Re: Power window switch problem
[Re: Hemi_Joel]
#2167093
10/03/16 03:25 PM
10/03/16 03:25 PM
Posts: 7,528 Minnesota
Hemi_Joel
Minnesota
I ended up repairing the broken tab with devcon 4 ton plastic epoxy. Besides the broken off tab, I found 1 that was cracked, so I glued that one as well.
I cleaned the switch assembly by putting it in a zip lock baggie with white vinegar, threw that in the ultrasonic cleaner for about 90 minutes and it came out all clean and shiney.
THe tabs in the die cast housing that held the switch in broke off, so I glued it back together with the devcon. I used it sparingly, just 4 globs. So It will be easier to remove next time it needs repair.
Thanks for all the help!
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2170516
10/08/16 07:49 PM
10/08/16 07:49 PM
Posts: 250 Iceland
BadMoonRacer
Iceland
Thank you guys for a very informative post. One of the tabs on my ´66 frame is broken off. I´ll try the epoxy glue. The ketchup advice: I like that!
Ragnar in Iceland
66 Charger, 451, .582" lift, 11" conv. 4.10:1. 4118 lbs 11.75@117 mph on regular Firestone Firehawk radials. Icelandic Champion in MC 2007, 2008, 2009 and 2022.
