Page 165 of 180 1 2 163 164 165 166 167 179 180
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2493861
05/09/18 08:24 AM
05/09/18 08:24 AM
fullmetaljacket Offline
101st airborne parachuting into the winners circle.
Detachable I gather?
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2493967
05/09/18 02:49 PM
05/09/18 02:49 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Yes,can't block the plate readers,it's illegal.......LOL whistling
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2493977
05/09/18 03:09 PM
05/09/18 03:09 PM
You owe that many parking tickets that you're afraid of the Marshal coming to get the car? LOL
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2494125
05/09/18 09:58 PM
05/09/18 09:58 PM
State of confusion
Thumperdart Offline OP
State of confusion
Here's a unique and functional way to remove wt. from up front........I'm testing the twin blade 4150 stuff from GET'M Garage that Mark W. has posted pics of and they are a few pounds lighter than a Dommy and my initial testing is proving how bad azz these are. I will track test asap and they range from 600 cfm up to 1600 and these puppy's are taking over and winning races............ thumbs beer
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2494219
05/10/18 01:23 AM
05/10/18 01:23 AM
hemi-itis Offline
hemi-itis  Offline
Getting closer to the SV1..........
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2494223
05/10/18 01:32 AM
05/10/18 01:32 AM
Colorado
Bob J Offline
Bob J  Offline
Colorado
You guys are a bad influence, I'm just saying. I lost a 1/4 LBS on the headlight buckets. Lost a few pounds on the pedal assy. After welding up the steering column that was flexing bad without anything bolted to it. You straight line guys may not worry about this but I do but I'm trying to hit over 1g in the turns.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: Real world weight loss program and it` cost.......... [Re: Bob J] #2494225
05/10/18 01:38 AM
05/10/18 01:38 AM
What's up with the aluminum floor sound/heat shield covering? That there looks like it adds all the weight back in. Is that correct?
Huge exhaustive effort on the holes and neat, but it gets the job done.
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2494232
05/10/18 02:16 AM
05/10/18 02:16 AM
State of confusion
State of confusion
Closer but by design, they signal way differently and so far, I'm possibly pitching Dominators and running these based on initial testing but the track will tell the story........ beer
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2494268
05/10/18 08:27 AM
05/10/18 08:27 AM
Do you mean Ditching the dominators......?
And these are lighter by design as well?
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2494270
05/10/18 08:40 AM
05/10/18 08:40 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
You'll like the story they will tell at the track
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2494351
05/10/18 12:24 PM
05/10/18 12:24 PM
hemi-itis Offline
hemi-itis  Offline
That would cool if they work out,better than a Dom???Better than an SV1?? If I ever hit lotto I will be able to go EFI,'till then I have stick with what I have.I am confident I will achieve my legal limit and then just maintain what I have.It's been a very long road!
Best of Luck on the new style carb Dominic! The Dominator is not going away any time soon work
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2494352
05/10/18 12:28 PM
05/10/18 12:28 PM
Colorado
Bob J Offline
Bob J  Offline
Colorado
Yes the insulation adds weight but I melted and pair if tennis shoes driving one of my old hotrods so there so there needs to be some heat shielding. This was put in years ago before the project was side tracked and the car was just a Promod build. Yep I started to play with Porsche for a number of years and the car was just sitting unfinished. Then I started to run SCCA Solo II with the Porsche and before you know it the old stalled project is now being built for Cam T class.
If you look you can see the Holley HP controller mounted to the firewall to move the weight back plus keeping it cooler. There is a Classic air A/C box next to it That is lighter but with the Sanden compressor it adds a little weight. With this in mind that is why my target weight is between 3300 and 3400 lbs and not lower. The car started life weighing between 3700 and 3800 lbs and the first 200 lbs was easy and I'm now looking for the next 200 lbs. I'm weighing parts and using the lighter one. I'm just not trying lighten the car but move the weight around for a better corner weight balance.
Edit: Both of the weight loss up front and high up and I moved the weight down low so a win with comfort.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2494393
05/10/18 02:16 PM
05/10/18 02:16 PM
State of confusion
State of confusion
If it runs as good, yes I will drive and race these cos they are bad azz so far and throttle response like is nothing else......... boogie drive
Re: Real world weight loss program and it` cost.......... [Re: ric3xrt] #2494394
05/10/18 02:17 PM
05/10/18 02:17 PM
State of confusion
State of confusion
Have you messed with these.............
Re: Real world weight loss program and it` cost.......... [Re: Bob J] #2494419
05/10/18 03:37 PM
05/10/18 03:37 PM
Ahh gotcha.
It is great to place weight where it belongs for a particular project to perform best whether it is round, course or straight line.
I have a target weight and it has so far been slow either because of availability, $$ time or people just simply slamming the door on me because it's all crazy. I'm glad I'm not alone by the various confessions noted on here. LOL.
Sounds like Thumper, the original publisher of this thread has found a few horses and lighter weight within new items hitting the market.
Hope that he gets a chance to weigh all the carbs for a comparison as far as weight, even though a heavier carb may make more power with a correct tune.
I could be wrong.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2494470
05/10/18 05:53 PM
05/10/18 05:53 PM
State of confusion
State of confusion
After more tuning today, GREAT things are going to be available for all of us and talk about conversations.........."Them" Man your car fly's what size carb you running....Me oh just a 2-barrel............ laugh2 boogie
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2494475
05/10/18 06:05 PM
05/10/18 06:05 PM
Colorado
Bob J Offline
Bob J  Offline
Colorado
This is my not carb and some of the motor. If the crank scraper would only come in. Oh and the block is still in the machine shop.
Re: Real world weight loss program and it` cost.......... [Re: Bob J] #2494478
05/10/18 06:15 PM
05/10/18 06:15 PM
State of confusion
State of confusion
1 barrel ............ work
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2494557
05/10/18 10:58 PM
05/10/18 10:58 PM
Colorado
Bob J Offline
Bob J  Offline
Colorado
Why not I use to ran a 3 barrel, remember those?
Re: Real world weight loss program and it` cost.......... [Re: Bob J] #2494588
05/11/18 12:30 AM
05/11/18 12:30 AM
Lock, stock and barrel. LOL.
