904/727 behind a 5.7
#2496494
05/15/18 03:27 PM
05/15/18 03:27 PM
Posts: 1,550 Michigan
Kiddart
I know its not a direct bolt up but what is needed to go with a 727 and a 904 to a 5.7.
Thank you Kiddart
Re: 904/727 behind a 5.7
[Re: Kiddart]
#2496542
05/15/18 05:12 PM
05/15/18 05:12 PM
Posts: 2,045 MD
RTSE4ME
MD
[Re: Kiddart]
#2496655
05/15/18 09:44 PM
05/15/18 09:44 PM
Kiddart
and that was it? Cool no spacers for the convertor? last question for tonight. is there a list of required items to have on hand or that are needed. I have seen one but cant seem to find it as always
Thank you Kiddart
[Re: Kiddart]
#2497301
05/17/18 06:28 PM
05/17/18 06:28 PM
Posts: 25,796 Rio Linda, CA
John_Kunkel
Rio Linda, CA
It seems that a lot of folks were bolting up the trans without the spacer until somebody discovered that the 5.7 crank flange extended further from the block than the LA/Magnum.
[Re: Kiddart]
#2497326
05/17/18 07:52 PM
05/17/18 07:52 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I put a straight edge across a crank flange on both a 5.9 mag and a 5.7 hemi and the 5.7 crank mounting surface does not go out as far on the 5.7 so a spacer would make things worse not better all else being the same.
The hemi does use an 8 bolt plate instead of a 6 bolt SB pattern and the 5.7 has the same 8 bolt pattern as a 4.7. Seems like you could use the 4.7 or 5.7 flex plate and just take off the starter ring gear on the converter. Edit At least on a 727 as the ring gear is the same diameter.
[Re: Kiddart]
#2497435
05/18/18 02:32 AM
05/18/18 02:32 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
You can buy flexplate from mancini for $70. With one of my torque converters i needed to make a spacer, changed converter than didn't need a spacer. Changed trans and another converter and didn't need a spacer. Mock it up outside the car first
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
