Nitrous ? #2498858
05/21/18 11:48 PM
05/21/18 11:48 PM
Indiana
Crabra Offline OP
Crabra  Offline OP
Indiana
OK I am opening my self up here.I have a stock bottom end 318.Thats right cast pistons.What are your thoughts on nitrous would like to run 14.50 index.Goes 15.50 now.I kmow slow
Re: Nitrous ? [Re: Crabra] #2498933
05/22/18 08:37 AM
05/22/18 08:37 AM
crlush Offline
crlush  Offline
Ran a 125hp shot for years on a stock bottom end it ran 14:50 on motor and 13:20 on nitrous, always ran good
Re: Nitrous ? [Re: Crabra] #2498957
05/22/18 09:56 AM
05/22/18 09:56 AM
an8sec70cuda Offline
I wouldn't be scared a bit to spray 125-150 on it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Nitrous ? [Re: Crabra] #2499307
05/23/18 01:21 AM
05/23/18 01:21 AM
Chicago
PurpleBeeper Offline
Chicago
Some people get lucky, others do not. I've always considered a 100hp shot of nitrous about the limit for a stock bottom end, running 93+ octane fuel, good plugs (copper not platinum), excellent fuel pressure & maybe retard the timing a degree or two about the limit for a stock bottom end.
I have run a 150 shot on a stock bottom end, I have to admit....BUT I've also had a bad nitrous backfire that blew the top half of the motor into pieces AND melted another engine when the fuel pump couldn't keep up at the top end of the 1/4 mile (ran lean). My 2-cents...no more than a 125hp max and I think a 100hp shot should drop your 1/4 mile a full second at least on a stock-ish motor.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Nitrous ? [Re: Crabra] #2499444
05/23/18 12:45 PM
05/23/18 12:45 PM
Indiana
Crabra Offline OP
Crabra  Offline OP
Indiana
Thank you all for the advice.
Re: Nitrous ? [Re: Crabra] #2499557
05/23/18 04:58 PM
05/23/18 04:58 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have run 250 shot (Cheater kits) on my bone stock 440 New Yorkers & Newports in the past & even on my 440 Charger before at times with no issues ever. Never blew any of them up. It sure does wake them up. (no quarter mile times, just street sleepers). Just don't use the recommended jetting for the kits. Each car / kit requires it own unique tune & will take a little adjusting to get the plugs looking good.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Nitrous ? [Re: Crabra] #2499800
05/24/18 01:22 AM
05/24/18 01:22 AM
Chicago
Chicago
6pkrtse, all I can say is wow.... I've never even considered a 250 shot on cast pistons. I don't doubt you, but I don't doubt my own grenaded engines either. How many bottles have you run through on those cars that stayed in one piece? Geez, that's a lot of spray on a stock motor. How did you dial them in?
Re: Nitrous ? [Re: Crabra] #2499875
05/24/18 10:03 AM
05/24/18 10:03 AM
There was a member here I remember talking several times about how many bottles he fed through a stock bottom end 440 w/ a 300 hp NOS Big Shot plate system on it and never hurt it. FastMop maybe?
Not a Mopar, but I fed a LOT of bottles through a stock bottom end 5.3 GM LS motor in my old '00 Silverado. It was only a 100 shot, but man did it love it.
CHIP
Re: Nitrous ? [Re: Crabra] #2499979
05/24/18 02:10 PM
05/24/18 02:10 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
250-300HP sounds like alot, but alot is in the tune up. Some people can crack the main webbing on an NA 500 HP 440, and some can blow their ring lands up with a 100 shot. Some factory engines are much loser than others too whistling
