Page 3 of 3 1 2 3
Re: Batteries and battery tenders - not a good idea? [Re: 67SATisfaction] #2494907
05/11/18 09:36 PM
05/11/18 09:36 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
I use the deltran battery tender on the Duster and my Truck which I don't use so much in the winter.
The Duster's battery is 10 years old this month (Autocraft Silver) and tested at 535cca (525cca rated)
My Truck's battery is 7 years old (autocraft gold) and tests at 618cca (625cca spec).
I can't complain. I also use it on my lawnmower battery.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Batteries and battery tenders - not a good idea? [Re: pittsburghracer] #2494945
05/11/18 11:12 PM
05/11/18 11:12 PM
5thAve Offline
5thAve  Offline
Originally Posted By pittsburghracer
I didn’t even read all these posts because this has been discussed so often. There is not reason other than laziness to leave a battery tender on for extended amounts of time. Get of your lazy butt once in awhile and put it on and take it off the next day every 2-3 months. This also gives you a good chance to burn a few calories and check things over. If reading a few nightmare stories about fires from these things doesn’t bother you, it should.
That's pretty much what I do. Disconnect the battery and charge it once or twice over winter.
Re: Batteries and battery tenders - not a good idea? [Re: 67SATisfaction] #2494968
05/12/18 12:49 AM
05/12/18 12:49 AM
KY USA
mopargem Offline
mopargem  Offline
KY USA
My late father always used tenders on the four batteries on his houseboat and funny thing just the opposite occurred, he was always replacing them. Seemed to never last more than 3-4 years at most so I have no faith in battery tenders not to mention the fire hazard. I just start my cars if not driven or occasionally put a charge on them and I get good life. Same thing for my other equipment. The battery in my Kubota tractor lasted about ten years and most of the time that machine sat. It’s just more over rated BS just like a lot of things marketed to brain wash us. Another example is synthetic oil. My cars get conventional oil and my work vans always last me many years and well over 200k miles before replacement. It’s just all part of the feel good thing doing all the extra unnecessary BS. But this is my experience and opinion and of course other results may vary and are open to debate laugh
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: Batteries and battery tenders - not a good idea? [Re: 67SATisfaction] #2495005
05/12/18 08:18 AM
05/12/18 08:18 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
I have a battery disconnect that I use when not driving the car to avoid any draw. Winter time it goes into a boat storage bin in the closet. Check the voltage once a month and see if it needs charged. Brand new battery, so trying this vs leaving it in the storage unit all winter.
Re: Batteries and battery tenders - not a good idea? [Re: pittsburghracer] #2495121
05/12/18 02:37 PM
05/12/18 02:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted By John_Kunkel
Depends on how much "parasitic draw" the car has. I have only one car with no parasitic draw and it'll start right up after sitting for months. All of my other cars have devices that draw milliamps when sitting idle and eventually the voltage drops enough to cause starting problems.
I use the Schumacher SE-1-12S onboard chargers.
So take a battery cable off. Zero draw.
Then you lose the whole purpose of those devices.
Re: Batteries and battery tenders - not a good idea? [Re: 67SATisfaction] #2495382
05/13/18 02:20 AM
05/13/18 02:20 AM
WA
tman Offline
tman  Offline
WA
That is what I used to do was disconnect the cable, then got a shutoff switch, but battery life was horrible. Sulfate sets in being dormant. This is leaving it in my car in the garage. Could be in other climates your battery life can be longer by just disconnecting. Zero draw does not work for me. I live in WA state, and don't know why I had terrible batt life until I got the Batt Tender. My current batt has lasted 8 yrs strong. That's the longest ever for me.
Re: Batteries and battery tenders - not a good idea? [Re: 67SATisfaction] #2496230
05/15/18 12:02 AM
05/15/18 12:02 AM
Albany, NY
67SATisfaction Offline OP
The member whose name is actually Art
Albany, NY
Thanks all,
Good info to absorb. I'm chucking the tenders. I still won't leave my batteries in the cars over the winter, but it's easy to check voltage thru the winter, and use a light 2A charge only if needed.
Only one car has significant parasitic draw to maintain memory functions, but it has its own dedicated tender. The rest are old and I only lose the radio presets in a complete power-off.
All my batteries have lasted me over 5 years, one is 8, with minimal maintenance, just a quick freshen-up charge in the spring.
One of the reasons I tried the tenders was because my one, expensive, vintage red-cap sulfated in less than 4 years. That one I treated the same as the others, taking it out and leaving it alone all winter.. but it was a true cap battery, needed to have distilled water level checked and charged and filled, specific gravity checked, etc.. and I kept after it real good too.
I bought two yellow-cap maintenance-free vintage repops, and they have been OK. One is 6 years and getting weak.. but neither one cooked any acid out on the battery tenders this winter.
Cheers,
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Batteries and battery tenders - not a good idea? [Re: 67SATisfaction] #2496395
05/15/18 12:24 PM
05/15/18 12:24 PM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
Wasn't it a charger or tender that caused the unfortunate incident in Rhinos garage?
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Page 3 of 3 1 2 3
