Page 21 of 22 1 2 19 20 21 22
Re: Let the Hemi swap begin [Re: AlexP] #2233632
01/13/17 06:22 PM
01/13/17 06:22 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Ariel you should be golden. Alex and I were in the same boat with our versions of the Gold box. I guess mine making it 3000 miles before failing is just a testament to my anal grounding strategies.
Mopar to the bone!!!
Re: Let the Hemi swap begin [Re: AlexP] #2289966
04/18/17 11:49 AM
04/18/17 11:49 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
A good friend of mine from here came all the way from Greece to help me finish up the proper wiring of the car.
We ran a 4g welding wire from the (-) post of the battery all the way to the PS kick panel. Now all of my dash electronics will go directly to there and my ms3 box will ground to the same point also. All of the grounds on the car will be tied together and overdone. My ms3 gold box also gets power directly from the battery.
If you've got a battery in the trunk, power things directly and over do your grounds. You will lose your hair otherwise. I can't stress what Monte_Smith and others have said repeateldy. Buss bars are your friend!
I've got to backtrack once again and bench test my injectors and injector drivers to make sure I've properly fixed the issues. Something about running at 8:1 AFR isn't comforting and I'd like to avoid it.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Let the Hemi swap begin [Re: AlexP] #2290759
04/19/17 11:03 PM
04/19/17 11:03 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
You want the MS3 ground and positive direct to battery post.
Re: Let the Hemi swap begin [Re: AlexP] #2405792
11/19/17 02:56 AM
11/19/17 02:56 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Its about that time of the year that I update.
I reached a crossroads with the car. MS3 box was back in after some issues that I caused, and I wanted to rip off the vinyl top and paint the roof black.
Easier said than done, my roof under the vinyl top was solid bonds and pop rivets. Some waste of space threw a vinyl top over that mess sometime in the past.
I cut the roof off and I'm prepping a donor roof to go on. Not digging into a full restoration by any means, just throwing the roof and a new deck filler in and getting a bad paint job on the car.
After that, the Hemi action will start again. I started in July, and a bad work schedule has only let me make limited progress. I bought a Miller 211 welder, taught myself how to weld sheet metal and all the tools I need.
Re: Let the Hemi swap begin [Re: AlexP] #2405846
11/19/17 10:03 AM
11/19/17 10:03 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
There never done, Thanks for the update
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Let the Hemi swap begin [Re: AlexP] #2406657
11/21/17 03:44 AM
11/21/17 03:44 AM
houston texas
gremlinsteve Offline
houston texas
Good to hear Alex
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: Let the Hemi swap begin [Re: AlexP] #2496082
05/14/18 06:22 PM
05/14/18 06:22 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Roof is still off while I fix rust. Nothing exciting to report.
The car will go the body shop for paint in a month, and then I expect things to get better.
Re: Let the Hemi swap begin [Re: AlexP] #2496114
05/14/18 07:32 PM
05/14/18 07:32 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Nice to see more threads blog style on here. don't be a stranger smile
Rich H.
Esse Quam Videri
Re: Let the Hemi swap begin [Re: AlexP] #2496873
05/16/18 04:58 PM
05/16/18 04:58 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I've been lurking on ih8mud.com for my land cruiser daily driven build. I've got a huge post going there: https://forum.ih8mud.com/threads/my-fj60-project-thread.904068/
I'm daily driving a classic truck with 300,000 miles on it and it just makes me miss my hotrod more. I will likely just have these two cars in daily driven rotation.
The plan is to get the bugs worked out of the old car and start driving it the way I'm driving this. Road trip and power tour type stuff.
If my carb'd, 4 speed with no OD, 300,000 mile, 11mpg cruiser can do 15,000 miles a year...the EFI roadrunner with a modern engine should be able to knock it out no problem.
Re: Let the Hemi swap begin [Re: AlexP] #2496881
05/16/18 05:11 PM
05/16/18 05:11 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
This is the 70 Roadrunner that gave its roof. Abandoned after Katrina down in Louisiana, everything has been stripped.
The older gentleman wanted $100 as is. No vin or title. I just wanted the roof and I've got nowhere to store it, so after I cut the roof off, it was crushed. I felt sad, but it was a goner and it is donating the roof and some of the complex patch panels that mine needs.
He also had a pretty awesome blown Hemi Roadrunner.
Re: Let the Hemi swap begin [Re: AlexP] #2502805
05/31/18 06:28 PM
05/31/18 06:28 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
After sitting for quite a while, I'll be dropping the tank to see how well stabil keeps ethanol 93 and cleaning it out. Another 2 weeks before I'm back in the country from travels to get the car moving again. The life of a nomadic blue collar worker.
After that, I'll drive it onto the trailer and take it to get the roof replaced and body work.
Re: Let the Hemi swap begin [Re: AlexP] #2612427
01/26/19 03:34 AM
01/26/19 03:34 AM
808CUDA Offline
808CUDA  Offline
Alex,
Been away for some time and looking to do a similar swap as yours except witha 6.4/392 Hemi crate engine with a 23 spline four speed. I couldn’t find any mention as to what pilot bearing you used. I did see you cut the input shaft 1/2”. Thanks
Re: Let the Hemi swap begin [Re: AlexP] #2612541
01/26/19 01:41 PM
01/26/19 01:41 PM
southwest Alabama
challenger73400 Offline
southwest Alabama
Wow!Just read through the whole thread, I'm impressed! Thanks for posting all the hurdles and how you've over came them. There's no telling how many people you've helped. Including me!
Re: Let the Hemi swap begin [Re: AlexP] #2613252
01/27/19 10:54 PM
01/27/19 10:54 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I’ve had a major update today.
I’ve agreed to let someone fix the rust.
Things will get better now. After the body is sealed up, wire the autometer dash reinstall the fuel tank and put my rear discs on.
Then, lots of efi tuning.
Re: Let the Hemi swap begin [Re: AlexP] #2613396
01/28/19 09:17 AM
01/28/19 09:17 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
I have read every word of this thread ….twice...Thank you.
Re: Let the Hemi swap begin [Re: AlexP] #2613541
01/28/19 03:27 PM
01/28/19 03:27 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I’ll get back to the detailed articles when I’m at that point. I’ve really enjoyed cataloging all this stuff.
Re: Let the Hemi swap begin [Re: AlexP] #2613579
01/28/19 04:37 PM
01/28/19 04:37 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
your thread, Goodie's thread and a few other I reference and send people to.
Re: Let the Hemi swap begin [Re: AlexP] #2613620
01/28/19 06:39 PM
01/28/19 06:39 PM
IL
furious70 Offline
furious70  Offline
IL
Are there any major changes or advancements that have been made in recent years however? I like reading these threads from the trendsetters and pioneers but I wonder how much of it has been solved by this or that part number now offered?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Let the Hemi swap begin [Re: AlexP] #2614594
01/30/19 02:33 PM
01/30/19 02:33 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I don't believe so. I know that the VVT 5.7 and 6.4 are getting easier to swap, which means that the hellcat motor will be easier also.
I think the core choices for EFI and such have pretty much stagnated. I bet the majority of innovations will be valve covers and detail stuff from here on. I do see rocker stuff happening, but that is only needed in the most extreme of circumstances.
Re: Let the Hemi swap begin [Re: AlexP] #2614885
01/31/19 02:13 AM
01/31/19 02:13 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I can provide e-MS3-tuning support wrench
I've spent way too many hours sifting through logs and making changes that I have gotten pretty decent at it. yellow
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
