Adding power steering to 70 Challenger RT #2495110
05/12/18 02:26 PM
05/12/18 02:26 PM
Carpinteria, Ca
hotcidr Offline OP
hotcidr  Offline OP
Carpinteria, Ca
Does anyone have a complete parts list for what I need to add power steering to me 70 Challenger as well as a recommendation for best source for the parts
thanks
Re: Adding power steering to 70 Challenger RT [Re: hotcidr] #2495145
05/12/18 03:22 PM
05/12/18 03:22 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
If originality isn't important Borgeson sells a kit that includes pump/brackets/hoses/steering gear. It's around $1100, Maybe Bergman Auto Craft would offer it a little cheaper.
http://www.borgeson.com/xcart/product.php?productid=1796&cat=143&page=1
Re: Adding power steering to 70 Challenger RT [Re: hotcidr] #2495230
05/12/18 08:14 PM
05/12/18 08:14 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Don't forget the steering column is different too.
Re: Adding power steering to 70 Challenger RT [Re: hotcidr] #2495324
05/12/18 11:46 PM
05/12/18 11:46 PM
Chicago
PurpleBeeper Offline
Chicago
I just did this swap on my 70 RR.
1. steering box - wherever you can find one. I got autozone.
2. pitman arm - autozone
3. p/s pump - autozone
4. steering coupler - can't remember, Mancini? Megaparts?
5. p/s pump pulley - online somewhere
6. belt - autozone
7. p/s length column shaft. probably on this site since many people are switching power to manual. The power steering CENTER SHAFT is the only part you need, or you can buy a whole column if you want to.
8. p/s pump bracket..online somewhere
9. hardware store bolts
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Adding power steering to 70 Challenger RT [Re: PurpleBeeper] #2496019
05/14/18 03:41 PM
05/14/18 03:41 PM
Slantytown
DUFFMAN Offline
Ask And Ye Shall Receive
DUFFMAN  Offline
Slantytown
A reman steering gear will be missing the pressure relief valve and pressure hose adapter fitting (if 1970 used one). Those you will likely have to source from eBay or a junkyard. Make sure you use a factory fitting, the ID may differ from an off the shelf fitting. I ran into this when I converted my 1972 B-Body.
8. p/s pump brackets..online somewhere
I got a junkyard unit from a local you pull it, took the brackets and pulley off and used the JY pump as a core for a reman.
For these I bought a junk column off a member here that was in the swap area. I have an NOS coupler kit I bought at a local swap meet, but I think you can still get the kit through a Chrysler dealer.
The mounting bolts for the gear are the same and can be re-used. You'll collect the bolts for the pump when you pull a junk yard unit.
I ddi this conversion on my 1972 B-body two years ago. I'm not sure how different a 1970 E-body would be, but I don't think there's much. I do have the k-frame from a 1970 Challenger in my car, so I know the gear mounts the same. Feel free to PM me questions.
No longer taking $h!t from anyone!
Re: Adding power steering to 70 Challenger RT [Re: hotcidr] #2496469
05/15/18 02:47 PM
05/15/18 02:47 PM
Carpinteria, Ca
hotcidr Offline OP
hotcidr  Offline OP
Carpinteria, Ca
Thank you for all the help
Ray
Re: Adding power steering to 70 Challenger RT [Re: hotcidr] #2496806
05/16/18 12:02 PM
05/16/18 12:02 PM
Winlock, Wa
fshd4it Offline
fshd4it  Offline
Winlock, Wa
Several years ago my friend changed his '74 challenger from manual to power. His manual steering shaft had a dimple, up from the roll-pin hole, that lined up perfectly for a power coupling/box. Removed the column, drilled the hole, and cut the end off the shaft. Done. Hope you are as lucky as he was.
In order to know what you want, you'll probably have to find out what you don't want.
Re: Adding power steering to 70 Challenger RT [Re: hotcidr] #2496933
05/16/18 07:46 PM
05/16/18 07:46 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Thank You for that beer
Re: Adding power steering to 70 Challenger RT [Re: Ply72rr] #2497032
05/17/18 12:26 AM
05/17/18 12:26 AM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
The Borgeson box for those who want to step into modern steering is the way to go along with my direct bolt in coupler and hydraulic fittings. No cutting your column.
Re: Adding power steering to 70 Challenger RT [Re: hotcidr] #2504933
06/05/18 06:56 PM
06/05/18 06:56 PM
Carpinteria, Ca
hotcidr Offline OP
hotcidr  Offline OP
Carpinteria, Ca
I ended up ordering the Bergman ps system. You can talk directly with the owner. He uses the Borgeson box however you DO NOT HAVE TO cut the steering column as his kit includes a part for direct connection. This was such an easy installation with all correct parts and pieces and nothing else needed
