Help! 1998 Dodge Caravan electrical mystery. #2492874
05/06/18 07:14 PM
05/06/18 07:14 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
I have a 1998 Dodge Grand Caravan Sport 3.3L that I've owned since new. It's been very good to me and has nearly 200K miles on it. My son has been driving it at college and it recently started having issues with starting and the radio cutting in and out. He brought it home to check out. I found the battery was fully charged and wouldn't put a draw on a battery charger. But the terminals were extremely corroded. I cleaned up the battery and terminals with water and baking soda, put a little dialectric grease on the terminals, and cinched it all down. It starts right up but all of a sudden I have no gauges, no park or headlights, and the electric locks don't work. The turn signals work and show on the dash, the parking brake light and other idiot lights work, but the tach, speedo, gas gauge and temp gauge all quit working, along with the lights and locks. I've checked all related fuses and they are fine. I can't even begin to imagine where these different functions would intersect. Can anybody offer any clues or advice?!?
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Help! 1998 Dodge Caravan electrical mystery. [Re: MadMatt] #2492882
05/06/18 07:42 PM
05/06/18 07:42 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
ant remember the years this applied too . But there was a couple years they had BCM issues would cause weird electrical issues.
Unplug the BCM and see if functions return
Re: Help! 1998 Dodge Caravan electrical mystery. [Re: gtx6970] #2492916
05/06/18 08:54 PM
05/06/18 08:54 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Thanks for the suggestion. But I tried it and no luck. down
Re: Help! 1998 Dodge Caravan electrical mystery. [Re: MadMatt] #2492919
05/06/18 09:05 PM
05/06/18 09:05 PM
New Jersey
P
Powerflow Offline
Powerflow  Offline
P
New Jersey
I don't know if this applies to earlier years, but Gen IV Caravans (2001-07) had corrosion issues with the connections under the underhood fuse box. The Gen IV fuse box pivots so you can see underneath.
Re: Help! 1998 Dodge Caravan electrical mystery. [Re: MadMatt] #2492920
05/06/18 09:09 PM
05/06/18 09:09 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
It's the BCM.
Re: Help! 1998 Dodge Caravan electrical mystery. [Re: rt66jim] #2492926
05/06/18 09:33 PM
05/06/18 09:33 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Originally Posted By rt66jim
It's the BCM.
As in replace the BCM??
Re: Help! 1998 Dodge Caravan electrical mystery. [Re: MadMatt] #2492957
05/06/18 10:52 PM
05/06/18 10:52 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
If it's the BCM will the OBD port show error codes? I think O'Reilly auto parts does a free OBD error check.
Re: Help! 1998 Dodge Caravan electrical mystery. [Re: MadMatt] #2492996
05/06/18 11:51 PM
05/06/18 11:51 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I would be looking for a bad, corroded, or missing ground between the battery and the body.
Did you remove the battery cables and cleaned the posts and terminals, or did you just chemically clean the posts? Chemically cleaning doesn't always get the job done, especially if they are really bad. I would also consider replacing the terminals on the cables or replacing the entire cable. A lot of problems on old stuff is fixed with good clean metal to metal battery connections, on both ends of the cables. Gene
Re: Help! 1998 Dodge Caravan electrical mystery. [Re: poorboy] #2493001
05/07/18 12:13 AM
05/07/18 12:13 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Try unplugging the cluster.(reboot) Except for the headlights? You did say you have no headlights right. I would address that problem first. Do the headlight come on when you flash them with the turn signal stalk?
Re: Help! 1998 Dodge Caravan electrical mystery. [Re: poorboy] #2493031
05/07/18 01:25 AM
05/07/18 01:25 AM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Thanks for the suggestions. I will try and check the grounds tomorrow. I checked for continuity, resistance, and voltage drop between the battery and the fuse/relay box under the hood and everything checked out fine. I physically cleaned the battery posts and terminals. I don't think the issue is at the battery, but a ground problem at the relay boxes sounds like a possibility.
