OK, WHO WORKS ON POST-75 AND UP RADIOS #2499253
05/22/18 11:16 PM
05/22/18 11:16 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
Spoke with the member here who works on radios, won't do 75 and up, so who might y'all recommend?
Thanks in advance.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: OK, WHO WORKS ON POST-75 AND UP RADIOS [Re: Magnumguy] #2499257
05/22/18 11:22 PM
05/22/18 11:22 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Probably BigmoneyLewis send him a pm.
Re: OK, WHO WORKS ON POST-75 AND UP RADIOS [Re: Magnumguy] #2499266
05/22/18 11:39 PM
05/22/18 11:39 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I'd consider taking a look at it. If the schematic is available (and it might be - I'd need a model # to find out) there are things that could be checked. What is wrong with it?
Re: OK, WHO WORKS ON POST-75 AND UP RADIOS [Re: Magnumguy] #2499376
05/23/18 10:06 AM
05/23/18 10:06 AM
scratchnfotraction Offline
1factroyradio.com
855 723 4699 sales & tech support
m-f/9a-6p
Re: OK, WHO WORKS ON POST-75 AND UP RADIOS [Re: Jim_Lusk] #2499387
05/23/18 10:44 AM
05/23/18 10:44 AM
S.E.Ohio
S.E.Ohio
I'd say mechanical issues? One needs a volume switch? replaced (may have one), presets don't work on both, and the one needs the tuner fixed, can't dial a station up.
Re: OK, WHO WORKS ON POST-75 AND UP RADIOS [Re: Magnumguy] #2499389
05/23/18 10:44 AM
05/23/18 10:44 AM
S.E.Ohio
S.E.Ohio
Big Money won't work on post 74 radios
Re: OK, WHO WORKS ON POST-75 AND UP RADIOS [Re: Magnumguy] #2499449
05/23/18 12:56 PM
05/23/18 12:56 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I may or may not be able to fix a tuner issue, depending on the cause (I don't have a scope), but I'd take a look at them.
Re: OK, WHO WORKS ON POST-75 AND UP RADIOS [Re: Magnumguy] #2499905
05/24/18 11:10 AM
05/24/18 11:10 AM
S.E.Ohio
S.E.Ohio
I'm sending a PM
Re: OK, WHO WORKS ON POST-75 AND UP RADIOS [Re: Magnumguy] #2506154
06/09/18 04:26 AM
06/09/18 04:26 AM
Washington
billyboo Offline
billyboo  Offline
Washington
You're not saying what the problem is. You can contact me @ 360-427 0513 if you haven't found someone yet.
Bill The Radio Guy
bill@billtheradioguy.com
