Page 1 of 3 1 2 3
Shopping for a drive shaft : UPDATE #2493647
05/08/18 02:45 PM
05/08/18 02:45 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Can anyone suggest a place that builds quality drive shafts for an affordable price, like under $400. Called Dennys, strange a local shop here. All want 400+ for a chomemoly shaft in 3.5" with 1350's and no yoke. Would mild steel be strong enough with my combo. 650ftlb/3380#
Re: Shopping for a drive shaft [Re: mopar dave] #2493659
05/08/18 03:11 PM
05/08/18 03:11 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Yes mild steel would be ok,mine is[imo]The cm is for weight loss I believe.
Re: Shopping for a drive shaft [Re: mopar dave] #2493663
05/08/18 03:21 PM
05/08/18 03:21 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
CCI in new Baltimore on 26 mile 586-716-1160
JAKES AUTOMOTIVE
Re: Shopping for a drive shaft [Re: mopar dave] #2493669
05/08/18 03:43 PM
05/08/18 03:43 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
If you buy from Dynotech have a local shop check the balance. I'd chased a vibration ever since mini tubing and installing the Dana and new drive shaft in my Dart. Finally this spring I took the drive shaft to a local shop and had the balance checked, it was way off. I drove the Dart to work last night, the first time out with the new balance job, smooth as silk.
Re: Shopping for a drive shaft [Re: mopar dave] #2493673
05/08/18 03:52 PM
05/08/18 03:52 PM
AndyF Offline
AndyF  Offline
Check out Doctor Diff. He should be able to get you a nice driveshaft from Strange drop shipped to your door. That is what I used for my Duster project.
Re: Shopping for a drive shaft [Re: mopar dave] #2493675
05/08/18 03:59 PM
05/08/18 03:59 PM
Odessa, Fl
blowndart Online content
blowndart  Online Content
Odessa, Fl
I recently had a shaft built by Precision Shaft Tech. Price, part and service and turnaround was really good. http://www.pstds.com/
Re: Shopping for a drive shaft [Re: mopar dave] #2493678
05/08/18 04:15 PM
05/08/18 04:15 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I think steel would be fine, but are you going to be looking for .03 second down the road and wish you spent double on an aluminum, CF, or cromoly? I put steel in both of my cars and although I'm still a skeptic, sometimes I wish I spent extra for something lighter. I got one from dennys and one from a local shop. From what I remember dennys had a crazy wait and last time I checked I couldn't believe how much the prices went up. I want to say the local guy was like 450 but he sent me home with slip yoke and drive flange to measure with, he had it ready the next day. 450 was with slip yoke and drive flange for the 8.8 rear.
Try cj tattons or tattons driveshafts. He sells on eBay but might have website, you can call him. I've used him for jeeps before and had no issues. I couldn't find cheaper. Pretty fast too. He's mostly jeep and 4x4 but I want to say the jeep stuff is super finicky with driveline vibes.
Re: Shopping for a drive shaft [Re: JAMESDART] #2493691
05/08/18 04:45 PM
05/08/18 04:45 PM
Mt Morris Michigan
Mt Morris Michigan
Ok i will check these out. I currently have a dynotech and looking for something different this time. Thanks
Re: Shopping for a drive shaft [Re: mopar dave] #2493698
05/08/18 05:15 PM
05/08/18 05:15 PM
Mt Morris Michigan
Mt Morris Michigan
CCI wants 300-330 with my yoke. Precision shaft wants 329 with my yoke. A local place here (joint clutch and gear) wants 275-300 with my yoke. Dennys wants 534 with a new yoke.
Re: Shopping for a drive shaft [Re: mopar dave] #2493699
05/08/18 05:17 PM
05/08/18 05:17 PM
Mt Morris Michigan
Mt Morris Michigan
These are 3.5 mild steel good for 1000hp. I think strange wanted 435 for cm without yoke.
Re: Shopping for a drive shaft [Re: mopar dave] #2493702
05/08/18 05:28 PM
05/08/18 05:28 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Strange does a 3" CM shaft with HD weld yokes for $250, 3" CM with CM yokes for 335 and the 3.5 " for 435. They need a yoke to balance it. You send one or buy one from them. Takes a couple days right now.
Re: Shopping for a drive shaft [Re: CMcAllister] #2493707
05/08/18 05:47 PM
05/08/18 05:47 PM
Mt Morris Michigan
Mt Morris Michigan
Yes, they need the yoke to balance i know. I would have to send them my yoke. Gonna call strange back and get a price on 3.5 mild steel as well.
Re: Shopping for a drive shaft [Re: AndyF] #2493708
05/08/18 05:48 PM
05/08/18 05:48 PM
Mt Morris Michigan
Mt Morris Michigan
Does dr diff have a number?
Re: Shopping for a drive shaft [Re: mopar dave] #2493719
05/08/18 06:52 PM
05/08/18 06:52 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Ann Arbor Driveshaft
Re: Shopping for a drive shaft [Re: mopar dave] #2493720
05/08/18 06:52 PM
05/08/18 06:52 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Re: Shopping for a drive shaft [Re: CMcAllister] #2493730
05/08/18 08:11 PM
05/08/18 08:11 PM
Mt Morris Michigan
Mt Morris Michigan
Talked to dr diff about a driveshaft. Suggested the strange 3" cm with 1350 joints and a spicer yoke for $365.
Re: Shopping for a drive shaft [Re: mopar dave] #2493733
05/08/18 08:15 PM
05/08/18 08:15 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
That strange price sounds interesting.
Has there been any comparison to mild steel done? Wall thickness, weight?
Re: Shopping for a drive shaft [Re: mopar dave] #2493744
05/08/18 08:52 PM
05/08/18 08:52 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Have you called DTS
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Shopping for a drive shaft [Re: JAMESDART] #2493750
05/08/18 09:04 PM
05/08/18 09:04 PM
Mt Morris Michigan
Mt Morris Michigan
Dennys wont tell thickness. I believe the strange cm is .083. I would guess the 3" cm is lighter than the mild steel 3.5".
Re: Shopping for a drive shaft [Re: B3422W5] #2493751
05/08/18 09:05 PM
05/08/18 09:05 PM
Mt Morris Michigan
Mt Morris Michigan
No, i did not call them yet. Will pick with the calls again tomorrow. The 3" cm by strange looks good to me right now.
Page 1 of 3 1 2 3
