1118  Offline
Technology has really advanced on them. It seems there are two popular camps, the all out race SS type motors, which are incredibly large $$$ and have developed to the point where the garden type Hemi racers can't relate much, big diameter cams, changed valve angles, etc., or there is the pure stock restorers wanting them totally back the way they were stock. Most of the folks writing about them and providing info are real high end developers, or restorers.
Dinosaurs, like me, who are rank and file racers, still racing OEM type versions of the Hemi, are increasingly hard to find, but we're out there. Nostalgia Super Stock, like we do, still has a lot of geezers like me who live for this stuff, and who have loved these motors for decades and still love them. I guess we're like old Harley guys. But, still hooked on them, pound for pound there is nothing like a Hemi. Still the most potent factory produced engine ever. Cantankerous, fidgety, but when right nothing will run with them. We race several, from 650-700 hp 60s style nostalgia motors like ours to the new technology "nostalgia" motors that pump out over 900 hp.
My old friend the late "Bullet" Bob Reed said it best. "There ain't but two kinds of people in this world. Those that have Hemis, and those that want Hemis". It's still that way.
Good resources for the nostalgia Hemi stuff would be the old DC engine manual, or Larry Shephard's HP book "How to Rebuild and Modify Chrysler 426 Hemi engines". You can probably get it on Amazon. He was a Chrysler engineer that was involved in the initial development, and the race teams of the 60s.
Re: How much lift can stock hemi heads take? [Re: 73DAD] #2500290
05/25/18 01:17 PM
05/25/18 01:17 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
drinking
Floyd Lippencott IV
Re: How much lift can stock hemi heads take? [Re: mr_340] #2500302
05/25/18 01:50 PM
05/25/18 01:50 PM
Steve1118 Offline
Steve1118  Offline
Jim, it can still be done. There are a lot of guys racing old school Hemis in NSS, but, if you are starting from scratch it would be hard to match the cost/performance factor of an Indy headed wedge, which is what most guys use. The heads are about as good as the stock, old school Hemi heads. There is still a lot of old school stuff out there, cams, especially that can be had reasonable. Heads are still pretty reasonable, you can get new ones, but the blocks are getting tough. We built a Hemi Dart out of old school stuff we had laying around, basically a 484 inch crate motor, and it runs 9.70s and does a real good job in NSS. We don't have $10K in the whole car. It can certainly be done.
Personally, I think racing one in NHRA Stock/SS is a pipe dream for most. Barton gets 75K for a motor. That's ridiculous. The motors have become so far away from what they were intended to be it's not even funny. Years back, a buddy of mine who works for Chrysler was pushing hard to force them to keep to stock type cross rams, but the big money guys pushed for the sheetmetal intakes, and now, you have to have a 10,500 rpm motor to compete. Most folks who have this 'dream' really have no concept in what it takes to do it. And, you have to have the money to buy EVERYTHING, not just part of it. If you only have 8 of the state of the art stuff when you should have all ten, you are just pissing your money away, will become discouraged and quit soon.
Put your stuff together, run NSS, and have some fun.
Re: How much lift can stock hemi heads take? [Re: 73DAD] #2500314
05/25/18 02:34 PM
05/25/18 02:34 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
If maintenance is an issue I understand that about .630 lift is the current limit for a street cam. Rich Nedbal's book has a great roller cam design in it....Are you wanting flat tappet or roller?
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