Re: Help! 1998 Dodge Caravan electrical mystery. [Re: SALEM1912] #2493032
05/07/18 01:26 AM
05/07/18 01:26 AM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Nope, they don't flash. I also found out the power mirrors don't work. But the power windows and the brake lights do work.
Re: Help! 1998 Dodge Caravan electrical mystery. [Re: MadMatt] #2493117
05/07/18 11:05 AM
05/07/18 11:05 AM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
Try to unhook the battery again and turn the key on while its unhooked. I had the same thing happen with an 02 caravan, dash lights, speedo and tach quit, hooked battery back up, all was working again.
Re: Help! 1998 Dodge Caravan electrical mystery. [Re: gtsdude] #2493147
05/07/18 12:19 PM
05/07/18 12:19 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
So, reconnect the battery with the key in the ON position?
Re: Help! 1998 Dodge Caravan electrical mystery. [Re: MadMatt] #2493192
05/07/18 02:09 PM
05/07/18 02:09 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
I was not there personally to see it but back when my mom’s 2005 T&C 3.3 was just a few months old my father said he simply pressed the trip odometer reset button and suddenly lost all Dash lights and functions. The BCM was replaced at the dealership under warranty.
I have seen the driver’s side power window suddenly quit functioning,
then suddenly start working again weeks later.
When it quit I could see the a voltage drop when the down switch was depressed, indicating the motor had a locked rotor with not enough troque to break free.
During the time the power window was not working I now remember I put a pulse style desulphating charger on the battery for 48 hours, and cleaned connections, including the block ground terminal about two feet below the battery posts.
I will keep in mind that there may be “green death” on connections below the engine compartment fuse box.
Re: Help! 1998 Dodge Caravan electrical mystery. [Re: MadMatt] #2493205
05/07/18 02:31 PM
05/07/18 02:31 PM
Stoney Creek, Ontario, Canada
76Beeper Offline
76Beeper  Offline
In the relay/fuse box in the engine compartment, check the fuse labelled
I/O (input/output) if it's blown then replace. If it's not blown pull the fuse wait 10 seconds and reinstall.
Re: Help! 1998 Dodge Caravan electrical mystery. [Re: MadMatt] #2493307
05/07/18 06:14 PM
05/07/18 06:14 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
We used to have a 2000 that started to weird things. There was corrosion in the harness below the battery from acid residue running down from the battery.
Re: Help! 1998 Dodge Caravan electrical mystery. [Re: MadMatt] #2493632
05/08/18 02:08 PM
05/08/18 02:08 PM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
No, turn key on with battery not hooked up, gets any battery voltage stored in the vehicle to 0.
Re: Help! 1998 Dodge Caravan electrical mystery. [Re: MadMatt] #2493636
05/08/18 02:19 PM
05/08/18 02:19 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Buddy's did the same, tried a lot of things. One mechanic said to pound the dash with his fist, he did and it would work again. That tells me bad ground connections around cluster. He did replace cluster and is working fine now but the disconnecting could have been helpful too. How many times in older cars just wiggling the fuse cured issues.
Common practice on those 70s Dodge trucks with the fuse panel on top of the dash under the glove box door (spilled drink)
Re: Help! 1998 Dodge Caravan electrical mystery. [Re: cudaman1969] #2493776
05/08/18 09:59 PM
05/08/18 09:59 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
I would track down why you have no headlightsmost likely related to the other things wrong.
Re: Help! 1998 Dodge Caravan electrical mystery. [Re: MadMatt] #2493783
05/08/18 10:20 PM
05/08/18 10:20 PM
A727Tflite Offline
A727Tflite  Offline
Another common issue in the late 90's minivans was the wiring bundle that ran next to the trans pan - the convolute was not wrapped in some areas and the sharp trans pan chaffed wires. Caused mostly power train issues but I believe there were some body electronics affected as well.
