400 Big Block street motor- contemplating some directions
#2494229
05/10/18 01:53 AM
05/10/18 01:53 AM
Posts: 1,682 Philadelphia
radar
Philadelphia
Here I go with a long post, sorry! Please help me think about a street 400 block build for my antique truck.
Details and The intended chassis:
I have been looking for a 400 block for a while and finally scored one complete carb to pan with all accessories and brackets. Perfect candidate to stuff into my 1954 3/4 ton dodge pickup truck! The truck already has a jeep grand cherokee rear axle, new suspension and kingpins, a nice aluminum radiator, and four wheel power disc brakes. I heard I would need to do an oil filter relocation, electric fans, and re-work the steering. The steering box is beat anyway but otherwise the truck is pretty roadworthy and ready for a little v8 power. The rear is 3.55 limited slip and it has all terrain 12”x31” rear tires.
Goals/limitations:
I know this block is going to get a rebuild but I would like to keep the iron exhaust manifolds and probably the 452 casting # heads for now too. I want to keep the stamped rockers and use a hydraulic cam, probably flat tappet for economy. I want to make power from idle to 5000 with neck snapping torque from any speed under 40mph. I want to lay stripes at will from a roll. I don’t want to do more than 80mph or do any real racing over 45mph. I don’t want a lazy pig of a motor! If I got bored with the initial result then stealth heads and headers could probably uncork it later. I’m definitely doing pistons, a cam and intake but I’m unsure about stroking it.
Build options I’m considering:
-400 with rods, 9:1 pistons, cam, intake. This one would give up some power from a stroker but I’m sure a de-smogged 400 could put out 350hp/400tq without being too revvy and wouldn’t cost much if I could find stock weight .030 over slugs maybe hyper not forged. I could probably get power like a smallblock 408 pretty easily with the huge bore.
-470 stroker kit. The 440 source 512 kit is a sexy number but their 470 kit offers lower compression ratios. I have a feeling that I couldn’t possibly put a big enough cam in with the limitation of stamped rockers to get poor idle or street manners with a 470-512 eating up duration?
Would a big CID kit just be an ego/bragging rights thing all corked up with stock heads or would it have that big flat torque curve from idle to 5000? I don’t need it to rip from 5-7k, all done well before 6000 is fine. I also don’t want it to feel like a tow truck all power no giddyup- the decently light vehicle should come into play there?
What do you all think? I’ve seen some shredding low deck builds on here- I’m trying to do something way simpler but that 512 is calling me hahaha
Thanks for reading and as always any type of constructive or non constructive commentary or discussion is welcome!
Radar
Re: 400 Big Block street motor- contemplating some directions
[Re: radar]
#2494243
05/10/18 02:45 AM
05/10/18 02:45 AM
Posts: 43,283 Bend,OR USA
Cab_Burge
[Re: radar]
#2494464
05/10/18 05:34 PM
05/10/18 05:34 PM
crabman173
crabman173
Invest in a set of pistons that come to the top--use Summit K6401 cam new valve springs and other than that 100% stock as a rock even your old used rod bolts sweet valve job---It will be cheap and if you tune on the distributor with an FBO plate it will run fantastic!!!
manifolds everyone he wants manifolds
400's are like 360's no performance history because they were all low compression---
That recipe will run amazing and be cheaper than a concert ticket
[Re: radar]
#2494647
05/11/18 04:47 AM
05/11/18 04:47 AM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Since you put a limit on rpm, i would follow Andyf or Cabs' advice and go big. It depends on what you are willing to invest in the shortblock, but my preferance is go big, 512. This is the best situation that the statement YOU CAN'T BEAT CUBIC INCHES works in. If you have 25 percent more cubic inches than a 400, (512) you should be able to build 25 percent, or close, more torque way down low (2500 rpm?) where you say you want it. A custom set of pistons designed for the good heads down the road would be my choice. Then when you upgrade, the gains will be very well worth it.
[Re: quickd100]
#2494781
05/11/18 03:02 PM
05/11/18 03:02 PM
Cab_Burge
I've built several different combinations of 400 stroker motors for pump gas and race gas. I would bore the block first after having it sonic tested and then decide on the piston and rods and compression ratio with your current heads, bore it as big as needed to straighten up the bores only. Don't go to the maximum bore to start with If it will clean up at 4.360 use that, if not it might clean up at 4.375 or it may need to go to 4.380 My current bracket motor is a 230 thick main cold weather block I bought from Andyf and it cleaned up at 4.350 I have had several new 4.150 BB stroker cranks with Mopar rod journal sizes offset ground down to 4.300 stroke with 2.200 rod journal sizes and used forged steel BB Chevy H beam rods in 6.800 and 6.700 rod length The pistons are really light and the motors make a hoop of torque and HP The more common crankshafts available are 4.25, 4.150 and the old shorter 3.91 stroke, they work very well also, especially for a pump gas motor OP, good luck on your build, be ready to enjoy or have the crap scared out of you the first time you go to WOT AKA aside, these motors can make a bunch of power is built correctly for the application so be safe until you get use to the new found power
[Re: radar]
#2495636
05/13/18 07:10 PM
05/13/18 07:10 PM
radar
Philadelphia
Darn it- ‘project creep’ strikes again!
I got the manifolds and heads off this morning- the heads are not looking too great and the heads and exhaust manifolds weighed a TON!
So... I already ordered a set of stealths. I’ll have to weld up some headers after I shoehorn this thing in my old truck too- no need to cart around a thousand pounds of iron manifolds. I’ll be doing an rpm manifold too- it looks pretty easy to shave 75+ lbs off a big block.
Wrenching on my first big block mopar I am not sure if I am impressed by how all the BB systems and parts are independent of each other and easy to service, or how the LA combines many items to save weight and space haha- water pump/timing cover,oil pump/rear main/ rear main seal, intake/valley pan
I’m definitely going 512. There is really no reason not to! I still am still planning on a mild cam and low powerband. The heads will get checked out before installation and my block will go to the machine shop this week.
Thanks for all the input you guys are great
[Re: Twostick]
#2495639
05/13/18 07:21 PM
05/13/18 07:21 PM
radar
Philadelphia
No replacement for displacement!
My 493 is just shy of 9:1 and made 600 ft/lbs at 4000. It was making 500 ft/lbs by 2000 RPM. MP509 cam, TBI and Edelbrock RPM heads with 1.7 rockers. That's the magic of cubes. That cam in a 440 is a stone off idle.
It's happy on all but the hottest days on 87 regular and if my timing curve was a little less aggressive, it would likely be OK on 87 all the time.
Kevin Sounds awesome! I am looking at cams one step milder than the 509 but I’m not buying a cam until I finish collecting a lot more parts. Does all that torque move a factory high stall type converter up a few hundred rpm? What are you running for a converter?
[Re: radar]
#2495807
05/14/18 03:05 AM
05/14/18 03:05 AM
Posts: 6,569 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Kevin Sounds awesome! I am looking at cams one step milder than the 509 but I’m not buying a cam until I finish collecting a lot more parts. Does all that torque move a factory high stall type converter up a few hundred rpm? What are you running for a converter? Pretty sure it's a 2800 stall. It's a Turbo Action that I got at Mancini's. The first time I tried to check the stall it ripped the left motormount apart about the time the tach approached 2400. I put in a set of Polylock Schumacher mounts which it stretched but the brakes would never hold it and it didn't have enough traction to get a flash stall reading either. The car was a 66 New Yorker, 4800 lbs. Kevin
