I meant stock port window. Not max wedge. They were on the running engine. Just doing an overhaul. They will be gone through. Valve job at minimum.
Have they had any port work? If not, they need it. Most Stage VIs should have been sold as "porter castings" w/ no expectation of being used out of the box.
Has the guide clearance been checked? Not uncommon for even new OOB Stage VIs to have too-loose guides. Mine were and had to be replaced before they were ever used.
If they're even close to stock ports, IMO, there is no use in even bolting them on. Budget for having the heads gone through, or sell 'em for whatever you can get and buy something closer to ready-to-run. Especially since you've trying to feed a 528, those heads are not a great choice, IMO.
My suggestion is to re-evaluate the parts you have, your budget and your expected results. Sometimes they simply aren't in synch and require a change in direction. Better to figure this out early...
