Engine vibration 383 4 spd (Fixed)
#2495234
05/12/18 08:19 PM
05/12/18 08:19 PM
Posts: 1,385 Az
69hemibeep
Az
Not going to do what I first posted bad idea just thinking out loud. Vibration 27-2800 rpm and up.
1969 Hemi Roadrunner 2nd owner
Re: Engine vibration 383 4 spd
[Re: 69hemibeep]
#2495257
05/12/18 09:05 PM
05/12/18 09:05 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
That is a REALLY bad idea. Please describe when, how you're getting a vibration. If you have eliminated ALL other possibilities (there are many), and you are down to JUST the engine as a whole and the pressure plate, then drop the transmission & take the flywheel and pressure plate to a shop that does balancing. Have a shop balance both separately & tell you how much they had to add/delete from each.
Your problem might be as simple as a harmonic balancer....7 bolts & done.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: 69hemibeep]
#2495379
05/13/18 02:08 AM
05/13/18 02:08 AM
Posts: 1,385 Az
69hemibeep
Az
I'm trying to push it back to the engine builder. It starts at about 3000 rpm in neutral or in any gear and standing still. Engine was complete with fly wheel and pilot bushing I added the clutch, trans and drive line.
[Re: Dave Hall]
#2495412
05/13/18 09:13 AM
05/13/18 09:13 AM
Posts: 7,664 IN
ahy
IN
If you want to check engine only, need to pull the transmission, support the engine and fire it up. Agree do not try to run it with clutch loose.
In the spirit easy things first, what about the damper (balancer)? SB and BB sometimes use a counterweight damper and sometimes not. Plus there are different amounts of imbalance used depending on how the engine is set up. If the vibration damper is not matched that could cause this problem.
[Re: 69hemibeep]
#2495420
05/13/18 09:57 AM
05/13/18 09:57 AM
Posts: 960 Chicago
PurpleBeeper
Chicago
Pilot bushing does sound like a possibility....or motor mount.... or 1/2-dozen other things. I know you are probably pissed, but take a moment and breathe.
a. Check all the easy stuff & just deal with it. Priority #1 is to drive the car, right? Balancer, motor mounts, transmission mount, one plug wired popped off, bad plug, cracked distributor cap, other?
b. phase #2 is pull the transmission. You cannot push it back on the engine builder unless you have absolute proof that you did everything 100% correct yourself. Pilot bushing/bearing, pressure plate balance, transmission bearings/bushings, etc.
[Re: PurpleBeeper]
#2495440
05/13/18 10:37 AM
05/13/18 10:37 AM
Posts: 1,385 Az
69hemibeep
Az
It is a brand new restoration so everything is fresh. I'm going to have it on the ground today for a better drive. When I first fired it and at break in 2000 RPM all is good but then I revved it a bit higher and it shook. I figured I'd put it off and finish the car and address issues after completion. I took it around the block from the alignment shop to my trailer and was not pleased to say the least. I was skeptical about the engine when it arrived all the screw in block plugs water and oil were loose and a nut laying in the valley pan, not how I do things. I needed to step back blow some steam and get after it, I'm sure I'll get stuck finding the problem anyway.
[Re: 69hemibeep]
#2495493
05/13/18 01:19 PM
05/13/18 01:19 PM
Posts: 2,366 Banana Republic
FM3AAR
Banana Republic
I had vibration problems on a new motor install also. Turned out to be the Centerforce DF clutch that I added. I pulled the transmission, removed the clutch and fired the motor. Was smooth as silk confirming that it was the Centerforce. Just a thought if you went that brand.
“You’ll own nothing” — And “you’ll be happy about it.” K. Schwab
[Re: 69hemibeep]
#2495536
05/13/18 02:33 PM
05/13/18 02:33 PM
Posts: 43,240 Bend,OR USA
Cab_Burge
I have all my flywheels and clutch pressure plates balanced with the crankshaft assembly on any stick shift motors I build That being said look very closely at your flywheel and pressure plate to see if there are any balancing holes in the flywheel and any weights welded onto the pressure plate Is your motor a BB or SB? What size clutch and flywheel? Is there any big holes drilled or machined into the engine side of the flywheel? If so that flywheel was intended to be used on a external balanced Mopar motor
[Re: DAYCLONA]
#2495540
05/13/18 02:38 PM
05/13/18 02:38 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
Yeah, I'm with Dayclona on this one....might just have a spark plug wire fall off. And I hate to say it, but just about every tine I've rebuilt/installed a motor, there was "something" I missed...often 2 or 3 things....forget to tighten a hose clamp completely, not hook up the field wires on the alternator..."something"....you will get there brother, don't worry. Try the easy stuff first.
[Re: 69hemibeep]
#2495592
05/13/18 04:45 PM
05/13/18 04:45 PM
Posts: 1,385 Az
69hemibeep
Az
Took it for a good drive. It shakes the car moving or not from about 27-2800 RPM all the way up, getting to warm out to mess with it so until tomorrow I will get on the basics. This and a good detail and its ready to deliver.
[Re: FM3AAR]
#2495717
05/13/18 10:54 PM
05/13/18 10:54 PM
Posts: 298 mt. pleasant, PA
Diplomat440
mt. pleasant, PA
I had vibration problems on a new motor install also. Turned out to be the Centerforce DF clutch that I added. I pulled the transmission, removed the clutch and fired the motor. Was smooth as silk confirming that it was the Centerforce. Just a thought if you went that brand. I have the same problem with my centerforce dual friction. My weights get stuck off center once in awhile and i have to reach in and push em around.
[Re: 69hemibeep]
#2496532
05/15/18 04:59 PM
05/15/18 04:59 PM
Posts: 1,385 Az
69hemibeep
Az
Fixed. Damper balanced by said machine shop, I had one for another project the shakes are gone.
