Page 1 of 3 1 2 3
electric fans #2494849
05/11/18 06:29 PM
05/11/18 06:29 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
whats everyone using on puller 16" fans around 2800-3000 cfm?
Re: electric fans [Re: RustyM] #2494854
05/11/18 06:50 PM
05/11/18 06:50 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
SPAL makes a nice product. I'm sure there are others.
Re: electric fans [Re: RustyM] #2494928
05/11/18 10:26 PM
05/11/18 10:26 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
I've had one of these, good fan - http://www.zirgo.com/
Re: electric fans [Re: RustyM] #2494979
05/12/18 01:33 AM
05/12/18 01:33 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I also like Spal fans
"Just a Bracket car dressed up like a streetcar"
Re: electric fans [Re: RustyM] #2495088
05/12/18 01:57 PM
05/12/18 01:57 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I bought a Spal,great product! The mounting straps are genius!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: electric fans [Re: RustyM] #2495092
05/12/18 02:06 PM
05/12/18 02:06 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
I bought a derale for my car. Made night and day difference over cheap parts store fan that was on the car when I bought it.
Spal and derale both good fans. I found the better fans that have good motors pull 20+ amps. If they aren't pulling that many amps and have good CFM ratings, run. They won't cut the mustard
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: electric fans [Re: hemi-itis] #2495098
05/12/18 02:11 PM
05/12/18 02:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats the purpose for it.. race only or street
strip..big flow fans draw big amps
wave
Re: electric fans [Re: RustyM] #2495108
05/12/18 02:22 PM
05/12/18 02:22 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
If I had the money I would run some delta pag fans, they look very trick.
Since I don't I run a set of dual fans from a dodge intrepid. They have a high and a low speed and have worked well even though my radiator is a little undersized.
68 Barracuda Formula S 340
Re: electric fans [Re: MR_P_BODY] #2495148
05/12/18 03:25 PM
05/12/18 03:25 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
its for the 72 duster bracket car Mr P.
would like to stage/leave at 160-165 degrees and be able to cool back down well.
Re: electric fans [Re: RustyM] #2495162
05/12/18 04:07 PM
05/12/18 04:07 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
SPAL on all my cars.
Re: electric fans [Re: RustyM] #2495166
05/12/18 04:20 PM
05/12/18 04:20 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
HHR..............Blows lots of air and it's built in shroud fits nicely on my 26" Griffin radiator............ beer
Re: electric fans [Re: Thumperdart] #2495178
05/12/18 05:11 PM
05/12/18 05:11 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
hmmmm
Re: electric fans [Re: RustyM] #2495181
05/12/18 05:20 PM
05/12/18 05:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If this is a street car I use the HHR fan also
fits my rad perfect
wave
Re: electric fans [Re: RustyM] #2495211
05/12/18 07:21 PM
05/12/18 07:21 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
I wonder if I can adapt that to my radiator shroud??
sure save some money.
I need 2800 to 3000 cfm for the 4 core radiator.
Not putting car on street at this time but, who know later,,,,,
Re: electric fans [Re: RustyM] #2495218
05/12/18 07:39 PM
05/12/18 07:39 PM
Brisbane Australia
crash520 Offline
crash520  Offline
Brisbane Australia
What’s good out there for a 22” radiator guys please
Re: electric fans [Re: RustyM] #2495394
05/13/18 04:56 AM
05/13/18 04:56 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
FWIW, I bought some 13" Be-Cools fans when Summit was running a sale. They are SPAL fans with the mounting strap kit.
I had a Champion 4-core radiator (4 x 0.63" tubes, core 2.75" deep.) The thickness of the radiator made it difficult for clearance to the water pump. Edited: tank width per spec sheet is 3.2" wide.
I changed to a Griffin (2 x 1.25", 2.68" deep core, tanks are about same width as core) exact fit radiator (about 1/2" more water pump to radiator clearance), and I used two 13" Be-cool (SPAL) fans (2" deep, 1200-1250 cfm each) on 26" radiator in '69 Coronet with 440 engine.
Re: electric fans [Re: RustyM] #2495550
05/13/18 02:51 PM
05/13/18 02:51 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
RustyM my two cents would be build the tool for what you want to do now. Weight on the nose of a 10sec bracket car is evil and just makes it harder to get the car to work.
Re: electric fans [Re: Just-a-dart] #2495712
05/13/18 10:47 PM
05/13/18 10:47 PM
Texas
RustyM Offline OP
RustyM  Offline OP
Texas
Good point.
I’m actually thinking about dropping the 4 core for a 3 .
Won’t need quite as much fan that way and loose some weight on both.
Re: electric fans [Re: RustyM] #2496734
05/16/18 01:43 AM
05/16/18 01:43 AM
Medina, OH
dart440_72 Offline
dart440_72  Offline
Medina, OH
I had an HHR fan on mine, but recently switched it out. I am using a dual fan setup from a Ford Contour. Works really well. I like it a lot better than my HHR fan
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: electric fans [Re: RustyM] #2497102
05/17/18 09:30 AM
05/17/18 09:30 AM
Maryland, USA
Raymond Offline
Raymond  Offline
Maryland, USA
PM me.I have a brand new champion 16 inch
with shroud for a 22 inch core that
I am not using.
Page 1 of 3 1 2 3
