04 dodge , cummins no crank #2497430
05/18/18 02:13 AM
05/18/18 02:13 AM
gulfport, ms, west mi
rowin4 Offline OP
rowin4  Offline OP
Went down to the hardware store, came back out , turned the key, nothing. got dash gauges,dings when the key is on , lights. Turning the key to start nothing changes, no dimming, no clicks. Got it towed home. Figured it was the ignition switch , changed out the electrical unit. Nothing changed. Good batteries , clean and tight cables, could the starter just stop working????? but there is no draw on the system when the key is turned to start. Where to look next?
Re: 04 dodge , cummins no crank [Re: rowin4] #2497455
05/18/18 05:55 AM
05/18/18 05:55 AM
Guitar Jones Offline
Auto or stick? Does it have anti theft?
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 04 dodge , cummins no crank [Re: rowin4] #2497489
05/18/18 11:44 AM
05/18/18 11:44 AM
rowin4 Offline OP
rowin4  Offline OP
It's a auto trans. anti theft ? right now I wish someone would. If your talking about the key thing , no. Same key since new.
Re: 04 dodge , cummins no crank [Re: rowin4] #2497544
05/18/18 01:56 PM
05/18/18 01:56 PM
rowin4 Offline OP
rowin4  Offline OP
checked all the fuses in the fuse relay box under the hood, starter wire tight, ?????? Need to check connections under the fuse / relay box
Re: 04 dodge , cummins no crank [Re: rowin4] #2497578
05/18/18 03:41 PM
05/18/18 03:41 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I had the same issue with my 07 6-speed. "No bus", the connection between the cab and the engine compartment gave up the ghost. Took a long time to find, had to replace wiring and the main connectors. My 04 automatic truck was a Laramie and had a bus issue also. I would get a message on the dash that said "no bus", but it would always come out of it after a while. May have something to do with the junk TIPM too. work
JB Rhinehart, Realist
A-Body's RULE!
Re: 04 dodge , cummins no crank [Re: Rhinodart] #2497650
05/18/18 07:20 PM
05/18/18 07:20 PM
Palm Coast, FL (near Daytona B...
Blown_Hemi Offline
Blown_Hemi  Offline
Starter relay under the hood. Try swapping them around with the horn or trailer relay.
Ask me my opinion of Frank Mitchell....... A Mopar crook!
Re: 04 dodge , cummins no crank [Re: rowin4] #2497707
05/18/18 09:57 PM
05/18/18 09:57 PM
rowin4 Offline OP
rowin4  Offline OP
Well I have some good news and some bad news. The good news is I got it started and running, the bad news is I don't know what I did to make it start. I swapped around a lot for fuses, relays everything that had anything to do with the start and run sequence. I opened and closed a bunch of plugins, looked at a lot of wires, didn't find any corrosion anywhere. I even pulled the starter and had it checked , still nothing. Then after some more probing it started and runs. This makes me a little leery as if it happens again i'll be out in the middle of nowhere with no idea of what to look for again. Thanks for everyone for your input
Re: 04 dodge , cummins no crank [Re: rowin4] #2502281
05/30/18 03:33 PM
05/30/18 03:33 PM
BC Canada
O
ogopogo Offline
ogopogo  Offline
O
BC Canada
My 05 started doing this and it was the contacts inside the starter worn out fyi.......cheap easy fix
